- Getting Started
User Guide
- CEC Operation Guide
Tenant Administrator Guide
- Tenant Space
- Configuring the Employee Center
Enabling Manual Services
- Voice and Video Services
Agent Workbench
- Configuring Call Reasons
- Configuring Rest Reasons
- Configuring Contact Record Data Items
- Configuring the Voice Notification Function
- Configuring the One-Click Bidirectional Call Function
- Configuring Screen Pop-ups
- Configuring Pages
- Configuring Dynamic Data Tables
- Querying Table Data
- Managing the Multimedia Library
- Configuring Identity Authentication Processes
Other Configurations
- Configuring the Fault Prompt Tone
- Configuring Satisfaction Surveys
- Configuring the Customized Tone (Agent Ringback Tone)
- Configuring Page Message Notifications
- Configuring Voice Silent Agents
- Managing Messages
- Viewing Contact Records
- Viewing Bidirectional Call Records
- Configuring the Online Chat Service Time
- Viewing Skill Queue Adjustment Records
- Viewing Identity Authentication Records
- Managing Documents
- Managing Harassment Records
- Configuring Service Guidance
- Configuring SmartCare Integration Information
- Configuring a Mobile Agent
Configuring Multimedia Channels
- Configuring the WeChat Channel
- Configuring the Web Channel
- Configuring the X (Twitter) Channel
- Configuring AICC Information
- Configuring the 5G RCS Channel
- Configuring the Email Channel
- Configuring the LINE Channel
- Configuring the WhatsApp Channel
- Configuring the SMS Channel
- Configuring the Instagram Channel
- Configuring the Telegram Channel
FAQ
- How Do I Set the Click-to-Dial Called Route?
- How Do I Enable the Last Agent Mode?
- How Do I Set Session End Due to No Customer Reply?
- How Do I Set Session Transfer Due to No Agent Reply?
- How Do I Set Session Transfer?
- How Do I Set the Third-Party Authentication Key?
- How Do I Enable Offline Messages?
- How Do I Enable Message Push?
- How Do I Enable the Auto Reply and Non-Workday Reply Functions?
- How Do I Enable Connection to the Intelligent Robot?
- How Do I Enable Connection to the Robot Assistant?
- Creating an App Using a Facebook Developer Account
- How Do I Set Automatic Email Reply?
Robot Management and Configuration Guide
- Getting Started
Configuring an Intelligent Robot
- Overview
- Configuring an Appointment Chatbot (Task-oriented Robot)
- Adding a Q&A-oriented Robot
Other Operations
- Managing Variables
- Maintaining Stored Procedures
- Creating Work Calendar Templates
- Adding Data Tables
- Adding Domains
- Adding Entities
- Adding Sensitive Words
- Adding Knowledge Gray Rules
- Managing Models
- Managing Robot Test Cases
- Reviewing a Historical Message
- Processing a Question Clustering Task
- Setting Intelligent Engine Parameters
- Managing the Call History
- Viewing Flow Analysis
- Checking Flows
- Adding Gray Rules
- Configuring 2D Virtual Humans
- Configuring the SmartCare Intelligent Robot
Reference
Diagram Elements
- Start
- Robot Reply
- Conversation Analysis
- Subflow
- Call Ending
- Switching Between Voice and Video Calls
- Voice Playback
- Voice Playback and Digit Collection
- Language Selection
- Semantic Recognition
- Menu Configuration
- Call Transfer
- Error Count Clearance
- Branch Judgment
- Logic Loop
- Variable Assignment
- Rule Validation V2
- Time Selection
- Interface Invocation
- Data Table
- Stored Procedure
- Information Query
- User Level
- Message Leaving
- SMS
- Satisfaction Configuration
- Key Recognition (Expired and Not Recommended)
- Rule Verification (Expired and Not Recommended)
- Date Processing (Expired and Not Recommended)
- SMS Sending (Expired and Not Recommended)
- JSON Data Invoking (Expired and Not Recommended)
- Composite
- Avatar Reply
- Connection Lines Between Diagram Elements
- Parameters
TUC Interfaces
- /chatbot/rest/tuc/v1/nlp/detectRegularEntity
- /chatbot/rest/tuc/v1/nlp/identify
- /chatbot/rest/tuc/v1/recommendFaq
- /chatbot/rest/tuc/v1/qualityInspection/qiOnline/recognize
- /chatbot/rest/tuc/v1/nlp/feedback
- /chatbot/rest/tuc/v1/nlp/textClassify
- /chatbot/rest/tuc/v1/nlp/detectEntity
- Built-in Functions
Diagram Elements
- Why Do I Need to Configure Stop Words?
- Why Are Some Intentions Matched Despite Low Matching Rates?
- Why TTS Cannot Identify the Date Format?
- How Do I Configure the Scenario Where Multiple Slots Are Filled Repeatedly?
- How Do I Resolve the Problem of Infinite Loop During Interaction Between the IVR and ODFS?
- How Do I Configure the Number of Voice Recognition Errors in a Flow?
- How Do I Configure an Entity That Matches Any Character String?
- What Causes Incorrect ASR?
- How Do I Transfer the Disconnection Reason Code to the Specified Business Interface?
- How Do I Configure the Language Recognition Interface?
- How Do I Configure Dynamic Flow Variables?
- How Do I Use a Rule Corpus?
- How Do I Assign Values to and Use Lists and Objects?
- How Do I Parse Call-associated Data?
- How Do I Press a Key to Collect Digits or Return to the Upper-Level Menu When the Play Voice & Collect Digit Diagram Element Does Not Support the Asterisk (*) Key?
