Configuring the 5G RCS Channel
A tenant administrator can configure the 5G RCS channel for customers to access.
- You have obtained the authentication certificate provided by 5G RCS and uploaded it in Managing Certificates.
- After you enter information on the chatbot service platform (CSP) portal or provide enterprise information offline for chatbot registration, the CSP submits an application to China Mobile. After the application is approved, the CSP allocates the chatbot address, app ID, and app secret for enterprise access.
Context
If the chatbot address, app ID, and app secret provided by 5G RSC are changed, you need to modify the involved 5G RCS channel as follows: Sign in as a tenant administrator, choose , click Edit in the Operation column corresponding to the involved channel, and update the values of Chatbot Address, App Id, and App Secret.
- Sign in to the AICC as a tenant administrator and choose .
- Click New. The Configure Channel page is displayed.
- Set channel information parameters.
Table 1 Channel information parameters Parameter
Channel Selection
Select 5G RCS.
Chatbot Address
Unified service address of industry messages. The client can display all notifications based on this address.
App ID
App ID allocated by the developer market.
App Secret
Password allocated by the developer market to the app access key.
Certificate File
Select the uploaded 5G certificate.
- Set basic configuration parameters.
Table 2 Basic configuration parameters Parameter
Channel Name
The channel name must be unique. The code can contain a maximum of 64 characters, including only letters, digits, and underscores (_), and can start only with a letter or an underscore (_).
OU Configuration
Select an OU created in Configuring OUs to assign it to channel resources.
Skill Queue
The options are all multimedia called routes of the current tenant space. For details about how to configure a called route, see Configuring Called Routes.
The search criterion All accessible organizations is controlled by the tenant parameter Has the tenant enabled inter-organization data isolation enforcement. When the tenant parameter is set to Yes, the called route can be searched by OU. In addition, a non-administrator account that is not configured with the OU permission can search for only the called routes under the current OU.
Keyword for Transfer to Agent
Keywords for switching from robot service to manual service. After a customer enters any of the keywords on the client, robot service is switched to manual service.
NOTE:If the intelligent robot is enabled, this parameter must be set.
Agent Work Time
- Workday: A maximum of four working time segments (from 00:00 to 24:00) can be configured. By default, a time segment is displayed. You can click New to add a time segment.
- Non-workday: A maximum of four working time segments (from 00:00 to 24:00) can be configured. By default, a time segment is displayed. You can click New to add a time segment.
Non-working days are set on the page.
Non-Working Time Notification
When a customer call is connected to an agent in non-working time, this message is displayed to notify the customer that the agent is in rest state.
Queue Reminder
Queue reminder mode.
- All Reminders
- Queue Reminder
- Queue Progress Reminder
- Close Reminder
Queue Reminder Content
Queue reminder content.
The value can contain a maximum of 256 characters and cannot contain the following special characters: <>'"/\
This parameter is mandatory when Queue Reminder is set to All Reminders or Queue Reminder.
Queue Progress Reminder Content
Queue progress reminder content.
- The value can contain a maximum of 256 characters and cannot contain the following special characters: <>'"/\
- Variables can be set. The bound variables can only be user ID (${userId}), username (${nickName}), queue position (${position}), and estimated waiting time (${waitTime}, in seconds).
- Default value: You are currently in the queue, in position ${position}, and are expected to wait for ${waitTime} seconds
This parameter is mandatory when Queue Reminder is set to All Reminders or Queue Progress Reminder.
Call Transfer Interaction Times
The call transfer function can be used only when the number of messages sent by an agent to a customer reaches the set value.
When the value is 0 or empty, the agent can use the call transfer function at any time.
More
Last Agent Mode
For details, see How Do I Enable the Last Agent Mode?
Session End Due to No Customer Reply
For details, see How Do I Set Session End Due to No Customer Reply?
Session Transfer Due to No Agent Reply
For details, see How Do I Set Session Transfer Due to No Agent Reply?
Session Transfer
For details, see How Do I Set Session Transfer?
Offline Messages
For details, see How Do I Enable Offline Messages?
- Set robot configuration parameters.
Table 3 Robot configuration parameters Parameter
Connecting to the Intelligent Robot
For details, see How Do I Enable Connection to the Intelligent Robot?
Access Robot Assistant
For details, see How Do I Enable Connection to the Robot Assistant?
- Click The next step and go to the 5G RCS configuration page to configure the URL.
Follow-up Procedure
Export channel information.
- All information under Basic Configuration and Robot Configuration can be exported. Passwords and keys cannot be exported.
- A maximum of 100,000 channel records can be exported at a time, and a maximum of 2000 records are allowed in an exported file.
- If no channel is selected, all channel information is exported by default.
- Enter a compression password and click
to view the plaintext password.
- Return to the channel list.
- Select the new channel and click
to export the channel information. - Click
and confirm that Status of the export task is Success. - Click Download to obtain the exported channel information.
