Batch Executing Commands on COC
In routine ECS management, O&M personnel typically need to update configurations and install software on multiple ECSs. However, the traditional method of manually logging in to each ECS and executing commands is time-consuming, labor-intensive, and error-prone. To address this challenge, COC delivers the batch ECS operation function. With this function, you can deliver script commands to one or more ECSs without logging in to them. This helps you quickly handle routine maintenance on them.
Precautions
- You can perform this operation only when the selected instances are running.
- UniAgent of the selected instance must be running. For details about UniAgent-related operations, see Installing UniAgent on a Host.
- If the selected ECSs run different OSs (Linux and Windows), you need to deliver commands to the ECSs separately.
Currently, only ECSs support batch command execution.
Batch Executing Commands on ECSs
- Log in to COC.
- In the navigation pane, choose Resource O&M > Batch Resource Operations.
- On the displayed page, choose the Elastic Cloud Server (ECS) tab. Click Execute Commands.
- Set parameters for executing a command.
Table 1 Parameter configurations Parameter
Target Instance
Click Add and configure the parameters in the Select Instance dialog box.
For details about the parameters, see Table 2 Parameters for selecting an instance.
Operating System
OS of the target instance. Currently, Linux and Windows are supported.
Select the operating system of the target instance.
Executed By
User who executes the commands.
- For an ECS running on Windows, the preset value is system and the value cannot be changed.
- For an ECS running on Linux, the preset value is root. You can change it as needed.
Execution Plan
Execution plan of the commands. The preset value is Execute Now.
Timeout Interval
Timeout interval for an individual command execution. If the command execution times out, the command submission will be stopped forcibly.
Value range: 6 to 1800 seconds (24 hours)
Unit: second
Command Type
Type of the script commands that can be submitted.
- For an ECS instance running Windows, you can set this parameter to Bat.
- For an ECS instance running Linux, Shell is used by default and Python is also supported.
Command Input
Input box of the commands to be submitted.
The input must be a command that produces a result after a single execution, meaning no further interaction with the command's output is required.
NOTE:After a command is executed, you can enter another command in the command input box and run the command.
Command Output
Output box of the commands. You can view the command execution results.
Table 2 Parameters for selecting an instance Parameter
Example Value
Selection Method
Select an instance selection method.
Manual Selection: Manually select one or more instances based on settings of Enterprise Project, View Type, Resource Type, Region, and Target Instance.
Manual Selection
Enterprise Project
Select an enterprise project from the drop-down list. You can choose All.
All
View Type
Select a view type.
- CloudCMDB resources: Select an instance by resource type.
- CloudCMDB application groups: Select an instance by application group.
CloudCMDB resources
Resource Type
The preset value is used and cannot be changed.
ECS
Region
Select a region from the drop-down list.
CN-Hong Kong
Target Instance
Set filter criteria in the filter box and select the displayed instances manually or automatically.
- Click OK to run the command.
After the command is executed, you can view the command output.
Figure 1 Checking execution results
Helpful Links
You can use the batch command execution function of COC to send commands to multiple ECSs concurrently. Using COC to Batch Execute Commands for Multiple ECSs.