Operator: Configuring a Common IVR
- Introduction to the IVR Flow
- Managing Voice and Video Resources
- Configuring a Common IVR
- Configuring Robot Tracking
- Configuring a Called Route
- Configuring a Flow Track
- Configuring IVR Recording
- Querying Flow Transfer Records
- Typical Configuration Example
Diagram Elements
- Start
- Subflow
- Call Ending
- Voice Playback
- Call Transfer
- Branch Judgment
- Logic Loop
- Data Table
- Stored Procedure
- Time Selection
- Information Query
- User Level
- Message Leaving
- SMS
- Survey
- Call Ending (Expired and Not Recommended)
- Condition Judgment (Expired and Not Recommended)
- Ringing (Expired and Not Recommended)
- Response (Expired and Not Recommended)
- User Level (Expired and Not Recommended)
- Time Selection (Expired and Not Recommended)
- Assignment (Expired and Not Recommended)
- Transfer (Expired and Not Recommended)
- Interface Invocation (Expired and Not Recommended)
- Configuring the Preconfiguration Intelligent Flows
- Large Language Model Service Zone
- Small Language Model Zone
- IVR Journey Analysis
- Monitoring Outbound Call Risks
- Managing Cases
Managing Inspections
- Overview on Inspection Management
- Typical Scenario: Configuring Manual Inspection Tasks
- Managing Manual Inspections
- Typical Scenario: Configuring AI Inspection Tasks
- Managing AI Inspections (Self-Developed)
- Managing the Notification Center
- Managing the Customer Center
Making Intelligent Outbound Calls
- Overview of Outbound Call Tasks
Preparations for Creating Outbound Call Tasks
- Managing Special Dates
- Managing Blocklisted Outbound Numbers
- Defining Business Results
- Defining Outbound Call Data Attributes
- Defining Outbound Call Results
- Creating Outbound Call Templates
- Managing the Special List
- Configuring an Outbound Call File Server
- Importing Mapping Rules
- Managing Task Groups
Managing Outbound Call Tasks
- Creating Common IVR Outbound Call Tasks or Intelligent Robot Outbound Call Tasks
- Creating Predicted Outbound Call Tasks
- Creating Previewed Outbound Call Tasks
- Creating Preempted Outbound Call Tasks
- Creating Fixed Outbound Call Tasks
- Creating Manual Outbound Call Tasks
- Configuring an Outbound Call Task
- Managing Outbound Call Tasks in Batches
- Managing Multimedia Marketing
- Managing Outbound Call Task Reports
- Managing Surveys
- Managing Intelligent Training
- Configuring the Knowledge Base
Configuring Public Resources
- Modifying Policy Information
- Viewing Interconnection Parameters
- Configuring Parameters
- Adding Customer Numbers to the Special List
- Configuring the Channel Special List
- Managing a Certificate
- Configuring Email Special List Rules
- Configuring SMS Special List Rules
- Configuring Resource Dump Tasks
- Managing Menus
- Managing Email Signatures
- Configuring Message Flow Control Rules
- Configuring UC Integration
- Managing Emails
- Configuring External Numbers
- Querying Operation Logs
- Querying Sign-in Logs
- Managing Business Fault Bypass
- Co-browsing
- Social Media Operations
- Performance Management
Agent Guide(AICC)
- Introducing Agent Workbenches
- Switching the Agent Status
- Allowing Browser Pop-up Notifications
- Handling Voice Businesses
- Handling Video Businesses
- Handling Multimedia Chat Businesses
Performing Other Agent Operations
- Configuring the Personal Center
- Querying Historical Contacts
- Viewing Inbound Call Information
- Setting the Handled Number
- Setting Call Reasons
- Setting the Online Chat Service Time
- Configuring Personalized Common Phrases
- Sending Notifications
- Performing Identity Authentication
- Viewing Customer Information
- Creating Harassment Records
- Editing Customer Information
- Querying Sign-In Records
- Performing Screen Recording for Agents
- SmartCare Fault Demarcation
- Intelligent Case Filling
- Creating a Case by One Click
- Searching for Satisfaction Statistics
- Managing Inspection Results
- Typical Scenarios
- Viewing Training Tasks
Intelligent Outbound Call Tasks
Agent Outbound Call Task
- Introduction to the Outbound Call Task of an Agent
- Manually Making an Outbound Call
- Viewing and Executing a Previewed Outbound Call
- Viewing a Predicted Outbound Call
- Viewing a Preempted Outbound Call
- Creating a Reserved Outbound Call Task
- Adding a Customer Number to the Blocklist
- Changing an Outbound Number
- Viewing Outbound Call Results
- Reserved Manual or Automatic Outbound Call
- OpenEye Help Document
- Implementing Intelligent Case Filling
Inspector Guide
- Processing Manual Post-Event Inspections
- AI Inspection
Performing Agent Monitoring and Inspections
- Monitoring Configuration
- Monitoring Management
Report Query
- VDN Traffic Report
- VDN Traffic Report by Access Code
- IVR Traffic Report
- IVR Traffic Report by Access Code
- Skill Queue Traffic Report
- Skill Queue Traffic Report by Access Code
- Traffic Summary Report
- Agent Traffic Report
- Agent Outbound Call Report
- Agent Operation Report
- Abandoned Call in Ringing Report
- Interval-based VDN Traffic Report
- IVR Outbound Call Report
- System Performance Report
- Agent Timesheet Report
- Price Details
Developer Guide
Development Overview
- Development Map
Development Solutions
- Multimedia Channel Access Solution
- Self-Service (IVR) Integration Solution
- Voice and Video Agent Integration Solution
- Multimedia Agent Integration Solution
- Mobile Agent Integration Solution
- Screen Pop-up Integration Solution
- Intelligence Solution
- Operations Monitoring and Report Integration Solution
- Automatic Outbound Call Integration Solution
- CDR Download and Recording Backhaul Integration Solution
- Development Preparations
- Contact Us
- User Access-VoIP Voice and Video Access
User Access-Web Lightweight Client Integration (JS)
- Lightweight Web Chat Control Integration (Token Mode)
- Lightweight Web Chat Control Integration (Authorization Mode)
User Access--Web Client Access (RESTful)
- Overview
- Machine-Machine Interface, AK/SK-based Authentication Interface
- Third-party Request Authentication
- Query Queue Information
- Proactively Poll Information Sent by Agents
- Submit Customer Satisfaction Evaluation Results
- Send Message
- Send Files by Customer
- Receive Document by Customer
- Associate Common Phrases
- Create Click-to-dial Call
- Get Click-to-dial Event
- Check Whether Support Click-to-dial
- Release Click-to-dial Call
- Submit Offline Messages by Customer
- Create an Anonymous Call
- Submit Customer Satisfaction with Robots
Agent Integration-Agent Lightweight Connection Block Integration (JS)
- Overview
- Integration Principles
