Configuring an HTTP/HTTPS Header for a LoadBalancer Ingress
- HTTP/HTTPS headers rely on ELB. Before using HTTP/HTTPS headers in a Service, check whether HTTP/HTTPS headers are supported in the current region. For details, see HTTP/HTTPS Headers.
- After HTTP or HTTPS is configured, if you delete the HTTP or HTTPS configuration on the CCE console or delete the target annotation from the YAML file, the configuration on the ELB will be retained.
| Header | Feature | Description | Supported Cluster Version |
| X-Forwarded-Port | Transfer Listener Port Number | If this option is enabled, the port number used by the listener will be transmitted to backend servers through the X-Forwarded-Port header. | v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later |
| X-Forwarded-For-Port | Transfer Port Number in the Request | If this option is enabled, the port number used by the client will be transmitted to backend servers through the X-Forwarded-For-Port header. | |
| X-Forwarded-Host | Rewrite X-Forwarded-Host | If this function is enabled, X-Forwarded-Host will be rewritten using the Host field in the client request header and transferred to backend servers. | |
| X-Real-IP | Rewrite X-Real-IP | If this function is enabled, the source IP address of the client will be rewritten into the X-Real-IP header and transferred to backend servers. | v1.25.16-r30, v1.27.16-r30, v1.28.15-r20, v1.29.13-r0, v1.30.10-r0, v1.31.6-r0, v1.32.1-r0, or later |
- A CCE standard or Turbo cluster is available, and the cluster version meets the requirements in Table 1.
- An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
- A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
Notes and Constraints
- Ingresses support HTTP to HTTPS headers only when dedicated load balancers are used.
- If multiple ingresses share the same external port on a load balancer, you are advised to use the same HTTP/HTTPS header for these ingresses. Otherwise, the configuration of the first created ingress will take precedence. For details, see Configuring Multiple Ingresses to Use the Same Load Balancer.
You can configure an HTTP/HTTPS header for an ingress using either the CCE console or kubectl.
- In the navigation pane, choose Services & Ingresses. Click the Ingresses tab and click Create Ingress in the upper right corner.
- Configure ingress parameters.
This example explains only key parameters for configuring HTTP/HTTPS headers. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
Table 2 Key parameters Parameter
Example
Name
Enter an ingress name.
ingress-test
Load Balancer
Select a load balancer to be associated with the ingress or automatically create a load balancer. In this example, only dedicated load balancers are supported.
Dedicated
Listener
- Frontend Protocol: HTTP and HTTPS are available.
- External Port: specifies the port of the load balancer listener.
- Advanced Options
- Transfer Listener Port Number: If this function is enabled, the listening port on the load balancer can be transferred to backend servers through the HTTP header of the packet.
- Transfer Port Number in the Request: If this function is enabled, the source port on the client can be transferred to backend servers through the HTTP header of the packet.
- Rewrite X-Forwarded-Host: If this function is enabled, X-Forwarded-Host will be rewritten using the Host field in the client request header and transferred to backend servers.
- Rewrite X-Real-IP: If this function is enabled, the source IP address of the client will be rewritten into the X-Real-IP header and transmitted to the backend servers.
- External Port: 80
- Advanced Options
- Transfer Listener Port Number: Enable
- Transfer Port Number in the Request: Enable
- Rewrite X-Forwarded-Host: Enable
Forwarding Policy
- Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through an IP address. The domain name must be registered and filed. Once used by a forwarding policy, only that domain name will be accepted for access.
- Path Matching Rule: Choose Prefix match, Exact match, or RegEx match.
- Path: comes from a backend application for external access. It must work in the backend application. Otherwise, forwarding will not take effect.
- Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list. If no Service meets the requirements, create one by following the operations provided in Services Supported by Ingresses.
- Destination Service Port: Select the access port of the destination Service.
- Domain Name: You do not need to configure this parameter.
- Path Matching Rule: Prefix match
- Path: /
- Destination Service: nginx
- Destination Service Port: 80
Figure 1 Configuring HTTP/HTTPS headers
- Click OK.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
An example YAML file of an ingress associated with an existing load balancer is as follows:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.id: <your_elb_id> # Replace it with the ID of your existing load balancer. kubernetes.io/elb.class: performance # Load balancer type kubernetes.io/elb.port: '80' kubernetes.io/elb.x-forwarded-port: 'true' # Obtain the listener port number. kubernetes.io/elb.x-forwarded-for-port: 'true' # Obtain the client port number for requests. kubernetes.io/elb.x-forwarded-host: 'true' # Rewrite X-Forwarded-Host. kubernetes.io/elb.x-real-ip: 'true' # Rewrite X-Real-IP. spec: rules: - host: '' http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with your target Service name. port: number: 80 # Replace it with your target Service port. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cceTable 3 Key parameters Parameter
Type
String
A load balancer can obtain the port number of a listener using X-Forwarded-Port and transmit the port number to the packets of the backend server.
- true: Enable the function of obtaining a listener port number.
- false: Disable the function of obtaining a listener port number.
String
A load balancer can obtain a client port number for requests using X-Forwarded-For-Port and transmit the port number to the packets of the backend server.
- true: Enable the function of obtaining a client port number for requests.
- false: Disable the function of obtaining a client port number for requests.
String
- true: Enable the function of rewriting X-Forwarded-Host. Then, the X-Forwarded-Host header will be rewritten using the Host header of the client request and transmitted to backend servers.
- false: Disable the function of rewriting X-Forwarded-Host. Then, the X-Forwarded-Host header of the client will be transmitted to backend servers.
String
- true: Enable the function of rewriting X-Real-IP. The source IP address of the client will be written into the X-Real-IP header and transmitted to the backend servers.
- false: Disable the function of rewriting X-Real-IP. The X-Real-IP header of the client will be transmitted to the backend servers.
- Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress.networking.k8s.io/ingress-test created
- Check the created ingress.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test cce * 121.**.**.** 80 10s
