- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Key Management Service
- Cloud Secret Management Service
- Key Pair Service
- Dedicated HSM
- Tag Management
- Auditing Logs
- Sharing
- Permission Control
Best Practices
- General
API Reference
- Before You Start
- Calling APIs
- API Overview
APIs
Key Management APIs
- Key Lifecycle Management
- DEK Management
- Small-Size Data Encryption and Decryption
- Signature and Verification
- Key Tag Management
- Key API Version Query
- Querying Key API Versions
- Key Import Management
- Querying Keys
- Key Grant Management
- Key Rotation Management
- Dedicated Keystore Management
- Signature Verification
- Key Pair Management APIs
- Secret Management APIs
Key Management APIs
- Historical APIs
- Application Examples
- Appendix
- SDK Reference
KMS Related
- What Is Key Management Service?
- What Is a Customer Master Key?
- What Is a Default Key?
- What Are the Differences Between a Custom Key and a Default Key?
- What Is a Data Encryption Key?
- Why Cannot I Delete a CMK Immediately?
- Which Cloud Services Can Use KMS for Encryption?
- How Do Huawei Cloud Services Use KMS to Encrypt Data?
- What Are the Benefits of Envelope Encryption?
- Is There a Limit on the Number of Custom Keys That I Can Create on KMS?
- Can I Export a CMK from KMS?
- Can I Decrypt My Data if I Permanently Delete My Custom Key?
- How Do I Use the Online Tool to Encrypt or Decrypt Small Volumes of Data?
- Can I Update CMKs Created by KMS-Generated Key Materials?
- When Should I Use a CMK Created with Imported Key Materials?
- What Should I Do When I Accidentally Delete Key Materials?
- How Are Default Keys Generated?
- What Should I Do If I Do Not Have the Permissions to Perform Operations on KMS?
- Why Can't I Wrap Asymmetric Keys by Using -id-aes256-wrap-pad in OpenSSL?
- Key Algorithms Supported by KMS
- What Should I Do If KMS Failed to Be Requested and Error Code 401 Is Displayed?
- What Is the Relationship Between the Ciphertext and Plaintext Returned by the encrypt-data API?
- How Does KMS Protect My Keys?
- How Do I Use an Asymmetric Key to Verify the Signature Result of a Public Key Pair?
- Does an Imported Key Support Rotation?
- Does KMS Support Offline Data Encryption and Decryption?
- How Do I Convert an Original EC Private Key into a Private Key in PKCS8 Format?
- CSMS Related
KPS Related
- How Do I Create a Key Pair?
- What Are a Private Key Pair and an Account Key Pair?
- How Do I Handle an Import Failure of a Key Pair Created Using PuTTYgen?
- What Should I Do When I Fail to Import a Key Pair Using Internet Explorer 9?
- How Do I Log In to a Linux ECS with a Private Key?
- How Do I Use a Private Key to Obtain the Password to Log In to a Windows ECS?
- How Do I Handle the Failure in Binding a Key Pair?
- How Do I Handle the Failure in Replacing a Key Pair?
- How Do I Handle the Failure in Resetting a Key Pair?
- How Do I Handle the Failure in Unbinding a Key Pair?
- Do I Need to Restart Servers After Replacing Its Key Pair?
- How Do I Enable the Password Login Mode for an ECS?
- How Do I Handle the Failure in Logging In to ECS After Unbinding the Key Pair?
- What Should I Do If My Private Key Is Lost?
- How Do I Convert the Format of a Private Key File?
- Can I Change the Key Pair of a Server?
- Can a Key Pair Be Shared by Multiple Users?
- How Do I Obtain the Public or Private Key File of a Key Pair?
- What Can I Do If an Error Is Reported When an Account Key Is Created or Upgraded for the First Time?
- Will the Account Key Pair Quota Be Occupied After a Private Key Pair Is Upgraded to an Account Key Pair?
- Why Is the Private Key Pair Invisible After It Is Upgraded to an Account Key Pair When Logging in as a Federated User?
Dedicated HSM Related
- What Is Dedicated HSM?
- How Does Dedicated HSM Ensure the Security for Key Generation?
- Do Equipment Room Personnel Has the Super Administrator Role to Steal Information by Using a Privileged UKey?
- What HSMs Are Used for Dedicated HSM?
- What APIs Does Dedicated HSM Support?
- How Do I Enable Public Access to a Dedicated HSM Instance?
- Pricing
General
- What Functions Does DEW Provide?
- What Cryptography Algorithms Does DEW Use?
- In Which Regions Are DEW Services Available?
- What Is a Quota?
- What Is the Resource Allocation Mechanism of DEW?
- What Are Regions and AZs?
- Can DEW Be Shared Across Accounts?
- How Do I Access the Functions of DEW?
- Why Do DEW Pemissions Fail to Take Effect Immediately?
KMS Related
- Videos
More Documents
- User Guide (ME-Abu Dhabi Region)
- User Guide (Paris and Amsterdam Regions)
User Guide
- Auditing Logs
KMS Related
- How Do Cloud Services Use KMS to Encrypt Data?
- What Types of Keys Can I Import?