- Integration Procedure
- Preparations
- Integration Development
- (Optional) Developing Other Functions
- Test and Verification
- Agent Integration--CC-Gateway Development Guide
Agent Integration-OpenEye H5 Softphone Interface Integration
- Change History
- OpenEye H5 Softphone Interface Overview
- OpenEye Installation Guide
- Development Guide to H5 Softphone Integration on the Agent Side
- Voice Call Interfaces
Voice and Video Call Interface Extension
- Voice and Video Calls
Device Management
- getMediaDevices (Obtaining the Device List)
- setMicIndex (Setting the Microphone)
- mediaGetMicIndex (Querying the Microphone in Use)
- setSpeakIndex (Setting the Speaker)
- mediaGetSpeakIndex (Querying the Speaker in Use)
- setMicVol (Setting the Microphone Volume)
- getMicVol (Querying the Current Microphone Volume)
- setSpkVol (Setting the Speaker Volume)
- getSpkVol (Querying the Current Speaker Volume)
- setVideoWindowParam (Setting the Position, Width, and Height of the Video Window)
- setVideoLayoutMode (Setting the Video Window Layout Mode)
- setVideoDisplayMode (Setting the Image Cropping Mode in the Video Window)
- openCamera (Turning on the Camera)
- closeCamera (Turning off the Camera)
- Screen Sharing
- Screenshot
- Screen Recording
- Error Codes
Operation Management - Agent Workbench Integration with Third-Party Web Pages
- Overview
- Scenario 1: Integration by Using a URL (in GET Parameter Transfer Mode)
- Scenario 2: Integration by Using a URL (in POST Parameter Transfer Mode)
Scenario 3: Integration by Using a URL (in Page JavaScript Invocation Mode)
- Overview
- Development Procedure
- Preparation
- Importing AICC.Support.js
- Developing the Function of Registering Listening Events
- Developing the Function of Removing Listening Events
- Developing the Function of Making One-Click Outbound Calls
- Developing the Function of Obtaining the Identity Authentication Result
- Development Example
- Post-development Configuration
Appendix - Process Description
- Overall Working Process
- Process of Registering a Listening Event (addHandler)
- Process of Removing a Listening Event (removeHandler)
- Process of Executing a One-Click Outbound Call (clickToOutbound)
- Process of Executing the Handling Method of a Registered Event
- Process of Executing the One-Click Outbound Call Method
- Process of Obtaining the Identity Authentication Result
- Scenario 4: Integration by Invoking an Enterprise API
- Scenario 5: Integration by Recording Information to the CEC
API Reference
- Interface Overview
- Glossary
- Change History
- Interface Authentication Modes
Call Center Configuration Interface Reference
Agent Management
- Creating a Single Agent Account (agentAccount/create)
- Deleting a Specified Agent Account (agentAccount/delete)
- Modifying Information About an Agent Account (agentAccount/update)
- Querying Agent Account Information (agentAccount/query)
- Binding an Agent to a Skill Queue (addSkillsToAgent)
- Unbinding an Agent from a Skill Queue (releaseAgentBySkillId)
- Querying Agent Information by Skill Queue ID (queryAgentInfoBySkillId)
- Changing the SIP Phone Number Login Password of an Agent (updateSipPhonePassword)
- Querying Softphone Information of All Agents, Excluding Business Accounts (querySysInfo)
- Querying Softphone Information of All Agents, Including Business Accounts (queryAgentInfo)
- Querying the Account Sign-in Result (queryAgentLoginParams)
- Querying Agent Information by Sign-in Account (queryAgentInfoByAccount)
- Deleting Data by Customer Number (cleancustpersonaldata)
Skill Queue Management
- Creating a Skill Queue (createSkill)
- Deleting a Skill Queue (deleteSkill)
- Modifying a Skill Queue (modifySkill)
- Querying Skill Queues (querySkills)
- Obtaining the Total Number of Users in a Configured Skill Queue
- Obtaining the Number of Users in a Skill Queue to Which an Agent Has Signed In
- Obtaining the Skill Queue Information of the Home VDN of an Agent
- Obtaining the Total Number of Users in a Specified Skill Queue
- Querying the Statistics About a Set of Skill Queues
- Querying the IVR Information of the VDN to Which an Agent Belongs
- Querying Information About Agents That Have Signed In to a Skill Queue
- Querying the Details About a Specified Agent
- Querying the Details About All Online Agents That Have Signed In to a Skill Queue
Number Management
- Querying Access Codes (queryAccessCodeList)
- Creating a Binding Relationship Between an Access Code, Skill Queue, and IVR (createCalledRoute)
- Deleting the Binding Relationships Between Access Codes, Skill Queues, and IVR Flows (deleteCalledRoute)
- Modifying a Binding Relationship Between an Access Code, Skill Queue, and IVR (modifyCalledRoute)
- Querying the Binding Relationships Between Access Codes, Skill Queues, and IVR Flows (queryCalledRoute)
- Querying the Home Area of a Number (getPhoneNoRegionInfo)
IVR Flow Management
- Querying All IVR Flows of a Specified Tenant Space (queryIVRFlowList)
- Querying Satisfaction Survey Information (querySatisfactionConfig)
- Querying Satisfaction Survey Results (satisfaction /query)
- Uploading IVR Voice Files (importVoiceFile/upload)
- Uploading a TTS Template for Voice Notifications (createVoiceTemplate)
Agent Management
Agent Workbench Interface Reference
Agent Control
Agent Operation Interfaces: onlineagent
- Signing In
- Forcibly Signing In
- Maintaining the Heartbeat by an Agent
- Sending Notes
- Querying Configured Skill Queues
- Querying Configured Skill Queues of Specified Agents
- Setting Automatic Answering
- Resetting Skill Queues
- Setting Idle
- Setting Busy
- Canceling the Busy State
- Applying for Rest
- Canceling Rest
- Entering the Work State
- Quitting the Work State
- Changing the Password (Extended)
- Setting Whether to Enter the Idle State
- Signing Out
- Forcibly Signing Out
- Forcibly Signing Out with a Cause Code
- Getting Agent Status
- Setting Whether to Answer Inbound Calls
- Signing In to the Platform by an Agent
- Actively Requesting to Update the GUID When the Agent Page Is Refreshed
- Synchronizing the Agent Status and Call Information When the Agent Page Is Refreshed
- Obtaining Token Information
- Customizing Status by an Agent
- Querying Customized Status by an Agent
- Canceling Status Customization by an Agent
Call Control Interfaces: voicecall
- Making a Common Outbound Call
- Making a Previewed Outbound Call
- Answering a Call
- Making an Internal Call
- Asking for Internal Help
- Muting a Call
- Unmuting a Muted Call
- Holding a Call
- Holding a Call
- Unholding a Call
- Transferring a Call
