Patch Version Release Notes
Indexes
Version 1.33
CCE Cluster Patch Version |
Kubernetes Version |
Feature Updates |
Optimization |
Vulnerability Fixing |
v1.33.5-r0 |
None |
Fixed some security issues. |
v1.33.1-r0 |
CCE clusters of v1.33 are released for the first time. For more information, see Kubernetes 1.33 Release Notes.
None |
None |
Version 1.32
Feature Updates |
Optimization |
v1.32.6-r10 |
None |
v1.32.6-r0 |
None |
v1.32.5-r2 |
None |
Optimized the performance of dynamic container network interface pre-binding in large CCE Turbo clusters. |
v1.32.5-r0 |
AK/SK automatic updates are supported for OBS buckets. |
None |
v1.32.1-r0 |
CCE clusters of v1.32 are released for the first time. For more information, see Kubernetes 1.32 Release Notes.
None |
Version 1.31
Feature Updates |
Optimization |
v1.31.10-r10 |
None |
v1.31.10-r0 |
None |
v1.31.6-r12 |
None |
v1.31.6-r10 |
None |
v1.31.6-r0 |
v1.31.4-r0 |
None |
v1.31.1-r4 |
None |
v1.31.1-r2 |
None |
Improved the Docker runtime security. |
v1.31.1-r0 |
CCE clusters of v1.31 are released for the first time. For more information, see Kubernetes 1.31 Release Notes.
None |
Version 1.30
Feature Updates |
Optimization |
v1.30.14-r10 |
None |
v1.30.14-r0 |
None |
v1.30.10-r12 |
None |
v1.30.10-r10 |
None |
v1.30.10-r0 |
v1.30.6-r10 |
None |
v1.30.6-r4 |
None |
v1.30.6-r2 |
None |
v1.30.6-r0 |
v1.30.4-r4 |
None |
v1.30.4-r2 |
None |
Fixed the issue of chart upload failures in certain situations. |
v1.30.4-r0 |
v1.30.1-r2 |
None |
Enhanced system stability. |
v1.30.1-r0 |
CCE clusters of v1.30 are released for the first time. For more information, see Kubernetes 1.30 Release Notes.
CCE can handle ELB listeners on all ports. |
Version 1.29
Feature Updates |
Optimization |
v1.29.15-r10 |
None |
v1.29.15-r0 |
None |
v1.29.13-r12 |
None |
v1.29.13-r10 |
None |
v1.29.13-r0 |
v1.29.10-r10 |
None |
v1.29.10-r4 |
None |
v1.29.10-r2 |
None |
v1.29.10-r0 |
v1.29.8-r4 |
None |
v1.29.8-r2 |
None |
v1.29.8-r0 |
v1.29.4-r2 |
None |
v1.29.4-r0 |
v1.29.3-r0 |
v1.29.2-r4 |
None |
The stability of ELB has been improved during upgrades that span across multiple versions. |
v1.29.2-r2 |
None |
During cluster upgrades, the collection of container logs has been made more reliable. |
v1.29.2-r0 |
v1.29.1-r10 |
v1.29.1-r0 |
CCE clusters of v1.29 are released for the first time. For more information, see Kubernetes 1.29 Release Notes. |
None |
None |
Version 1.28
Feature Updates |
Optimization |
v1.28.15-r50 |
None |
v1.28.15-r40 |
None |
v1.28.15-r32 |
None |
v1.28.15-r30 |
None |
v1.28.15-r20 |
v1.28.15-r10 |
None |
v1.28.15-r4 |
None |
v1.28.15-r2 |
None |
v1.28.15-r0 |
v1.28.13-r4 |
None |
v1.28.13-r2 |
None |
v1.28.13-r0 |
v1.28.8-r2 |
None |
v1.28.8-r0 |
v1.28.7-r2 |
v1.28.6-r4 |
None |
v1.28.6-r2 |
None |
v1.28.6-r0 |
v1.28.5-r0 |
v1.28.4-r0 |
The configurations of frequently used cluster parameters and node pool parameters are publicly available. |
v1.28.3-r0 |
LoadBalancer Services and ingresses allow you to:
None |
v1.28.2-r0 |
None |
v1.28.1-r4 |
None |
None |
Fixed CVE-2024-21626 issues. |
v1.28.1-r2 |
None |
Fixed the issue that configuration conflicts occasionally occur when an SNI certificate is configured on an ingress with HTTP/2 enabled. |
None |
v1.28.1-r0 |
CCE clusters of v1.28 are released for the first time. For more information, see Kubernetes 1.28 Release Notes.
