Managing the Recycle Bin
- The Knowledge Base feature has been enabled for the tenant space, and the operator has the Knowledge Base > Knowledge Management > Recycle Bin menu permission.
 - Delete has been clicked to delete a column or knowledge item. If you click Delete permanently, the deleted column or knowledge item is not moved to the recycle bin.
- Sign in to the AICC as a knowledge compiler and choose .
    Figure 1 Recycle Bin
    You can search for deleted columns and knowledge items by knowledge column name, knowledge column type, deletion start time, and deletion end time.
 - Select multiple columns or knowledge items and click Restore to restore them to the column management page.
 - Select multiple columns or knowledge items and click Delete to delete them permanently.
 - Click Empty Recycle Bin to clear all deleted columns and knowledge items by one click.
     After columns and knowledge items are deleted or the recycle bin is cleared, the columns and knowledge data will be deleted permanently. Exercise caution when performing these operations.
