Creating a LoadBalancer Ingress Using kubectl
This section uses an Nginx workload as an example to describe how to create a LoadBalancer ingress using kubectl.
- If no load balancer is available in the same VPC, CCE can automatically create a load balancer when creating an ingress. For details, see Automatically Creating a Load Balancer While Creating an Ingress.
- If a load balancer is available in the same VPC, perform the operation by referring to Associating an Existing Load Balancer to an Ingress While Creating the Ingress.
- An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
- A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
- Only clusters v1.17 or later support dedicated load balancers.
- It is recommended that other resources not use the load balancer automatically created by an ingress. Otherwise, the load balancer will be occupied when the ingress is deleted, resulting in residual resources.
- After an ingress is created, upgrade and maintain the configuration of the selected load balancers on the CCE console. Do not modify the configuration on the ELB console. Otherwise, the ingress service may be abnormal.
- The URL registered in an ingress forwarding policy must be the same as the URL used to access the backend Service. Otherwise, a 404 error will be returned.
- In an IPVS cluster, if the LoadBalancer ingress and Service share the same load balancer, the ingress cannot be accessed from within the cluster's nodes and containers. This is because kube-proxy binds the LoadBalancer Service address to the ipvs-0 bridge, which intercepts the ELB traffic. Use different load balancers for the LoadBalancer ingress and Service.
- Do not connect an ingress and a Service that uses HTTP to the same listener of the same load balancer. Otherwise, a port conflict occurs.
- Dedicated load balancers must be of the application type (HTTP/HTTPS) and support private networks (private IP addresses).
- If multiple ingresses access the same ELB port in a cluster, the listener configuration items (such as the certificate associated with the listener and the HTTP/2 attribute of the listener) are subject to the configuration of the first ingress.
Creating an Ingress Using kubectl
You can determine whether to automatically create a load balancer or use an existing one when creating an ingress.
The following describes how to run the kubectl command to automatically create a load balancer when creating an ingress.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
Starting from cluster v1.23, the ingress version is switched from networking.k8s.io/v1beta1 to networking.k8s.io/v1. For details about the differences between v1 and v1beta1, see Ingress API Version Upgrade in CCE Clusters v1.23.
Example of a shared load balancer (public network access) for clusters v1.23 or later:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.class: union kubernetes.io/elb.port: '80' kubernetes.io/elb.autocreate: '{ "type":"public", "bandwidth_name":"cce-bandwidth-******", # Bandwidth name "bandwidth_chargemode":"bandwidth", # Bandwidth billing mode "bandwidth_size":5, "bandwidth_sharetype":"PER", "vip_subnet_cidr_id": "*****", # IPv4 subnet ID of the subnet "vip_address": "**.**.**.**", # Private IP address of the load balancer "eip_type":"5_bgp" # EIP type }' kubernetes.io/elb.tags: key1=value1,key2=value2 # ELB resource tags spec: rules: - host: '' http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with your target Service name. port: number: <your_service_port> # Replace it with the target Service's port number. Using a different port may cause unexpected results. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cce # A LoadBalancer ingress is used.Example of a dedicated load balancer (public network access) for clusters v1.23 or later:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/elb.class: performance kubernetes.io/elb.port: '80' kubernetes.io/elb.autocreate: '{ "type": "public", "bandwidth_name": "cce-bandwidth-******", # Bandwidth name "bandwidth_chargemode": "bandwidth", # Bandwidth billing mode "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp", # EIP type "vip_subnet_cidr_id": "*****", # IPv4 subnet ID of the subnet "vip_address": "**.**.**.