Manually Making an Outbound Call
The administrator has created a manual outbound call task for a specified agent and started the task.
- Sign in to the AICC as an outbound call agent.
 - Choose .
    Figure 1 Agent outbound call task
     - Click a task to view its details.
 - Click Extract. The outbound call data can be extracted only when the outbound call data is not extracted by other agents and the outbound call task is being executed.
 - Click Number List to view the outbound number list as described in the following table.
Table 1 Elements in the outbound number list Element/Component
Called Number
Outbound number, which is anonymized.
Operation
Currently, the Call button is available.
 - Click Call to send a dial-up request to the customer number.
     An outbound call can be made only when the following conditions are met: The outbound call data is not complete and has been locked, the agent has signed in and is in idle state, and the outbound call task is being executed. If a call fails, it is initiated again until it succeeds or the maximum number of call attempts is reached.
 - After the call ends, view the outbound call result. For details, see Viewing Outbound Call Results.
