Configuring and Viewing Tracing
Overview
After enabling tracing on the Monitoring tab, you can view details on the Tracing page, or go to the APM console and choose Application Monitoring > Tracing. This feature is available only for Java 8 and 11 functions.
Notes and Constraints
This feature is available only in the CN East-Shanghai1 and CN North-Beijing4 regions.
- Only functions with 512 MB or larger memory can be traced. For functions whose memory is less than 512 MB, increase the memory on the Configuration > Basic Settings page.
- You have obtained the permission to use APM. For details, see APM Permissions Management. If tracing is not enabled, no trace data can be obtained.
Enabling Tracing
- Log in to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
- Click the name of the desired function.
- Choose Monitoring > Tracing.
- Click enable tracing.Figure 1 Enabling tracing
- The system automatically obtains an access key (AK/SK) from APM, as shown in Figure 2.
- If an access key already exists, select an AK from the AK drop-down list and click OK.
- If you do not have an access key, click Create AK/SK to create one on the APM console. For details, see Creating an Access Key. Then the new AK/SK will be synchronized to the FunctionGraph console.
- Manage tracing.
- Click Disable Tracing in the upper right corner. In this case, you cannot view function traces.
- If the AK/SK has been changed on the APM console, you need to go to the FunctionGraph console and click Update AK/SK in the upper right corner.
Querying Trace Details
- Return to the FunctionGraph console, choose Functions > Function List in the navigation pane, and click the name of a function with tracing enabled. The function details page is displayed.
- On the Monitoring tab page, choose Tracing.
- Set search criteria and click Search.Figure 3 Setting search criteria
- Time: Set a time range to query traces. It can be up to 24 hours.
- Response Time: Set the response time.
- Execution Result: Select All, Successful, or Failed.
- Trace ID: If you specify this parameter, all other search criteria become invalid and only the trace with the specified ID will be searched.
- View the trace details on the right.
Viewing details about a trace: In the query result, click the trace name and view details on the APM console.
Figure 4 Clicking a trace name
Figure 5 Details about a trace
Viewing information about all traces: Click go to APM to perform complete path analysis and other operations.
Figure 6 Going to APM
Example
- The following shows how function A (DemoTestA) invokes function B (DemoTestB) by sending an HTTP request. Figure 7 Function invocation details
1. Total time consumed by a method of function A
2. Invoking function B by sending an HTTP request
3. Accessing function B
4. Executing executeQuery
5. Executing a SELECT statement to query data
- The following shows a complete function execution process that contains cold start.
Spans are described as follows:
- load: time for downloading and decompressing the function code package and dependency package
- preload: time for loading function code and initializing the execution environment
- init: execution duration of the initializer. The initializer is executed only during cold start.
- processInvoke: execution duration of the function
For more information, see section "Tracing".