- Credential Related
KMS Related
- Change History
- Before You Start
- Calling APIs
- API Overview
APIs
- Creating a CMK
- Enabling a CMK
- Disabling a CMK
- Scheduling the Deletion of a CMK
- Canceling the Scheduled Deletion of a CMK
- Querying the List of CMKs
- Querying the Information About a CMK
- Creating a Random Number
- Creating a DEK
- Creating a Plaintext-Free DEK
- Encrypting a DEK
- Decrypting a DEK
- Querying the Number of Instances
- Querying the Quota of a User
- Changing the Alias of a CMK
- Changing the Description of a CMK
- Encrypting Data
- Decrypting Data
- Obtaining CMK Import Parameters
- Importing CMK Material
- Deleting CMK Material
- Querying CMK Instances
- Querying CMK Tags
- Querying Project Tags
- Adding or Deleting CMK Tags in Batches
- Adding a CMK Tag
- Deleting a CMK Tag
- Appendix
- Change History
API Reference (Paris and Amsterdam Regions)
- Before You Start
- Calling APIs
- API Overview
APIs
- Creating a CMK
- Enabling a CMK
- Disabling a CMK
- Creating a DEK
- Encrypting a DEK
- Decrypting a DEK
- Creating a Grant
- Revoking a Grant
- Retiring a Grant
- Querying Grants on a CMK
- Querying Grants That Can Be Retired
- Encrypting Data
- Decrypting Data
- Enabling Rotation for a CMK
- Changing the Rotation Interval for a CMK
- Disabling Rotation for a CMK
- Querying the Rotation Status of a CMK
- Appendix
- Change History
- Before You Start
- Calling APIs
- API Overview
APIs
- Creating a CMK
- Enabling a CMK
- Disabling a CMK
- Creating a DEK
- Encrypting a DEK
- Decrypting a DEK
- Creating a Grant
- Revoking a Grant
- Retiring a Grant
- Encrypting Data
- Decrypting Data
- Appendix
- Change History
Viewing CTS Traces in the Trace List
After you enable CTS and the management tracker is created, CTS starts recording operations on cloud resources. After a data tracker is created, the system starts recording operations on data in Object Storage Service (OBS) buckets. Cloud Trace Service (CTS) stores operation records (traces) generated in the last seven days.
These operation records are retained for seven days on the CTS console and are automatically deleted upon expiration. Manual deletion is not supported.
This section describes how to query or export operation records of the last seven days on the CTS console.
- Traces of a single account can be viewed on the CTS console. Multi-account traces can be viewed only on the Trace List page of each account, or in the OBS bucket or the CTS/system log stream configured for the management tracker with the organization function enabled.
- You can only query operation records of the last seven days on the CTS console. To store operation records for longer than seven days, you must configure transfer to OBS or Log Tank Service (LTS) so that you can view them in OBS buckets or LTS log groups.
- After performing operations on the cloud, you can query management traces on the CTS console one minute later and query data traces five minutes later.
- Data traces are not displayed in the trace list of the new version. To view them, you need to go to the old version.
Viewing Real-Time Traces in the Trace List of the New Edition
- Click
in the upper left corner and choose Management & GovernanceManagement & Deployment > Cloud Trace Service. The CTS console is displayed.
- Choose Trace List in the navigation pane on the left.
- On the Trace List page, use advanced search to query traces. You can combine one or more filters.
- Trace Name: Enter a trace name.
- Trace ID: Enter a trace ID.
- Resource Name: Enter a resource name. If the cloud resource involved in the trace does not have a resource name or the corresponding API operation does not involve the resource name parameter, leave this field empty.
- Resource ID: Enter a resource ID. Leave this field empty if the resource has no resource ID or if resource creation failed.
- Trace Source: Select a cloud service name from the drop-down list.
- Resource Type: Select a resource type from the drop-down list.
- Operator: Select one or more operators from the drop-down list.
- Trace Status: Select normal, warning, or incident.
- normal: The operation succeeded.
- warning: The operation failed.
- incident: The operation caused a fault that is more serious than the operation failure, for example, causing other faults.
- Enterprise Project ID: Enter an enterprise project ID.
- Access Key: Enter a temporary or permanent access key ID.
- Time range: Select Last 1 hour, Last 1 day, or Last 1 week, or specify a custom time range within the last seven days.
- On the Trace List page, you can also export and refresh the trace list, and customize columns to display.
- Enter any keyword in the search box and press Enter to filter desired traces.
- Click Export to export all traces in the query result as an .xlsx file. The file can contain up to 5,000 records.
- Click
to view the latest information about traces.
- Click
to customize the information to be displayed in the trace list. If Auto wrapping is enabled (
), excess text will move down to the next line; otherwise, the text will be truncated. By default, this function is disabled.
- For details about key fields in the trace structure, see Trace Structuresection "Trace References" > "Trace Structure" and Example Tracessection "Trace References" > "Example Traces".
- (Optional) On the Trace List page of the new edition, click Go to Old Edition in the upper right corner to switch to the Trace List page of the old edition.
Viewing Real-Time Traces in the Trace List of the Old Edition
- Click
- Each time you log in to the CTS console, the new edition is displayed by default. Click Go to Old Edition in the upper right corner to switch to the trace list of the old edition.
- Set filters to search for your desired traces, as shown in Figure 1. The following filters are available.
- Trace Type, Trace Source, Resource Type, and Search By: Select a filter from the drop-down list.
- If you select Resource ID for Search By, specify a resource ID.
- If you select Trace name for Search By, specify a trace name.
- If you select Resource name for Search By, specify a resource name.
- Operator: Select a user.
- Trace Status: Select All trace statuses, Normal, Warning, or Incident.
- Click Query.
- On the Trace List page, you can also export and refresh the trace list.
- Click Export to export all traces in the query result as a CSV file. The file can contain up to 5,000 records.
- Click
- Click
on the left of a trace to expand its details.
- Click View Trace in the Operation column. The trace details are displayed.
- For details about key fields in the trace structure, see Trace Structuresection "Trace References" > "Trace Structure" and Example Tracessection "Trace References" > "Example Traces" in the CTS User Guide.
- (Optional) On the Trace List page of the old edition, click New Edition in the upper right corner to switch to the Trace List page of the new edition.
