Updated on 2026-08-24 GMT+08:00
Timer Trigger
This section describes how to create a timer trigger on the FunctionGraph console to trigger a function at a specified frequency.
Common application scenarios:
  • Back up important data. For example, back up data every seven days.
  • Monitor the server status and resource usage. For example, functions are executed and server usage reports are sent at 10:00 a.m. every day.
Event Description
A timer trigger invokes a function based on a fixed frequency (minutes, hours, or days) or a specified Cron expression. It is suitable for scenarios where tasks need to be executed periodically.
You can use timer triggers for shared functions in the LA-Sao Paulo1 region.
Video Tutorial
This video shows how to use a timer trigger to invoke your function and check whether the function can be executed at the specified frequency.
As product functions evolve, the GUI may vary. This tutorial is for reference only.
Notes and Constraints
HTTP functions do not support timer triggers.
You have created a function. For details, see Creating a Function from Scratch
Creating a Timer Trigger
  1. Log in to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
  2. Click the name of the function to be configured. The function details page is displayed.
    You can configure a timer trigger for a shared function on the Shared page in the LA-Sao Paulo1 region. For details about shared functions, see Sharing Functions Based on RAM.
  3. Choose Configuration > Triggers and click Create Trigger, as shown in Figure 1.
    Figure 1 Creating a trigger
  4. Configure the following parameters:
    Table 2 Timer trigger parameters
    Example Value
    Trigger Type
    Select Timer.
    Timer
    Timer Name
    Customize a name. The value can contain letters, digits, underscores (_), and hyphens (-). It must start with a letter and cannot exceed 64 characters.
    Timer-fg
    Rule
    Trigger rule. You can select Fixed rate or Cron expression.
    • Fixed rate: The function is triggered at a fixed rate of minutes, hours, or days. You can set a fixed rate from 1 to 60 minutes, 1 to 24 hours, or 1 to 30 days.
    • Cron expression: The function is triggered based on a complex rule. For example, you can set a function to be executed at 08:30:00 from Monday to Friday. For more information, see Cron Expression Rules.
    Fixed rate
    1 minute
    Enable Trigger
    Determine whether to enable the timer trigger. If this parameter is disabled, the function will not be triggered at the specified frequency.
    Enabled
    Additional Information
    Optional.
    The additional information you configure will be put into the user_event field of the timer event source. For details, see Supported Event Sources.
  5. Click OK.
Viewing the Execution Result
After a timer trigger is created, the function will be executed periodically according to the configured trigger rule. You can view function run logs on the function details page.
  1. Return to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
  2. On the Functions page, click the name of the function to be configured.
  3. Choose Monitoring > Logs to query function run logs.
You can configure a cron expression in the following two formats for a function timer trigger:
  • @every format
    @every Nunit. N is a positive integer. unit can be ns, µs, ms, s, m, or h. An @every expression means to invoke a function every N time units, as shown in Table 3.
    Table 3 Example expressions
    Expression
    @every 30m
    Triggers a function every 30 minutes.
    @every 1h
    Triggers a function every hour.
    @every 2h30m
    Triggers a function every 2.5 hours.
  • Standard format
    The format is "seconds minutes hours day-of-month month day-of-week". day-of-week is optional. The fields must be separated from each other using a space. Table 4 describes the fields in a standard cron expression. For details about the special characters, see Table 7.
    Table 4 Cron expression fields
    Field
    Value Range
    Special Characters Allowed
    CRON_TZ
    Optional. If this parameter is not set, the region's time zone is used by default.
    If your task will run in a specific time zone, use CRON_TZ to specify the time zone. For example, to trigger your function at 04:00 on the first day of each month (Beijing time), use CRON_TZ=Asia/Shanghai 0 0 4 1 * *.
    The time zone expression varies depending on the region. Query the CRON_TZ expression of the required region. For details, see Table 8.
    Seconds
    Mandatory
    0–59
    Minutes
    Mandatory
    0–59
    Hours
    Mandatory
    0–23
    Day-of-month
    Mandatory
    1–31
    Month
    Mandatory
    1–12 or Jan–Dec. The value is case-insensitive, as shown in Table 5.
    Day-of-week
    Optional
    0–6 or Sun–Sat. The value is case-insensitive, as shown in Table 6. 0 means Sunday.
    Table 5 Value description of the month field
    Month
    Digit
    Abbreviation
    January
    Jan
    February
    2
    Feb
    March
    3
    Mar
    April
    4
    Apr
    May
    5
    May
    June
    6
    Jun
    July
    7
    Jul
    August
    8
    Aug
    September
    9
    Sep
    October
    10
    Oct
    November
    11
    Nov
    December
    12
    Dec
    Table 6 Value description of the day-of-week field
    Day of Week
    Digit
    Abbreviation
    Monday
    Mon
    Tuesday
    2
    Tue
    Wednesday
    3
    Wed
    Thursday
    4
    Thu
    Friday
    5
    Fri
    Saturday
    6
    Sat
    Sunday
    0
    Sun
    Table 7 describes the special characters that can be used in a cron expression.
    Table 7 Special character description
    Special Character
    Meaning
    Used to specify all values within a field.
    * in the minutes field means every minute.
    Used to specify multiple values, which can be discontinuous.
    For example, "Jan,Apr,Jul,Oct" or "1,4,7,10" in the month field and "Sat,Sun" or "6,0" in the day-of-week field.
    Used to specify a range.
    For example, "0-3" in the minutes field.
    Used to specify something in one of the two fields in which the character is allowed, but not the other.
    You can specify something only in the day-of-month or day-of-week field. For example, if you want your function to be executed on a particular day (such as the 10th) of the month, but do not care what day of the week that is, then put "10" in the day-of-month field and "?" in the day-of-week field.
    Used to specify increments. The character before the slash indicates when to start, and the one after the slash represents the increment.
    For example, "1/3" in the minutes field means to trigger the function every 3 minutes starting from 00:01:00 of the hour.
    Table 8 describes several example cron expressions.
    Table 8 Example cron expressions
    Function Scheduling Example
    Cron Expression (Beijing Time)
    12:00 every day
    CRON_TZ=Asia/Shanghai 0 0 12 * * *
    12:30 every day
    CRON_TZ=Asia/Shanghai 0 30 12 * * *
    26th, 29th, and 33rd minutes of each hour
    CRON_TZ=Asia/Shanghai 0 26,29,33 * * * *
    12:30 from Monday to Friday
    CRON_TZ=Asia/Shanghai 0 30 12 ? * MON-FRI
    Every 5 minutes between 12:00 and 14:59, Monday to Friday
    CRON_TZ=Asia/Shanghai 0 0/5 12-14 ? * MON-FRI
    12:00 every day from January to April
    CRON_TZ=Asia/Shanghai 0 0 12 ? JAN,FEB,MAR,APR *
Creating a Timer Trigger for a Shared Function
You can configure a timer trigger for a shared function in the LA-Sao Paulo1 region. For details about the shared function, see Sharing Functions Based on RAM.
  2. On the Shared tab, click the function name to go to the function details page.
  3. The subsequent steps are the same as those for a common function. For details, see 3.
Helpful Links
Manage function triggers through APIs. For details, see Function Trigger APIs.