None |
Version 1.27
Feature Updates |
Optimization |
v1.27.16-r60 |
None |
v1.27.16-r50 |
None |
v1.27.16-r42 |
None |
v1.27.16-r40 |
None |
v1.27.16-r30 |
v1.27.16-r20 |
None |
v1.27.16-r14 |
None |
v1.27.16-r12 |
None |
v1.27.16-r10 |
v1.27.16-r4 |
None |
v1.27.16-r2 |
None |
v1.27.16-r0 |
v1.27.10-r2 |
None |
v1.27.10-r0 |
v1.27.9-r0 |
v1.27.8-r4 |
None |
v1.27.8-r2 |
None |
v1.27.8-r0 |
v1.27.7-r0 |
v1.27.6-r0 |
v1.27.5-r0 |
None |
v1.27.4-r0 |
None |
v1.27.3-r4 |
None |
None |
v1.27.3-r2 |
None |
None |
v1.27.3-r0 |
v1.27.2-r0 |
None |
v1.27.1-r10 |
None |
Optimized the events generated during node pool scaling. |
v1.27.1-r0 |
CCE clusters of v1.27 are released for the first time. For more information, see Kubernetes 1.27 Release Notes.
The cluster IP address in clusters of v1.27 or later cannot be pinged due to security hardening. |
None |
Version 1.25
In CCE clusters of v1.25, containerd is the default runtime for nodes, except for nodes running EulerOS 2.5. In addition, clusters of v1.25 or later no longer support EulerOS 2.5.
Feature Updates |
Optimization |
v1.25.16-r40 |
None |
v1.25.16-r30 |
v1.25.16-r20 |
None |
v1.25.16-r14 |
None |
v1.25.16-r12 |
None |
v1.25.16-r10 |
v1.25.16-r4 |
None |
v1.25.16-r2 |
None |
v1.25.16-r0 |
v1.25.13-r2 |
None |
v1.25.13-r0 |
v1.25.12-r0 |
v1.25.11-r4 |
None |
v1.25.11-r2 |
None |
v1.25.11-r0 |
v1.25.10-r0 |
v1.25.9-r0 |
v1.25.8-r0 |
None |
v1.25.7-r0 |
None |
v1.25.6-r4 |
None |
None |
v1.25.6-r2 |
None |
None |
v1.25.6-r0 |
v1.25.5-r0 |
None |
v1.25.4-r10 |
None |
v1.25.4-r0 |
None |
v1.25.3-r10 |
High-frequency parameters of kube-apiserver are configurable. |
v1.25.3-r0 |
Enhanced network stability of CCE Turbo clusters when their specifications are modified. |
v1.25.1-r0 |
CCE clusters of v1.25 are released for the first time. For more information, see Kubernetes 1.25 Release Notes. |
None |
None |
Version 1.23
Feature Updates |
Optimization |
v1.23.18-r18 |
None |
None |
v1.23.18-r16 |
None |
None |
v1.23.18-r14 |
None |
v1.23.18-r12 |
None |
v1.23.18-r10 |
v1.23.18-r2 |
None |
v1.23.18-r0 |
v1.23.17-r0 |
v1.23.16-r4 |
None |
v1.23.16-r2 |
None |
v1.23.16-r0 |
v1.23.15-r0 |
v1.23.14-r0 |
v1.23.13-r0 |
None |
v1.23.12-r0 |
None |
v1.23.11-r4 |
None |
None |
v1.23.11-r2 |
None |
None |
v1.23.11-r0 |
v1.23.10-r0 |
None |
v1.23.9-r10 |
None |
v1.23.9-r0 |
None |
v1.23.8-r10 |
v1.23.8-r0 |
v1.23.7-r20 |
None |
v1.23.7-r10 |
None |
v1.23.7-r0 |
v1.23.6-r0 |
v1.23.5-r0 |
Fixed some security issues and the following CVE vulnerabilities: |
v1.23.4-r10 |