- Canceling Transfer
- Performing Two-Stage Dialing (Extended)
- Making a Three-Party Call
- Disconnecting a Call of a Specified ID
- Dropping a Call
- Releasing a Connection of a Specified Number
- Controlling the Image Display Mode of a Three-Party Video Call
- Requesting a Specified Call
- Picking Up a Call for Other Agents
- Rejecting an Inbound Call
- Taking the Phone Off the Hook
- Rejecting a Call
- Passing Numbers in a Conference
- Answering Calls on a Mobile Phone (login)
- Exiting the Function of Answering Calls on a Mobile Phone (logout)
- Querying Whether a Specified Agent Answers Calls on a Mobile Phone (isOfflineAgent)
Call Data (calldata)
- Querying Call Information
- Querying Call-Associated Data
- Configuring Call-Associated Data (Extended)
- Querying the List of Held Calls
- Querying Call Information Before Answering a Call
- Querying Call Information by Call ID
- Querying Call IDs of a Specified Agent
- Querying the Number of Current Calls of an Agent
- Querying Current Call Statistics Information About an Agent
- Querying the Current Call Statistics of an Agent (Extended)
- Querying Information About Calls Waiting in a Specified Skill Queue
- Querying All Calls Placed on Hold by a Specified Agent
- Agent Event: agentevent
- Multimedia: mediaCall
Agent Conference: agentconf
- Applying for an Agent Conference
- Answering an Agent Conference Call
- Rejecting an Agent Conference Call
- Leaving an Agent Conference
- Releasing an Agent Conference
- Holding a Participant in a Conference
- Unholding a Participant in a Conference
- Applying for Extending a Conference
- Transferring the Chairperson Permission
- Inviting Participants in Batches
- Deleting Participants in Batches
- Modifying Participant Attributes
- Playing an Announcement in an Agent Conference
- Stopping Conference Announcement Playing
- Playing an Announcement in an Agent Conference Channel
- Stopping Announcement Playing in an Agent Conference Channel
- Changing the Number of Conference Participants
- Querying Conference Information in Batches
- Querying an Ongoing Conference ID in the VDN
Agent Bidirectional Calls
- Creating a Bidirectional Call (V1.0.0) (createCall)
- Creating a Bidirectional Call (V3.0.0) (createCall)
- Querying Call History Records (queryCallDetailRecord)
- Querying Call Status (queryCallState)
- Obtaining the Recording File URL (getRecordingAddress)
- Querying Allocated Softphone Numbers (V1.0.0) (queryPhone)
- Querying Allocated Softphone Numbers (V2.0.0) (queryPhone)
- Obtaining the Information About the Destination Device of a Call (getCalledInfo)
- Creating a Voice Outbound Call (V1.0.0) (createVoiceNotification)
- Creating a Voice Outbound Call (V2.0.0) (createVoiceNotification)
- Querying Contact Records (queryUserContactLimit)
- Querying Call Information (queryCallInfoByCallId)
- Sending an ITA Bidirectional Call Result Notification (statusnotify)
- Callback Interface
Voice Recognition Result Subscription Interfaces
- Subscription
- Subscription Modification
- Unsubscription
- Handshake
- Handshake (Extended)
- Recognition Result Notification
Error Code Definition
- Error Codes Returned by the CC-Gateway
- Common Voice Recognition Result Subscription Interface Error Codes
- Common Error Codes Returned by the CTI Platform
- VDN Configuration Interface Error Codes Returned by the CTI Platform
- System Configuration Interface Error Codes Returned by the CTI Platform
- Error Code Returned by UAP
- Role Permission Bit Description
- App Personal Settings
Appendix
Events
- Events Related to Agent State
Audio and Video Call Event
- Entering the Talking State
- Customer Ringing
- Holding Success
- Entering Three-Party Conversation Successfully
- Making an Outgoing Call Unsuccessfully
- Outbound Call Failure Cause Detected
- Making an Internal Call Unsuccessfully
- No Answer from an Agent for a Long Time
- Agent Exiting a Call
- User Exiting a Call
- Automatically Answering a Call
- Notifying the Agent of an Inbound Call
- Connection Failure
- Consultation Failure
- Notifying the Transfer Success Result
- Returning from IVR
- Switching Between Audio and Video Calls
- Media Capability Check
- Inbound Call Notification
- Events Related to Outgoing Call
- Recording Events
- Events Related to Voice Playback by Quality Checks
- Events Related to Real-time Quality Control
- Events Related to Physical Phone
- Other Agent-Related Events
- Events Related to Multimedia
- Agent Conference Event
- Events Related to Disaster Recovery
- Phone Linkage Events
- Error Codes
- Agent Status
- Call Type
- Device Type
- Interface Parameters
Events
Agent Control
Telemarketing Outbound Call Interface Reference
Outbound Campaign Management Interfaces
- Adding an Outbound Campaign (V1)
- Adding an Outbound Campaign (V2)
- Modifying an Outbound Campaign (V1)
- Modifying an Outbound Campaign (V2)
- Deleting an Outbound Campaign
- Querying Details About an Outbound Campaign
- Querying All Outbound Campaigns
- Suspending an Outbound Campaign
- Resuming an Outbound Campaign
- Setting the Retry Policy of an Outbound Campaign
- Querying the Retry Policy of an Outbound Campaign
- Adding the Definition of an Outbound Call Business Result
- Querying the Definitions of Outbound Call Business Results
- Collecting Outbound Call Exception Statistics
- Adding Calling Numbers
- Deleting Calling Numbers
- Interfaces for Managing Outbound Campaign Holidays
- Interface for Outbound Blacklist Management
Outbound Call Data Interfaces
- Adding Outbound Numbers
- Adding Outbound Numbers (V2)
- Deleting an Outbound Number
- Adding Number Types
- Querying Number Types
- Querying Outbound Numbers
- Collecting Outbound Call Statistics on the Current Day
- Importing an Outbound Call Data File from the Server
- Querying Outbound Call Data File Import Results
- Outbound Result Interface
- Outbound Callback
- Business Result Writeback
- File Server Management Interfaces
- Outbound Call External Result Definition Interfaces
- Querying Interface Invocation Records
- Survey Interface Reference
- iKBS Interface Reference
Chatbot Management Interface Reference
- Overview
- Domain Query Interface
- Dialog ID Binding Interfaces
- Flow Query Interface
- Dialog Interfaces
- Dialog Interfaces (V2)
- Interaction Record Query Interface
- Session Record Query Interface
FAQ Configuration Interface
- FAQ Group Query Interface
- FAQ Group Creation Interface
- FAQ Group Modification Interface
- FAQ Group Deletion Interface
- FAQ Group Status Change Interface
- Q&A Query Interface
- Q&A Creation Interface
- FAQ Modification Interface
