(kubectl) Creating a Deployment Mounted with an OBS Volume
After an OBS volume is created or imported to CCE, you can mount the volume to a workload.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
- Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
- Run the following commands to configure the obs-deployment-example.yaml file, which is used to create a pod.
touch obs-deployment-example.yaml
vi obs-deployment-example.yaml
Example of mounting an OBS volume to a Deployment (PVC-based, shared volume):apiVersion: apps/v1 kind: Deployment metadata: name: obs-deployment-example # Workload name namespace: default spec: replicas: 1 selector: matchLabels: app: obs-deployment-example template: metadata: labels: app: obs-deployment-example spec: containers: - image: nginx name: container-0 volumeMounts: - mountPath: /tmp # Mount path name: pvc-obs-example restartPolicy: Always imagePullSecrets: - name: default-secret volumes: - name: pvc-obs-example persistentVolumeClaim: claimName: pvc-obs-auto-example # PVC nameTable 1 Key parameters Parameter
name
Name of the pod to be created.
app
Name of the application running in the pod.
mountPath
Mount path in the container.
spec.template.spec.containers.volumeMounts.name and spec.template.spec.volumes.name must be consistent because they have a mapping relationship.
Example of mounting an OBS volume to a StatefulSet (PVC template-based, dedicated volume):
Example YAML:apiVersion: apps/v1 kind: StatefulSet metadata: name: deploy-obs-standard-in namespace: default generation: 1 labels: appgroup: '' spec: replicas: 1 selector: matchLabels: app: deploy-obs-standard-in template: metadata: labels: app: deploy-obs-standard-in annotations: metrics.alpha.kubernetes.io/custom-endpoints: '[{"api":"","path":"","port":"","names":""}]' pod.alpha.kubernetes.io/initialized: 'true' spec: containers: - name: container-0 image: 'nginx:1.12-alpine-perl' env: - name: PAAS_APP_NAME value: deploy-obs-standard-in - name: PAAS_NAMESPACE value: default - name: PAAS_PROJECT_ID value: a2cd8e998dca42e98a41f596c636dbda resources: {} volumeMounts: - name: obs-bs-standard-mountoptionpvc mountPath: /tmp terminationMessagePath: /dev/termination-log terminationMessagePolicy: File imagePullPolicy: IfNotPresent restartPolicy: Always terminationGracePeriodSeconds: 30 dnsPolicy: ClusterFirst securityContext: {} imagePullSecrets: - name: default-secret affinity: {} schedulerName: default-scheduler volumeClaimTemplates: - metadata: name: obs-bs-standard-mountoptionpvc annotations: volume.beta.kubernetes.io/storage-class: obs-standard volume.beta.kubernetes.io/storage-provisioner: flexvolume-huawei.com/fuxiobs spec: accessModes: - ReadWriteMany resources: requests: storage: 1Gi serviceName: wwww podManagementPolicy: OrderedReady updateStrategy: type: RollingUpdate revisionHistoryLimit: 10Table 2 Key parameters Parameter
name
Name of the created workload.
Image of the workload.
mountPath
Mount path in the container. In this example, the volume is mounted to the /tmp directory.
serviceName
Service corresponding to the workload. For details about how to create a Service, see Creating a StatefulSet.
spec.template.spec.containers.volumeMounts.name and spec.volumeClaimTemplates.metadata.name must be consistent because they have a mapping relationship.
- Run the following command to create the pod:
kubectl create -f obs-deployment-example.yaml
After the creation is complete, choose Storage > OBS on the CCE console and click the PVC name. On the PVC details page, you can view the binding relationship between the OBS service and the PVC.