**", # Private IP address of the load balancer "elb_virsubnet_ids":["*****"], # Subnet network ID "available_zone": [ "ap-southeast-1a" ], "l7_flavor_name": "L7_flavor.elb.s1.small" }' kubernetes.io/elb.tags: key1=value1,key2=value2 # ELB resource tags spec: rules: - host: '' http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with your target Service name. port: number: <your_service_port> # Replace it with the target Service's port number. Using a different port may cause unexpected results. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cceExample of a shared load balancer (public network access) for clusters v1.21 or earlier:apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.class: union kubernetes.io/ingress.class: cce # A LoadBalancer ingress is used. kubernetes.io/elb.port: '80' kubernetes.io/elb.autocreate: '{ "type":"public", "bandwidth_name":"cce-bandwidth-******", # Bandwidth name "bandwidth_chargemode":"bandwidth", # Bandwidth billing mode "bandwidth_size":5, "bandwidth_sharetype":"PER", "eip_type":"5_bgp" # EIP type }' kubernetes.io/elb.tags: key1=value1,key2=value2 # ELB resource tags spec: rules: - host: '' http: paths: - path: '/' backend: serviceName: <your_service_name> # Replace it with your target Service name. servicePort: <your_service_port> # Replace it with the target Service's port number. Using a different port may cause unexpected results. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITHExample of a dedicated load balancer (public network access) for clusters v1.21 or earlier:apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/elb.class: performance kubernetes.io/ingress.class: cce kubernetes.io/elb.port: '80' kubernetes.io/elb.autocreate: '{ "type": "public", "bandwidth_name": "cce-bandwidth-******", # Bandwidth name "bandwidth_chargemode": "bandwidth", # Bandwidth billing mode "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp", # EIP type "elb_virsubnet_ids":["*****"], # Subnet network ID "available_zone": [ "ap-southeast-1a" ], "l7_flavor_name": "L7_flavor.elb.s1.small" }' kubernetes.io/elb.tags: key1=value1,key2=value2 # ELB resource tags spec: rules: - host: '' http: paths: - path: '/' backend: serviceName: <your_service_name> # Replace it with your target Service name. servicePort: <your_service_port> # Replace it with the target Service's port number. Using a different port may cause unexpected results. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITHTable 1 Key parameters Parameter
Mandatory
Type
Yes
String
Select a proper load balancer type. This parameter cannot be modified after the ingress is created.
Options:
- union: shared load balancer
- performance: dedicated load balancer. For details, see Differences Between Shared and Dedicated Load Balancers.
Default: union
Yes
(only for clusters v1.21 or earlier)
String
cce: A proprietary LoadBalancer ingress is used.
This parameter is mandatory when you create an ingress.
ingressClassName
Yes
(only for clusters v1.23 or later)
String
No
String
External port registered with the LoadBalancer Service address.
The value ranges from 1 to 65535. The default value is 80 for HTTP and 443 for HTTPS.
NOTE:Some ports on a shared load balancer are highly risky and blocked by default, for example, port 21.
kubernetes.io/elb.subnet-id
None
String
ID of the subnet where the cluster is located. The value can contain 1 to 100 characters.
- Mandatory when a cluster v1.11.7-r0 or earlier will be automatically created.
- Optional for clusters of a version later than v1.11.7-r0. It is left blank by default.
For details about how to obtain the value, see What Is the Difference Between the VPC Subnet API and the OpenStack Neutron Subnet API?
kubernetes.io/elb.enterpriseID
No
String
This parameter is available in Kubernetes clusters v1.15 or later. In Kubernetes clusters earlier than v1.15, load balancers are created in the default project by default.
This parameter specifies the ID of the enterprise project where a load balancer is created. It is applicable only to enterprise accounts with enterprise projects enabled. After an enterprise project ID is selected, resources can be created in the ELB enterprise project.
The value contains 1 to 100 characters.
How to obtain:
Log in to the EPS console, click the name of the target enterprise project. On the enterprise project details page, find the ID field and copy the ID.
Yes
elb.autocreate object
Whether to automatically create a load balancer associated with an ingress. For details about the field description, see Table 2. This parameter cannot be modified after the ingress is created.
CAUTION:kubernetes.io/elb.id and kubernetes.io/elb.autocreate cannot be specified concurrently.
