Updated on 2025-11-06 GMT+08:00
Creating an AHPA Policy
The native HPA in Kubernetes is a passive, metric-based mechanism. Auto scaling is only triggered when the current resource usage exceeds the preset threshold. The native HPA scales resources with a delay. The system does not respond quickly enough during peak hours, increasing response delay and deteriorating user experience. During off-peak hours, resources may go wasted for a short period of time. CCE uses AHPA to address the delay. AHPA can identify workload fluctuation periods and predict resource demands based on historical metrics to help you implement predictive scaling.
Features
AHPA monitors historical workload metrics and performs weekly modeling, making it particularly effective for workloads with clear periodic patterns.
After AHPA is enabled, it collects monitoring data for a specific workload over a period of one to eight weeks. It then analyzes and models the data using statistical principles. Then, AHPA uses historical monitoring data and future service trends to recommend the optimal number of pods for a workload every minute. This allows pods to be prepared in advance to handle anticipated increases in service volume, ensuring adequate resource availability.
AHPA can work with HPA and CronHPA to scale pods in complex scenarios.
AHPA allows you to change the maximum and minimum number of pods in an HPA policy based on the recommended result, or directly adjust the number of pods in a Deployment.
AHPA and CronHPA share the same approach for adjusting the maximum and minimum pod numbers specified in an HPA policy. For details, see Using CronHPA to Adjust the HPA Scaling Scope.
  • CCE Advanced HPA of v1.5.2 or later has been installed in the cluster.
  • The Cloud Native Cluster Monitoring add-on has been installed in the cluster, and the monitoring data is reported to AOM. For details, see Cloud Native Cluster Monitoring.
Notes and Constraints
  • AHPA policies apply only to clusters of v1.23 or later.
  • For clusters of v1.19.10 and later, if an HPA policy is used to scale out a workload with EVS volumes mounted, a new pod cannot be started because EVS disks cannot be attached.
  • The specifications of the CCE Advanced HPA add-on are determined based on the total number of containers in the cluster and the number of scaling policies. Configure 500m and 1,000 MiB of memory for every 5,000 containers, and 100m and 500 MiB of memory for every 1,000 scaling policies.
  • AHPA needs extra memory as it analyzes and processes historical workload data. It is advised to allocate 100m CPU cores and 300 MiB of memory for every 100 AHPA policies.
  • After an AHPA policy is created, the type of its associated workload cannot be changed.
  • Either an AHPA policy or a CustomedHPA policy can be enabled.
Enabling an AHPA Policy
  2. In the navigation pane, choose Add-ons. Locate CCE Advanced HPA on the right, click Edit, and enable AHPA Policy.
  3. Click OK and wait until the add-on update is complete.
Using AHPA
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Deploy a sample workload. If a workload already runs in the cluster, skip this step. It is advised to use a workload that has been monitored for over seven days, as AHPA requires a minimum of seven days of monitoring data.
    kubectl create -f hamster.yaml
    Example configuration of hamster.yaml:
    apiVersion: apps/v1
    kind: Deployment
      selector:
        matchLabels:
          app: hamster
      replicas: 2
      template:
          labels:
            app: hamster
          containers:
            - name: hamster
              image: registry.k8s.io/ubuntu-slim:0.1
              resources:
                requests:
                  cpu: 100m
                  memory: 50Mi
              command: ["/bin/sh"]
              args:
                - "-c"
                - "while true; do timeout 0.5s yes >/dev/null; sleep 0.5s; done"