- Q&A Deletion Interface
- Specific FAQ Group Test Interface
- FAQ Group Test and Activation Interface
- Intention List Query Interface
- Dedicated Interfaces for Silent Agents
- Interface for Pushing Packet Capture Recording Request Results
- Spelling Check Interface
- Specifications of the Interface for Connecting the ODFS to a Third-Party Robot System
- Statistics Report
- Querying the Offline Analysis of Outbound Call Failure Causes
- Intelligent Case Interface
- Interface for Querying the Recordings of Calls Transferred to a Third Party
- Semantic Recognition Interface
- GTS RPA Integration Interfaces
- Interface for Generating TTS Voices Based on Texts
- Offline Conversion Callback Interface
- Health Check Interface
Web Client Access Interface Reference
- Performing Third-Party Request Authentication (applyToken)
- Querying Queuing Information (queryQueueInfo)
- Proactively Polling Messages Sent by Agents (poll)
- Submitting the Customer Satisfaction Evaluation Result (saveSatisfaction)
- Sending a Message (send)
- Sending a File by a Customer (uploadFileStream)
- Receiving a File by a Customer (downloadFileStream)
- Associating Common Phrases Based on the Customer Input (queryPhraseByKeyword)
- Checking Whether the Current Tenant Space Supports the Click-to-dial Function (checkClickToCallSupport)
- Creating a Click-to-Dial Call (createClickToCall)
- Obtaining a Click-to-Dial Event (getClickToCallEvents)
- Releasing a Click-to-Dial Call (dropClickToCall)
- Creating an Anonymous Call (createcall)
- Submitting a Message by a Customer (doLeaveMessage)
- Submitting the Chatbot Satisfaction Evaluation Result (feedbacksatisfaction)
- Querying Historical Messages (queryHistoryChatMessage)
- Discarding an Email (chat_dropMail)
- Sending an MT WhatsApp Message (sendWhatsappMessage)
- Querying Information About the Current Chat on the Online Chat Workbench (getUserInfoBycallId)
- Querying the Satisfaction Survey Configuration (getSatisfactionSurveyMode)
Inspection, Monitoring, and Statistics Collection Interface Reference
Real-time Inspection: qualitycontrol
- Inserting
- Listening
- Intercepting
- Canceling Listening and Inserting
- Indicating an Agent in Busy State Forcibly
- Indicating an Agent in Idle State Forcibly
- Releasing a Call Forcibly
- Adjusting the Skill Queue of a Specified Agent
- Switching Between Listening and Inserting
- Forcing an Agent to Rest
- Requesting for Whispering
- Stopping Whispering
- Switching Among Whispering, Listening, and Barging
Intelligent Quality Check
scoresetting
- POST /CCSQM/rest/ccisqm/v1/appraisescore/createAppraiseScore
- POST /CCSQM/rest/ccisqm/v1/appraisescore/applyAppraiseScore
- POST /CCSQM/rest/ccisqm/v1/appraisescore/removeAppraiseScore
- POST /CCSQM/rest/ccisqm/v1/appraisescore/queryAppraiseScore
- POST /CCSQM/rest/ccisqm/v1/appraisescore/modifyAppraiseScore
sentencemanagement
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/createSentenceCategory
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/moveSentenceToCategory
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/deleteSentence
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/querySentence
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/querySentenceByCategoryId
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/updateSentence
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/updateSentenceCategory
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/deleteSentenceCategory
- POST /CCSQM/rest/ccisqm/v1/sentencemanage/querySentenceCategory
sensitiveWordManage
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/deleteSensitiveWord
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/querySensitiveWordList
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/deleteSensitiveCategory
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/updateSensitiveWord
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/querySensitiveCategoryList
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/querySensitiveWordsByCategoryId
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/createSensitiveCategory
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/moveSensitiveWordToCategory
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/createSensitiveWord
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/updateSensitiveCategory
- POST /CCSQM/rest/ccisqm/v1/sensitiveWordManage/querySensitiveWordDetail
- conversationspecific
- SemanticKeywordTraining
- conversationflow
- conversationrules
interposalrules
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/getInterposalRuleById
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/queryInterposalRules
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/deleteInterposalRule
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/addInterposalRule
- POST /CCSQM/rest/ccisqm/v1/interposal-rules/updateInterposalRule
- Common Parameter Structure
- silencerule
- speedrule
scenariomanage
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/deleteScenario
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/updateScenarioStatus
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/createScenario
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/queryScenario
- POST /CCSQM/rest/ccisqm/v1/scenariomanage/queryAllScenario
- qualitycheckmanage
regularQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/addQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/beginQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/updateQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/deleteQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/queryQualityTask
- POST /CCSQM/rest/ccisqm/v1/regularqualitytask/stopQualityTask
qualitytask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/deleteQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/updateQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/terminateQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/takeEffectQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/queryQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/appointQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualitytask/createQualityTask
- qualitytaskdetail
qualityitem
- POST /CCSQM/rest/ccisqm/v1/qualityitem/reassginQualityTask
- POST /CCSQM/rest/ccisqm/v1/qualityitem/modifyQualityItemResult
- POST /CCSQM/rest/ccisqm/v1/qualityitem/appealItem
- POST /CCSQM/rest/ccisqm/v1/qualityitem/queryQualityItem
- POST /CCSQM/rest/ccisqm/v1/qualityitem/queryQualityItemDetail
- POST /CCSQM/rest/ccisqm/v1/qualityitem/queryQualityItemResult
- POST /CCSQM/rest/ccisqm/v1/qualityitem/queryQualityHistory
