Updated on 2026-01-28 GMT+08:00
Comparison Between Cluster Types
Comparison
CCE provides different types of clusters for you to select. The following table lists the differences between them.
Cluster Type
CCE Standard
CCE Turbo
CCE Autopilot
Positioning
Standard clusters that provide highly reliable and secure containers for commercial use
Next-generation clusters designed for Cloud Native 2.0, with accelerated compute, networking, and scheduling
Serverless clusters that do not need users to manage nodes and are billed based on actual CPU and memory usages
In such clusters, no node deployment, management, and security maintenance are needed.
Application Scenario
For users who expect to use container clusters to manage applications, obtain elastic compute resources, and enable simplified management on compute, network, and storage resources
For users who have higher requirements on performance, resource utilization, and full-scenario coverage
For users whose services suffer frequent traffic surges, such as users in the online education and e-commerce sectors
Network Model
For scenarios where there are not so many containers and high performance is not needed, the following networks are provided:
  • Tunnel networks
  • VPC networks
For details, see Overview.
Cloud Native 2.0 networks: for scenarios where there are many containers and high performance is needed
A maximum of 2,000 nodes is supported.
Host Ports (hostPort) for Pods
Supported
Not supported
Not supported
Network Performance
The container network is overlaid with the VPC network, causing certain performance loss.
The VPC network and container network are flattened into one for zero performance loss.
Network Isolation
  • Tunnel networks: network policies for communications within a cluster
  • VPC networks: After DataPlane V2 is enabled, CCE supports network policies. For details, see DataPlane V2 Network Acceleration.
Pods can be associated with security groups for isolation. This ensures consistent security isolation both within and outside a cluster.
Container Resource Isolation
cgroups are used to isolate common containers.
  • VM-level isolation is supported for secure containers that run only on physical machines.
  • cgroups are used to isolate common containers.
VM-level isolation
Edge Infrastructure Management
Not supported
Support for management of edge cloud resources. For details, see Using Edge Cloud Resources in a Remote CCE Turbo Cluster.
Not supported
