Configuring Multimedia Marketing Tasks
- The Intelligent Outbound Call, SMS Marketing, Email Marketing, WhatsApp Marketing, and SmartCare features have been enabled for the tenant space.
 - To use the care task function, you have contacted the system administrator to add the SmartCare interconnection address on the page.
- (Optional) Sign in to the AICC as a tenant administrator, choose , and configure SmartCare integration information. If the care task function is not required, skip this step.
    Figure 1 Configuring SmartCare integration information
    - SmartCare Interconnection Address: Contact Huawei O&M personnel to obtain the address, and contact the system administrator to add the address to the trustlist on the page.
 - AppId: Contact Huawei O&M personnel to obtain the value.
 - AppSecret: Contact Huawei O&M personnel to obtain the value.
 - Certificate: Contact the system administrator to upload the certificate to .
 - Sign in to the AICC as a tenant administrator and choose .
 - View the created multimedia marketing tasks in the list.
    Figure 2 mMarketing
     - Click New. On the Create Multimedia Marketing Task page, configure marketing task information.
    Figure 3 Basic Information
    Figure 4 Marketing Policy
    Task Type: The options are Marketing and Care. In a care task, an agent needs to call a customer back who intends to make a complaint to pacify the customer and improve customer satisfaction. The SmartCare feature must be enabled for care tasks. Care task data is imported through scheduled tasks in the background. A tenant space can publish only one voice scenario–based care task and one data scenario–based care task.
The supported media types of multimedia tasks are as follows:
- SMS: Marketing campaigns are carried out by SMS message. The notification template can be a Huawei Cloud SMS message template or SMS gateway message template.
- For details about how to configure a marketing notification template, see Configuring Notification Templates as an Administrator.
 - To use an SMS gateway message template, you need to configure a gateway. For details about how to configure a gateway, see Configuring SMS Gateways.
 - By default, the country codes of China and Brazil are available. To add a country code, configure the dictionary value.
The configuration method is as follows:
DELETE FROM SYS_DATADICT_ITEM WHERE rel_id = '88001202102081808'; INSERT INTO SYS_DATADICT_ITEM (rel_id, dict_code, item_code, item_name, be_code, order_no, description, oper_id, oper_time, oper_org_id, ext1, ext2, ext3, ext4, ext5, be_id) VALUES ('88001202102081808', 'CCN.COUNTRY_CODE', '+55', 'Brazil', '101', '2', null, '101', null, '101', null, null, null, null, null, null) DELETE FROM SYS_DATADICT_ITEM_LANG WHERE rel_id = '8800120210208180801'; INSERT INTO SYS_DATADICT_ITEM_LANG (rel_id, item_rel_id, locale, item_name, be_id) VALUES ('8800120210208180801', '88001202102081808', 'en_US', 'Brazil', null); DELETE FROM SYS_DATADICT_ITEM_LANG WHERE rel_id = '8800120210208180802'; INSERT INTO SYS_DATADICT_ITEM_LANG (rel_id, item_rel_id, locale, item_name, be_id) VALUES ('8800120210208180802', '88001202102081808', 'en_US', 'Brazil', null);
In the preceding information, 88001202102081808 is the customized dictionary value ID. 8800120210208180801 and 8800120210208180801 are the customized dictionary internationalization IDs. Brazil, +55, and 2 are the customized country name, country code, and sequence number, respectively.
After the configuration, restart the SUMApp for the configuration to take effect.
 - Email: Marketing activities are carried out by email.
 - For details about how to configure a gateway, see Configuring SMS Gateways.
 - WhatsApp
- For details about how to configure the WhatsApp channel, see Configuring the WhatsApp Channel.
 - For details about how to configure a WhatsApp template message, see Managing the Multimedia Library.
 - Click Save. The multimedia marketing task is created successfully.
 - Return to the mMarketing tab page and click Import Data to import data.
 - Return to the mMarketing tab page and click Publish to publish the marketing task.
 - Click
 to export multimedia marketing tasks. A maximum of 100,000 records can be exported.
Follow-up Procedure
To modify a multimedia marketing task, click Suspend to suspend it.
After the task is suspended, you can perform the following operations:
- Click Edit to modify the multimedia marketing task.
 - Click Delete to delete the multimedia marketing task.
 - Click Import Data to import data.
 - Click View Marketing Result to view the execution result of the multimedia marketing task.