If both annotations are specified in a Service, CCE will use an existing load balancer instead of automatically creating one. If this Service is deleted, the existing load balancer is considered as an automatically created one. If no other resources are associated with the load balancer, the load balancer will also be deleted.
Example:
- Automatically created dedicated load balancer with an EIP bound:
'{"type":"public","bandwidth_name":"cce-bandwidth-1741230802502","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp","available_zone":["*****"],"elb_virsubnet_ids":["*****"],"l7_flavor_name":"L7_flavor.elb.pro.max","l4_flavor_name":"","vip_subnet_cidr_id":"*****"}'
- Automatically created dedicated load balancer with no EIP bound:
'{"type":"inner","available_zone":["*****"],"elb_virsubnet_ids":["*****"],"l7_flavor_name":"L7_flavor.elb.pro.max","l4_flavor_name":"","vip_subnet_cidr_id":"*****"}'
- Automatically created shared load balancer with an EIP bound:
'{"type":"public","bandwidth_name":"cce-bandwidth-1551163379627","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp","name":"james"}'
- Automatically created shared load balancer with no EIP bound:
- Automatically created dedicated load balancer with an EIP added to a shared bandwidth
'{"type":"public","bandwidth_id":"*****","bandwidth_sharetype":"WHOLE","eip_type":"5_bgp","available_zone":["*****"],"elb_virsubnet_ids":["*****"],"l7_flavor_name":"","l4_flavor_name":"L4_flavor.elb.pro.max","vip_subnet_cidr_id":"*****"}'
- Automatically created shared load balancer with an EIP added to a shared bandwidth
'{"type":"public","bandwidth_id":"*****","bandwidth_sharetype":"WHOLE","eip_type":"5_bgp","name":"james"}'
No
String
Whether to add resource tags to a load balancer. This function is available only when the load balancer is automatically created, and the cluster version is v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later.
A tag is in the format of "key=value". Use commas (,) to separate multiple tags. A load balancer supports a maximum of 20 resource tags. CCE automatically adds 1 system tag, counting toward this limit.
host
No
String
Domain name for accessing the Service. By default, this parameter is left blank, and the domain name needs to be fully matched. The domain name must be registered and filed. Once a domain name is used by a forwarding policy, only that domain name will be accepted for access.
path
Yes
String
User-defined route path. All external access requests must match host and path.
NOTE:The access path added here must exist in the backend application. Otherwise, the forwarding fails.
For example, the default access URL of the Nginx application is /usr/share/nginx/html. When adding /test to the ingress forwarding policy, ensure the access URL of your Nginx application contains /usr/share/nginx/html/test. Otherwise, error 404 will be returned.
No
String
Route matching policy.
Default: STARTS_WITH (prefix match)
Options:
- EQUAL_TO: exact match
- STARTS_WITH: prefix match
- REGEX: regular expression match
pathType
Yes
String
Path type. This field is supported only by clusters v1.23 or later.- ImplementationSpecific: The matching method depends on Ingress Controller. The matching method defined by ingress.beta.kubernetes.io/url-match-mode is used in CCE.
- Exact: exact matching of the URL, which is case-sensitive.
- Prefix: prefix matching, which is case-sensitive. With this method, the URL path is separated into multiple elements by slashes (/) and the elements are matched one by one. If each element in the URL matches the path, the subpaths of the URL can be routed normally. NOTE:
- During prefix matching, each element must be exactly matched. If the last element of the URL is the substring of the last element in the request path, no matching is performed. For example, /foo/bar matches /foo/bar/baz but does not match /foo/barbaz.
- When elements are separated by slashes (/), if the URL or request path ends with a slash (/), the slash (/) at the end is ignored. For example, /foo/bar matches /foo/bar/.
See examples of ingress path matching.
Table 2 elb.autocreate data structure Parameter
Mandatory
Type
name
No
String
Name of the automatically created load balancer.
The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed.
Default: cce-lb+service.UID
type
No
String
Network type of the load balancer.
