Voice Playback and Digit Collection
This diagram element is used to play a voice or video segment to interact with a customer, for example, to play the voice "Please enter xx."
Diagram Element
Parameter Description
The following figure shows the parameters of the Play Voice & Collect Digit diagram element.
The parameters are described as follows:
- Node Name: name displayed on the diagram element, which can be customized.
- Voice Prompt: Select Voice, TTS, or Video. You can click an option button to select a voice type.
- Voice: Upload a WAV voice file. Currently, the UAP supports only WAV (8 kHz, 8-bit) voice files. You can click the text box and select a voice file in the dialog box that is displayed. The options are approved voice files of the current tenant.
- TTS: Generate a voice file in TTS mode. You can enable Advanced TTS settings to set voice playback parameters. Click
in the drop-down list to select a sound effect and speaking speed. If this function is disabled, Sound effect is set to Female voice, Speaking speed is set to Low, and TTS extended parameter is not set by default.
- Sound effect: Select a sound effect. The default value is System Default. The options are Male voice and Female voice.
- Speaking speed: Select the speaking speed. The default value is System Default. The options are Low, Medium, and High.
- TTS extended parameter: Set this parameter based on site requirements. The value contains a maximum of 200 characters. This function is supported only when the MRCP protocol is used to connect to TTS service vendors. The parameter value is transparently transmitted to Vendor-Specific-Parameters.
- Number Pronunciation: This parameter is reserved.
- Video: Upload a video file in 3GP format, whose size must be less than or equal to 5 MB.
- Voice File: The system filters approved voice files, TTS files, or video files based on the selected voice type, and displays the files in the drop-down list. You can click
and select a required file. - Received Digits: This area displays parameters used to receive the external input.
- Max. number of digits received: maximum number of input digits that can be received. The default value is 24. If this parameter is set and the number of digits entered by a customer reaches the maximum value, the system automatically goes to the next step.
- Save user input: parameter for carrying information required by the diagram element. Click the text box. In the displayed dialog box, select a global variable or flow variable as required, for example, FLOW.IDNumber. The system saves the customer input by using a variable of the string type. Therefore, you can select only a variable of the string type.
In a security subflow scenario, the variables used to save the customer input must be saved after being encrypted.
- Waiting Time for Digit Collection: waiting time for receiving the external input. If the time when a customer stops the input exceeds that specified by Waiting Time for Digit Collection, the system records a failure, automatically executes Digit collection timed out, and continues to wait for the digit input.
- Max. Failure Times: maximum number of input attempts that are allowed. When an error occurs during digit collection, the system records a failure, automatically executes Digit collection failure, and continues to wait for the digit input.
- Timeout interval for digit collection: Timeout interval for pressing a key. For example, if this parameter is set to 2 seconds, the flow proceeds when the key pressing interval exceeds 2 seconds, even though the number of collected digits does not reach the specified value.
- Advanced Settings: You can click Advanced Settings + to expand this area and click Close to collapse this area.
- Digit collection failure: You can click
to enable the capability of playing a voice upon a digit collection error. Then, if digits fail to be collected before the number of a customer's input attempts reaches the maximum specified by Max. Failure Times, the system plays a voice to notify the customer. - Digit collection timed out: You can click
to enable the capability of playing a voice upon digit collection timeout. Then, if digits fail to be collected after the wait time reaches the maximum specified by Waiting Time for Digit Collection, the system plays a voice to notify the customer.
- By default, Digit collection failure and Digit collection timed out are disabled in the Advanced Settings area. If the capabilities are disabled, the system replays the voice configured for the voice playback and digit collection diagram element upon a failure.
- When the number of a customer's input attempts reaches the maximum specified by Max. Failure Times, the system executes the common failure exit.
Condition Branch Description
| Condition Branch | Description | Usage |
| Voice playback or digit collection failure | Voice playback or digit collection failure | Triggered upon a voice playback or digit collection failure. |
Typical Application Scenario
The system needs to interact with a customer and continue with the subsequent flow based on the input of the customer. For example, the system can handle a business only after a customer enters an identification number.
