Configuring Timeout for a LoadBalancer Ingress
LoadBalancer ingresses support the following timeout settings:
- Idle timeout setting for client connections: maximum duration for keeping a connection when no client request is received. If no request is received during this period, the load balancer closes the connection and establishes a new one with the client when the next request arrives.
- Timeout for waiting for a request from a client: If the client fails to send a request header to the load balancer during the timeout duration or the interval for sending body data exceeds a specified period, the load balancer will release the connection.
- Timeout setting for waiting for a response from a backend server: If the backend server fails to respond during the timeout duration, the load balancer will stop waiting and return HTTP 504 Gateway Timeout to the client.
- A CCE standard or Turbo cluster is available. The table below shows which cluster versions support the timeout configuration.
Timeout Type
Load Balancer Type
Supported Cluster Version
Idle Timeout
Dedicated
- v1.19: v1.19.16-r30 or later
- v1.21: v1.21.10-r10 or later
- v1.23: v1.23.8-r10 or later
- v1.25: v1.25.3-r10 or later
- Other clusters of later versions
Request Timeout
Dedicated
Response Timeout
Dedicated
Idle Timeout
Shared
- v1.23: v1.23.13-r0 or later
- v1.25: v1.25.8-r0 or later
- v1.27: v1.27.5-r0 or later
- v1.28: v1.28.3-r0 or later
Request Timeout
Shared
Response Timeout
Shared
- An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
- A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
Notes and Constraints
- If you delete the timeout configuration when updating an ingress, the timeout configuration of the existing listener will be retained.
- If multiple ingresses share the same external port on a load balancer, you are advised to use the same timeout configuration for these ingresses. Otherwise, the configuration of the first created ingress will take precedence. For details, see Configuring Multiple Ingresses to Use the Same External ELB Port.
Configuring Timeout
You can configure timeout for an ingress using either the CCE console or kubectl.
- In the navigation pane, choose Services & Ingresses. Click the Ingresses tab and click Create Ingress in the upper right corner.
- Configure ingress parameters.
This example explains only key parameters for configuring timeout. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
Table 1 Key parameters Parameter
Example
Name
Enter an ingress name.
ingress-test
Load Balancer
Select a load balancer to be associated with the ingress or automatically create a load balancer. A load balancer can be dedicated or shared.
Dedicated
Listener
- Frontend Protocol: HTTP and HTTPS are available.
- External Port: specifies the port of the load balancer listener.
- Advanced Options
- Idle Timeout (s): specifies the idle timeout of a client connection. If there are no requests reaching the load balancer during this period, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request.
The value ranges from 0 to 4000 (in seconds). The default value is 60.
- Request Timeout (s): specifies the timeout duration for waiting for a client request.
Specifically:
If the client fails to send a request header to the load balancer during this period, the request will be interrupted.
If the interval between two consecutive request bodies reaching the load balancer is greater than the timeout duration, the connection will be disconnected.
The value ranges from 1 to 300 (in seconds). The default value is 60.
- Response Timeout (s): specifies the timeout duration for waiting for a response from a backend server. If the backend server does not respond within this period after receiving a request, the load balancer will stop waiting and return an HTTP 504 error.
- External Port: 80
- Advanced Options
- Idle Timeout (s): 60
- Request Timeout (s): 60
- Response Timeout (s): 60
Forwarding Policy
- Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through the IP address. Ensure that the domain name has been registered and licensed. Once a forwarding policy is configured with a domain name specified, you must use the domain name for access.
- Path Matching Rule: Select Prefix match, Exact match, or RegEx match.
- Path: Enter the path provided by a backend application for external access. The path added must be valid in the backend application, or the forwarding cannot take effect.
- Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list. If no Service meets the requirements, create one by following the operations provided in Services Supported by Ingresses.
- Destination Service Port: Select the access port of the destination Service.
- Domain Name: You do not need to configure this parameter.
- Path Matching Rule: Prefix match
- Path: /
- Destination Service: nginx
- Destination Service Port: 80
Figure 1 Configuring timeout
- Click OK.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
An example YAML file of an ingress associated with an existing load balancer is as follows:
apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: test namespace: default annotations: kubernetes.io/elb.port: '80' kubernetes.io/elb.id: <your_elb_id> # In this example, an existing dedicated load balancer is used. Replace its ID with the ID of your dedicated load balancer. kubernetes.io/elb.class: performance kubernetes.io/elb.keepalive_timeout: '300' # Timeout setting for client connections kubernetes.io/elb.client_timeout: '60' # Timeout for waiting for a request from a client kubernetes.io/elb.member_timeout: '60' # Timeout for waiting for a response from a backend server spec: rules: - host: '' http: paths: - path: / backend: service: name: test port: number: 80 property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cceTable 2 Key annotation parameters Parameter
Mandatory
Type
No
String
Timeout for client connections. If there are no requests reaching the load balancer during the timeout duration, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request.
No
String
Timeout for waiting for a request from a client. There are two cases:
- If the client fails to send a request header to the load balancer during this period, the request will be interrupted.
- If the interval between two consecutive request bodies reaching the load balancer is greater than the timeout duration, the connection will be disconnected.
No
String
The duration within which a response from the backend server is expected. After a request is forwarded to the backend server, if the backend server does not respond within the duration specified by member_timeout, the load balancer will stop waiting and return HTTP 504 Gateway Timeout.
- Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress/ingress-test created
- Check the created ingress.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test cce * 121.**.**.** 80 10s