None |
Optimized the memory usage of kube-apiserver when CRDs are frequently updated. |
v1.23.4-r0 |
Arm nodes are supported. |
None |
v1.23.3-r0 |
Enhanced reliability when secure containers are frequently created or deleted. |
v1.23.1-r1 |
Node resource reservation has been optimized so that resource exhaustion can be detected to improve node stability. |
Node installation compatibility has been improved. |
v1.23.1-r0 |
CCE clusters of v1.23 are released for the first time. For more information, see Kubernetes 1.23 Release Notes. |
None |
None |
Version 1.21
Feature Updates |
Optimization |
v1.21.15-r0 |
v1.21.14-r0 |
A PVC can be used to dynamically create and mount an SFS Turbo subdirectory. |
None |
v1.21.13-r0 |
None |
v1.21.12-r4 |
None |
None |
v1.21.12-r2 |
None |
None |
v1.21.12-r0 |
The prefix and suffix of a node name can be customized in node pools. |
v1.21.11-r20 |
None |
v1.21.11-r10 |
None |
v1.21.11-r0 |
None |
v1.21.10-r10 |
v1.21.10-r0 |
v1.21.9-r0 |
v1.21.8-r0 |
v1.21.7-r0 |
Improved the stability of LoadBalancer Services/ingresses with a large number of connections. |
v1.21.6-r0 |
None |
v1.21.5-r10 |
None |
v1.21.5-r0 |
None |
v1.21.4-r10 |
None |
Enhanced the stability of EulerOS 2.9 NetworkManager. |
v1.21.4-r0 |
None |
v1.21.3-r10 |
None |
Enhanced the stability of secure containers when a network interface driver is changed. |
v1.21.3-r0 |
None |
CCE Turbo clusters support SNAT CIDR blocks. |
v1.21.2-r10 |
None |
Enhanced the interconnection stability between Services and load balancers. |
v1.21.2-r0 |
v1.21.1-r2 |
v1.21.1-r1 |
None |
Container networks support wide matching of an OS kernel version. |
v1.21.1-r0 |
CCE clusters of v1.21 are released for the first time. For more information, see Kubernetes 1.21 Release Notes. |
None |
None |
Version 1.19
Feature Updates |
Optimization |
v1.19.16-r84 |
None |
None |
v1.19.16-r82 |
None |
None |
v1.19.16-r80 |
None |
v1.19.16-r60 |
None |
v1.19.16-r50 |
None |
v1.19.16-r40 |
None |
v1.19.16-r30 |
v1.19.16-r20 |
v1.19.16-r10 |
None |
Enhanced the interconnection stability between Services/ingresses and load balancers. |
v1.19.16-r7 |
None |
v1.19.16-r6 |
v1.19.16-r5 |
v1.19.16-r4 |
v1.19.16-r3 |
None |
v1.19.16-r2 |
None |
v1.19.16-r1 |
None |
v1.19.16-r0 |
None |
Enhanced the stability in updating LoadBalancer Services when workloads are upgraded and nodes are scaled in or out. |
v1.19.10-r0 |
CCE clusters of v1.19 are released for the first time. For more information, see Kubernetes 1.19 Release Notes. |
None |
None |