- public: public network load balancer
- inner: private network load balancer
Default: inner
bandwidth_id
No
String
Shared bandwidth ID, which must be specified when you use an existing shared bandwidth. The cluster version must be v1.30.14-r100, v1.31.14-r60, v1.32.13-r30, v1.33.12-r10, v1.34.8-r10, v1.35.5-r10, v1.36.2-r0, or later.
bandwidth_name
Yes for public network load balancers when no shared bandwidth ID is provided
String
Bandwidth name. The default value is cce-bandwidth-******.
String
Bandwidth billing mode.
- bandwidth: billed by bandwidth
- traffic: billed by traffic
bandwidth_size
Integer
Bandwidth size. The value ranges from 1 Mbit/s to 2000 Mbit/s by default. Configure this parameter based on the bandwidth range allowed in your region.
The minimum increment for bandwidth adjustment varies depending on the bandwidth range.- The minimum increment is 1 Mbit/s if the allowed bandwidth does not exceed 300 Mbit/s.
- The minimum increment is 50 Mbit/s if the allowed bandwidth ranges from 300 Mbit/s to 1000 Mbit/s.
- The minimum increment is 500 Mbit/s if the allowed bandwidth exceeds 1000 Mbit/s.
bandwidth_sharetype
String
Bandwidth sharing mode.
- PER: dedicated bandwidth
- WHOLE: shared bandwidth. This parameter is supported only in clusters v1.30.14-r100, v1.31.14-r60, v1.32.13-r30, v1.33.12-r10, v1.34.8-r10, v1.35.5-r10, v1.36.2-r0, and later versions. NOTE:
When set to WHOLE, the shared bandwidth ID must be specified.
eip_type
String
EIP type.
- 5_telcom: China Telecom
- 5_union: China Unicom
- 5_bgp: dynamic BGP
- 5_sbgp: static BGP
The types vary by region. For details, see the EIP console.
vip_subnet_cidr_id
No
String
The ID of the IPv4 subnet where the load balancer resides. This subnet is used to allocate IP addresses for the load balancer to provide external services. The IPv4 subnet must belong to the cluster's VPC.
If this parameter is not specified, the load balancer and the cluster will be in the same subnet by default.
This field can be specified only for clusters v1.21 or later.
How to obtain:
Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the IPv4 Subnet ID on the Summary tab.
ipv6_vip_virsubnet_id
No
String
The ID of the IPv6 subnet where the load balancer is deployed. IPv6 must be enabled for the subnet.
This parameter is available only for dedicated load balancers.
How to obtain:
Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the Network ID on the Summary tab.
elb_virsubnet_ids
No
Array of strings
The network ID of the subnet where the load balancer is located. This subnet is used to allocate IP addresses for accessing the backend server. If this parameter is not specified, the subnet specified by vip_subnet_cidr_id will be used by default. Load balancers occupy varying numbers of subnet IP addresses based on their specifications. Do not use the subnet CIDR blocks of other resources (such as clusters or nodes) as the load balancer's CIDR block.
Example:
"elb_virsubnet_ids": [ "14567f27-8ae4-42b8-ae47-9f847a4690dd" ]
How to obtain:
vip_address
No
String
Private IP address of the load balancer. Only IPv4 addresses are supported.
The IP address must be in the ELB CIDR block. If this parameter is not specified, an IP address will be automatically assigned from the ELB CIDR block.
This parameter is only available in clusters v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later versions.
available_zone
Yes
Array of strings
AZ where the load balancer is located.
You can obtain all supported AZs by getting the AZ list.
l4_flavor_name
No
String
Flavor name of the Layer 4 load balancer. This parameter is mandatory when TCP, TLS, or UDP is used.
You can obtain all supported types by getting the flavor list.
l7_flavor_name
No
String
Flavor name of the Layer 7 load balancer. This parameter is mandatory when HTTP or HTTPS is used.
This parameter is available only for dedicated load balancers. Its value must match that of l4_flavor_name, both of which must be either elastic or fixed.
- Create an ingress.
If the command output contains "ingress-test created", the ingress has been created.