  3. Create an AHPA task.
    kubectl create -f hamster-ahpa.yaml
    Example configuration of hamster-ahpa.yaml:
    apiVersion: autoscaling.cce.io/v1alpha1
    kind: AdvancedHorizontalPodAutoscaler
      namespace: default
      scaleTargetRef:  # Associated workload, which can only be Deployment/HPA
        apiVersion: apps/v1
        kind: Deployment
      minReplicas: 2  # Minimum number of pods
      maxReplicas: 10  # Maximum number of pods
      metrics:  # Metrics, whose format is the same as that of the community HPA
      - type: Resource  # Metric source type, which can only be Resource
        resource:
          name: cpu  # Metric source name, which can only be CPU or memory
          target:
            type: Utilization  # Metric source type, which can only be Utilization
            averageUtilization: 50
      predictConfig:
        predictWindowSeconds: 1800
        stabilizationWindowSeconds: 1800
        quantile: "0.97"
      effectiveTime:
      - '* * 11-22 ? * MON-FRI'  # Valid from 11:00 to 22:00, from Monday to Friday
    Table 1 Key AHPA parameters
    Mandatory
    scaleTargetRef
    Yes
    Target Deployment/HPA.
    metrics
    Yes
    Metrics for scaling, which can only be CPU or memory. Only one metric can be configured. Either CPU or memory can be configured.
    maxReplicas
    Yes
    Maximum number of pods, which ranges from 0 to 2147483647.
    NOTICE:
    In CCE Turbo clusters, if you use a dedicated load balancer for your workload, the number of pods cannot exceed the backend server group quota of the load balancer, which is 500 by default. If you exceed this limit, you will not be able to add any more pods to the load balancer backend.
    minReplicas
    Yes
    Minimum number of pods, which ranges from 0 to 2147483647.
    predictConfig.predictWindowSeconds
    Yes
    Recommendation time window, which starts from the current time. The historical monitoring data within this time window will be used to calculate the recommended number of pods. The value can range from 1 to 3600.
    predictConfig.stabilizationWindowSeconds
    No
    Scale-in cooling duration. The value ranges from 0 to 3600.
    predictConfig.quantile
    Yes
    Prediction quantile, which indicates the probability that a service metric's actual value will be lower than the preset target value. A higher value indicates a more conservative estimate. The value ranges from 0 to 1. Two decimal places are supported. The default value is 0.99. The recommended value ranges from 0.90 to 0.99.
    effectiveTime
    No
    If multiple cron expressions are specified, AHPA will take effect on the combined set of these expressions. The default setting is always valid.
  4. After AOM has collected at least seven days of monitoring data for the target workload, AHPA can create a model and suggest the appropriate number of pods. Wait for the recommended number of pods to be provided and run the following command to check AHPA resource details:
    kubectl get ahpa hamster-ahpa -oyaml
    Command output:
      creationTimestamp: "2024-10-07T13:11:58Z"
      generation: 2
      namespace: default
      resourceVersion: "15529454"
      uid: e5ffbb01-50b0-4485-8cf5-bc2be884b1ee
      effectiveTime:
      maxReplicas: 10
      metrics:
      - resource:
          target:
            type: Utilization
        type: Resource
      minReplicas: 2
      predictConfig:
        quantile: "0.97"
      scaleTargetRef:
        apiVersion: apps/v1
        kind: Deployment
    status:
      conditions:
      - lastTransitionTime: "2024-10-07T13:24:19Z"
        message: the AHPA's model is ready
        reason: ModelIsReady
        status: "True"
        type: ModelAvailable
        message: the AHPA was able to successfully calculate a replica count
        reason: SucceededRunPrediction
        status: "True"
        type: ScalingActive
        message: this ahpa checkpoint is fresh
        reason: CheckpointIsFresh
        status: "True"
        type: CheckpointAvailable
        message: recommended size matches current size
        reason: ReadyForNewScale
        status: "True"
        type: AbleToScale
        message: the desired replica count is more than the maximum replica count
        reason: TooManyReplicas
        status: "True"
        type: ScalingLimited
      currentReplicas: 10
      desiredReplicas: 10
      lastScaleTime: "2024-10-07T13:24:19Z"
  5. If you no longer need an AHPA policy, run the following command to delete it:
    kubectl delete ahpa hamster-ahpa
    During the validity period of AHPA, you can use custom ahpacheckpoint resources to keep the recommended settings for the next 6 hours. If you do not need this configuration, manually delete it.
    kubectl delete ahpacheckpoint hamster-ahpa