- asrtrans
scoresetting
Monitoring and Statistics Collection
Real-Time Data Query
Real-Time Interfaces for VDNs
- Querying Information About System Access Codes in a Specified VDN
- Querying Agent Rest Information in a Specified VDN
- Querying Agent Phone Numbers in a Specified VDN
- Querying Information About All Agents in a Specified VDN
- Querying Information About the Current Status of All Agents in a Specified VDN
- Querying Information About Static Configurations of All Agents in a Specified VDN
- Querying IVR Status Details in a Specified VDN
- Querying Information About IVR Flow Access Codes in a Specified VDN
- Querying Information about Each Skill Queue in a Specified VDN
- Querying All Rest Reason Codes in a Specific VDN
- Querying Information About Calls of a Specified Access Code
- Querying Call Information in a Specified VDN
- (V2) Querying Call Information in a Specified VDN
- Querying the Call track Data in a Specific VDN
- Querying Static Configuration Information About All Agents in a Specified VDN (Not Supported by CTI 3.6)
- Querying Information About All Agents in a Specified VDN (Not Supported by CTI 3.6)
- Obtaining Real-Time Monitoring Indicators by VDN
Real-Time Interfaces for Skill Queues
- Querying Signed-in Agents in Skill Queues in Batches
- Querying Extended Information About Skill Queues in Batches
- Querying Call Statistics of Skill Queues in the Current 5 Minutes in Batches
- Querying Information About Status of a Specified Skill Queue
- Querying Information About Skill Queue Configurations in Batches
- Querying Statistics Details of Skill Queues in Batches
- Querying All Calls Queuing in a Skill Queue in Batches
- Querying the Number of Calls that Each Queue Answers from Other Queues in Batches When Calls are Queuing in Multiple Skill Queues
- Querying the Number of Agents in Each State in a Skill Group
- Querying Details About Signed-in Agents in a Skill Queue
- Querying Service Quality for Skill Queues in Batches
- Obtaining Real-Time Monitoring Indicators by Skill Queue
Real-Time Interfaces for Agents
- Querying Skill Queues to Which Agents Sign In in Batches
- Querying Agent Information in Batches
- Querying the Current Call ID of a Specified Agent
- Querying Call Information About All Agents in Batches
- Querying Private Calls of a Specified Agent
- Querying the Number of Agents in the Agent State in batches
- Querying Details of a Specified Agent
- Checking Whether an Agent Is Processing a Call
- Querying System Status by Agent
- Obtaining Real-Time Monitoring Indicators by Agent
- Obtaining Agent Operation Details
- Querying Agent Information by Agent Status in Pagination Mode
- Real-Time Interfaces for Call Details
Historical Data Query
- Obtaining Historical Monitoring Indicators by VDN
- Querying Information About Missed Calls in a Specified VDN
- Obtaining Historical IVR Monitoring Indicators
- Obtaining Historical Monitoring Indicators by Skill
- Obtaining Historical Monitoring Indicators by Agent
- Obtaining Historical Monitoring Indicators in a Specified Time Range by Skill
- Obtaining Historical Monitoring Indicators in a Specified Month Range by Skill
- Obtaining Historical Monitoring Indicators in a Specified Time Range by Agent
- Obtaining Historical Monitoring Indicators in Specified Month by Agent
- Collecting Statistics on Result Sets in Daily Settlement Table for Inbound Calls
- Collecting Statistics on Result Sets in Daily Settlement Table for Outbound Calls
Configuration Data Query
- Querying Information about All VDNs in a Specified Call Center
- Querying Information About All Agents by VDN ID
- Obtaining All Called Routes in a VDN
- Querying Information About All Agents by Tenant Space ID
- Querying Skill Groups in a Specified VDN
- Querying Information About All Tenants Accessible to an Access User
Inspection Relationship Maintenance Interfaces
- Querying a User Group Member
- Deleting Members from a Group in Batches
- Adding Members to a Group in Batches
- Querying All User Groups
- Adding a User Group
- Deleting a User Group
- Updating User Group Information
- Setting Inspection Relationships
- Deleting Configured Inspection Relationships
- Adding an Agent to a User Group
- Updating Agent Names
- Querying Outbound Call Task Lists
Interfaces for Querying System Indicators
- Querying UAP Performance Information
- Querying Key Information About Control Blocks
- Querying the Registration Status of a Terminal
- Interface for Querying UAP Performance Indicator Statistics
- Interface for Querying UAP Terminal Statistics
- Interface for Querying CTI System Indicators
- Querying the Time of the CTI Platform Server
- Querying the Current License Usage in the System
- Checking Cluster Health Status
Appendix
- Indicator Code Reference
- Error Code Reference
- CTI Platform Agent Status Code Reference
- Description of Call Media Types
- Description of Call Submedia Types
- Description of Call Types
- Description of Agent Types
- Call Features
- Reasons for Leaving the Device of the Call
- Cause Code
- Device Types
- Agent Operation Types
- Interfaces of Earlier Versions (Versions Earlier Than 8.13.0)
Recording and CDR Interface Reference
- Recording
CDR Download and Recording Playback and Download
Data Access Interface
- Obtaining a Recording Download and Playback URL
- Generating CDRs and Recording Indexes
- Downloading CDRs and Recording Indexes
- Downloading a Recording File
- Downloading a Recording File (Extended)
- Generating Indexes of Agent Operation Details
- Downloading Indexes of Agent Operation Details
- Requesting to Play Back a Recording File
- Playing Back a Recording File
- Downloading an Intelligent IVR Recording File
- Downloading IVR Voice Messages
- Downloading a Recording File as a Third Party
- Uploading a File as a Third Party
- Generating a File Hash Value as a Third Party
- Deleting an Uploaded File as a Third Party
- Index File Definition
- Reference Description
- Voice Notification Interface Reference
- OMA Interface Reference
- DataProcess Interface Reference
- Other Interfaces Reference
- FAQs
- To create a common IVR outbound call task, you have configured and published a main IVR flow. For details about how to configure a common IVR flow, see Getting Started. To create an intelligent outbound call task, you have configured and published a main intelligent IVR flow. For details about how to configure an intelligent IVR flow, see Configuring an Intelligent Robot.
In independent deployment mode, you have configured the IVR flow on the web configuration console.