- Check the created ingress.
kubectl get ingress
If information similar to the following is displayed, the ingress has been created:
NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test cce * 121.**.**.** 80 10s
- Enter http://121.**.**.**:80 in the address bar of the browser to access the workload (for example, Nginx workload).
121.**.**.** indicates the IP address of the unified load balancer.
CCE allows you to connect to an existing load balancer when creating an ingress.
- Starting from cluster v1.23, the ingress version is switched from networking.k8s.io/v1beta1 to networking.k8s.io/v1. For details about the differences between v1 and v1beta1, see Ingress API Version Upgrade in CCE Clusters v1.23.
- An existing dedicated load balancer must be of the application type (HTTP/HTTPS) and support private networks (with a private IP address).
If the cluster version is 1.23 or later, the YAML file configuration is as follows:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.id: <your_elb_id> # Replace it with the ID of your existing load balancer. kubernetes.io/elb.ip: <your_elb_ip> # Replace it with the IP address of your existing load balancer. kubernetes.io/elb.class: performance # Load balancer type kubernetes.io/elb.port: '80' spec: rules: - host: '' http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with your target Service name. port: number: 8080 # Replace it with the target Service's port number. Using a different port may cause unexpected results. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cceIf the cluster version is 1.21 or earlier, the YAML file configuration is as follows:
apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.id: <your_elb_id> # Replace it with the ID of your existing load balancer. kubernetes.io/elb.ip: <your_elb_ip> # Replace it with the IP address of your existing load balancer. kubernetes.io/elb.class: performance # Load balancer type kubernetes.io/elb.port: '80' kubernetes.io/ingress.class: cce spec: rules: - host: '' http: paths: - path: '/' backend: serviceName: <your_service_name> # Replace it with your target Service name. servicePort: 80 # Replace it with the target Service's port number. Using a different port may cause unexpected results. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITHTable 3 Key parameters Parameter
Mandatory
Type
No
String
ID of a load balancer. The value can contain 1 to 100 characters.
Use either this parameter or kubernetes.io/elb.ip. If they conflict, kubernetes.io/elb.id will take precedence. This parameter cannot be modified after the ingress is created.
How to obtain:
On the management console, click Service List, and choose Networking > Elastic Load Balance. Click the name of the target load balancer. On the Summary tab page, find and copy the ID.
No
String
IP address of a load balancer.
Use either this parameter or kubernetes.io/elb.id. If they conflict, kubernetes.io/elb.id will take precedence. This parameter cannot be modified after the ingress is created.
When creating an ingress, specify a public or private IP address for a shared load balancer. For a dedicated load balancer, only a private IP address can be specified.
Yes
String
Load balancer type. This parameter cannot be modified after the ingress is created.
- performance: dedicated load balancer, which can be used only in clusters v1.17 and later. For details, see Differences Between Shared and Dedicated Load Balancers.
NOTE:If a LoadBalancer ingress accesses an existing dedicated load balancer, the dedicated load balancer must be of the application load balancing (HTTP/HTTPS) type.
No
String
NOTE:- Some ports on a shared load balancer are highly risky and blocked by default, for example, port 21.
- If you select an existing load balancer, the listener ports of different clusters cannot be reused. Multiple ingresses within the same cluster can share the same listener port, but the listener configuration that works is determined by the earliest ingress configuration. For details, see Configuring Multiple Ingresses to Use the Same Load Balancer.
kubectl get ingress
Helpful Links
- For details about how to obtain the client source IP address, see Obtaining the Client Source IP Address for a Container.
- To use more advanced functions of LoadBalancer ingresses, see LoadBalancer Ingress Annotations.
- If an ingress cannot be accessed from outside the cluster, locate the root cause by referring to Why Can't the Ingress Be Accessed Outside the Cluster?
- If there is an access exception after an HTTPS certificate is configured for a LoadBalancer ingress, check whether the certificate configuration is correct by referring to What Could Cause Access Exceptions After Configuring an HTTPS Certificate for a LoadBalancer Ingress?