- To create an outbound call task, you have completed the operations in Preparations for Creating Outbound Call Tasks.
- If the tenant space is in trial commercial use, you have contacted O&M personnel to add the numbers used for making outbound calls to the tenant space trustlist.
- To send SMS notifications for failed outbound calls, you have configured an internal SMS template on the Configuration Center > Workbench Configuration > Notification Template page. For details about how to configure an SMS notification template, see Configuring Notification Templates as an Administrator. Set Template Type to HUAWEI CLOUD SMS Messages.
- To configure a callback URL, you have submitted an application for adding the callback URL to the address trustlist to the system administrator, and the system administrator has approved the application.
Context
In a common IVR outbound call task, the system makes an outbound call to a customer and the call is transferred to a specified IVR flow after being connected. The IVR flow then plays a voice and collects digits from the customer.
Select a configured outbound call template where certain outbound call task parameters are preset. For details, see Creating Outbound Call Templates.
You can modify, start, or delete a task in draft state, and configure outbound call data for the task.
Business Scenario
The following describes how to configure an automatic outbound call task for a call center to notify customers of major product changes by playing voices. The outbound call task is executed in working hours on workdays and also on weekends. If a customer is busy, the call is made to the customer for another two times.
- Sign in to the AICC as a tenant administrator and choose Outbound Call > Call Mgmt.
- Click Create and choose Robot Outbound Call.
Figure 1 Page for creating a common IVR outbound call task
- Configure basic information.
- Task Name: Enter a customized task name.
- Caller Number: Select an existing calling number of the current tenant space. A maximum of 100 calling numbers can be added.
- Task Start And End Time: The start time cannot be later than the end time.
- Task Type: Select Common IVR Outbound Call or Intelligent Robot Outbound Call.
- Common IVR: Select an IVR flow that has been configured and published.
- Smart Robot: Only robots bound to the main flow can be selected.
- Questionnaire: An IVR survey needs to be used together with the questionnaire diagram element in an IVR flow. A manual and IVR survey can be used on the outbound call workbench or used together with the questionnaire diagram element in an IVR flow.
- SMS Template for Failed Outbound Call: Select a configured internal SMS notification template. For details about how to configure an SMS notification template, see Configuring Notification Templates as an Administrator. Set Template Type to HUAWEI CLOUD SMS Messages.
- Priority: Select a value from 1 to 5. A smaller value indicates a higher priority. If tasks are started at the same time, the task with a higher priority is called preferentially.
- Transfer to Skill Queue: After a skill queue is selected, the Variable assignment diagram element in the IVR flow is used to obtain the value of SkillQueueName (skill queue name) in the call-associated data. The skill queue name is used to transfer a call to a skill queue when Transfer Type is set to Skill Queue (Name) for the Call Transfer diagram element.
- Variable assignment
Click the Flow Attribute tab and create the FLOW.chuichui variable in the Flow Variable area.
Click the Node Attribute tab, click the Obtaining Associated Data tab, and create the FLOW.chuichui=iSales.SkillQueueName variable.
- Call Transfer
Set Transfer Type to Skill Queue (Name).
Set Route Value to FLOW.chuichui.
Set Associated Data to IVRREQUEST.transin_data.Figure 2 Variable assignmentFigure 3 Call Transfer
- Associate Business Result: This field is displayed only after Transfer to Skill Queue is set for an intelligent robot outbound call task. If a business result is associated, only the associated business result and its sub-business results can be selected for outbound calls.
- Manual Questionnaire: This field is displayed only when Transfer to Skill Queue is set. Only manual surveys and manual and IVR surveys are available. If a manual survey is selected, the survey is displayed on the outbound call workbench. A manual and IVR survey can be used on the outbound call workbench or used together with the questionnaire diagram element in an IVR flow.
- Blocklist Type: If a blocklist category is selected, all numbers in the blocklist are not called within the specified period.
- Callback Address: Enter the URL for callback upon call connection or release on the customer side.
The callback URL is a third-party URL and can carry data. The carried parameters include dataId, taskId, sessionId, calledNo, beginTime, vdnId, failCode, callId, filePath, and customFiled.
In the integrated environment, the callback URL can be configured only in the outbound call task.
- Configure the outbound call period. The parameters take effect according to the following priority: Allocate time periods by special dates > Special Date > Regular Date Time Period.
Figure 4 Outbound Call Duration
- In Regular Date Time Period(UTC+08:00), set the start time and end time of the working period. Examples are as follows:
9:00–11:30
14:00–18:00
- In Special Date, click add special date to add days such as holidays and weekends as special dates.
- In Special Time Period(UTC+08:00), click Add Time Period and set Start Time and End Time to 00:00 and 23:59, respectively.
- In Allocate time periods by special dates(UTC+08:00), set a period. If this function is not required, disable it.
If calls do not need to be made on some special dates, for example, weekends, you can set Regular Date Time Period(UTC+08:00) to 00:00 - 23:59, set weekends as special dates, and set Special Time Period(UTC+08:00) to 00:00 - 00:00, as shown in the following figure.
- Click Next and configure the task policy.
Figure 5 Task Strategy
Table 1 Parameters in the Task Strategy area Parameter
Max. Response Duration
If the response duration exceeds this value, the current call ends and the next call is to be made.
The value ranges from 5 to 120. The default value is 20.
Outbound Call Interval
Interval for starting an outbound call.
Enter an integer ranging from 1 to 9999.
Number of Outbound Calls at a Time
Number of outbound calls each time. The default value is 1.
The value cannot exceed the number of purchased IVR channels in the tenant space.
If the value of Outbound Call Interval is greater than 3, the number of outbound calls initiated by the system is calculated as follows: Value of Number of Outbound Calls at a Time/Value of Outbound Call Interval x 3.
Outbound Call Data Attribute Filtering
You can customize data attributes on the Configuration Center > Call Config > Data Attr page.
Enable this parameter to customize filter criteria. The system initiates an outbound call only when the pre-called customer number meets the criteria. Encrypted attributes cannot be used as filter criteria.
Outbound Call Interval and Number of Outbound Calls at a Time should be configured to make a fixed number of outbound calls on average with proper intervals rather than make all outbound calls at once.
For example, if you want to make 60 outbound calls in 1 minute, you are advised to set both Outbound Call Interval and Number of Outbound Calls at a Time to 3 instead of 60.
For a key robot outbound call or intelligent outbound call task, the number of outbound calls is calculated as follows: (Value of Number of Outbound Calls at a Time/Value of Outbound Call Interval) x 3, rounded up. Outbound calls are made only when the result is greater than 1. If the value of Outbound Call Interval is greater than 3, 3 is used for calculation. If the value of Outbound Call Interval is less than 3, the actual value is used.
- Q1: If the value of Outbound Call Interval is greater than 3, 3 is used for calculation. If the value of Outbound Call Interval is less than 3, the actual value is used. What is the meaning?
A1: If the outbound call interval is set to an interval greater than 3 seconds, the OBS still uses 3 seconds as the call interval. If the outbound call interval is set to an interval less than 3 seconds, the configured call interval is used.
- Q2: If I set Outbound Call Interval to 10 and Number of Outbound Calls at a Time to 100, how many outbound calls are made every 10 seconds? 100 or 30?
A2: The outbound call interval configured for the outbound call task is used only to calculate the number of calls made each time. When the value is greater than 3, it does not indicate the actual call interval. If you set Outbound Call Interval to 10, the actual call interval is 3 seconds. In this case, the number of calls made each time is 30 based on the formula: (Value of Number of Outbound Calls at a Time/Value of Outbound Call Interval) x 3. That is, 30 outbound calls are made every 3 seconds.
- Q3: If I set Outbound Call Interval to 1 and Number of Outbound Calls at a Time to 10, will 30 outbound calls be made every second?
A3: In this case, 10 outbound calls are made every second.
- Q4: What will happen if the calculated number of outbound calls is less than 1?
A4: In this case, no outbound call is made at the first interval. An outbound call is made until the decimal part of the value of Number of Outbound Calls at a Time accumulates to greater than 1.
- Configure the call policy.
- In the Call Strategy area, customize the pre-called customer numbers. Set parameters based on Table 2.
Figure 6 Call Strategy
Table 2 Parameters in the Call Strategy area Parameter
Call Sequence: Customize the call sequence of pre-called customer numbers.
Unordered call
By No
By data attribute
Click Add, select attributes, and set the sorting type.
You can adjust the attribute sequence after adding the attributes.
Multi-number customer call rounds: Mode for calling multiple numbers of a customer.
In sequence
Call multiple numbers of a customer in sequence.
By number type
You can select Existing number type or New number type. After the configuration, the number with the specified type placed ahead is called first.
By sequence number
You can enter the sequence numbers of numbers. After the configuration, the number with a smaller sequence number is called first.
- Configure Outbound Call Result Policy, which indicates the processing method when an outbound call is not connected due to an unallocated number, busy line, or other exceptions. Select Global policy or Contact Policy.
- Global policy
- Disable Configure Policy Based On Results.
Set Max. Call Attempt Days, Maximum number of call attempts per day, and Call-Out Interval (s).
Clickand set Add non-retry result code. When the result of an outbound call to a customer matches a result code configured in Add non-retry result code, the system stops retrying calling all other numbers of the customer.
Figure 7 Disabling Configure Policy Based On Results - Enable Configure Policy Based On Results.
In Results processing strategy, click
and set Outbound Call Failure Cause, Retry Times and Call-Out Interval (s). Click
for multiple times to add multiple policies one by one. Policies with the same values of Outbound Call Failure Cause cannot be added.
Figure 8 Enabling Configure Policy Based On Results
If the outbound call interval is set to a large value, outbound call operations indicators, such as the call connection rate, may be affected. You are advised to use the default value.
- Contact Policy
- Default number type: Set Whether to configure based on the result to configure the policy.
If it is set to No, you can set Max. Call Attempt Days and Maximum number of call attempts per day.
Figure 9 Setting Whether to configure based on the result to NoIf it is set to Yes, you can set Outbound Call Failure Cause, Retry Times, and Call-Out Interval (s). Click
Figure 10 Setting Whether to configure based on the result to Yes - Added number type: Click
to access the Configure Policy Based On Results dialog box. You must set Number Type first regardless of whether Configure Policy Based On Results is enabled, and then set other parameters.
If Configure Policy Based On Results is disabled, set Number Type to New number type and set Max. Call Attempt Days and Maximum number of call attempts per day.
Figure 11 Disabling Configure Policy Based On ResultsIf Configure Policy Based On Results is enabled, set Number Type to New number type, click
, and set Outbound Call Failure Cause, Maximum number of call attempts, and Call-Out Interval (s). Click
Figure 12 Enabling Configure Policy Based On Results
- Global policy
- (Optional) Click Save as Template. In the dialog box that is displayed, enter a template name and click confirm to save the current configuration as an outbound call template.
- Click Save.
- Return to the Call Mgmt page, click Contact list in the Operation column corresponding to the new outbound call task, and add outbound call data to the outbound call task. For details, see Configuring Outbound Call Data.
- Return to the Call Mgmt page and click
corresponding to the new outbound call task.
Follow-up Procedure
To modify an outbound call task, click Suspend to suspend it.
After the task is suspended, click Edit to modify the outbound call task. The procedure for changing the calling number is as follows:
- Click Caller Number. The page for selecting a calling number is displayed. The selected calling number is displayed by default.
Figure 13 Select Calling Number
- Click Add and select another calling number. The selected calling number cannot be selected again. The number of new calling numbers cannot exceed the Maximum number of calling numbers configured by an administrator.
Figure 14 Adding a calling number
- Click OK. Return to the Select Calling Number page and click OK.
To view the task result, you can click a task to access the outbound call task details page and click the outbound call result on the outbound call task details page to view the outbound call result for each customer.
To enable the recording function for intelligent robot outbound call results, choose Configuration Center > Chatbot Management > Flow Configuration > System > System Settings, click the System Settings tab, and set FLOWRECORDFLAG (whether to enable the recording function for intelligent IVR call flows) to Enable. In this way, Play is displayed for intelligent robot outbound call results.
On the task result page, you can perform the following operations:
- Click Details to view all outbound call results of all called numbers under the customer.
- Click Business Result to remark the called outbound numbers.
- Click Export to export the task result.
- Click View Export Result to view the export result. On the displayed page, you can download the result.
The exported data contains personal data. Exercise caution when processing the exported data to prevent personal data leakage and abuse.
