Updated on 2026-09-21 GMT+08:00
CoreDNS
Introduction
CoreDNS is a DNS server that provides domain name resolution for Kubernetes clusters through chained plugins.
CoreDNS is an open-source software and has been a part of CNCF. It provides ways for cloud services to discover each other in cloud native deployments. CoreDNS uses a plugin chain architecture to enable flexible configuration and efficient DNS processing by combining plugins as needed. When used in a Kubernetes cluster, CoreDNS can automatically discover services in the cluster and provide domain name resolution for these services. By working with DNS servers, CoreDNS can resolve external domain names for workloads in a cluster.
This add-on is installed by default during cluster creation.
Kubernetes backs CoreDNS as the official default DNS for all clusters going forward.
CoreDNS official website: https://coredns.io/
Open-source community: https://github.com/coredns/coredns
For details, see DNS.
To run CoreDNS properly or upgrade CoreDNS in a cluster, ensure the number of available nodes in the cluster is greater than or equal to the number of CoreDNS pods and all CoreDNS pods are running. Otherwise, the add-on will malfunction or the upgrade will fail.
Installing the Add-on
This add-on is installed by default. If it is uninstalled due to some reasons, you can reinstall it by performing the following steps:
  2. In the navigation pane, choose Add-ons. Locate CoreDNS on the right and click Install.
  3. On the Install Add-on page, configure the specifications as needed.
    • If you selected Preset, you can choose between Small, Medium, or Large as needed. The system will automatically set the number of add-on pods and resource quotas based on the preset specifications. You can see the configurations on the console.
      The small one can handle up to 2500 external and 10,000 internal domain names QPS. The medium specification can handle up to 5000 external and 20,000 internal domain names QPS. The large specification can handle up to 10,000 external and 40,000 internal domain names QPS.
    • If you selected Custom, you can adjust the number of pods and resource quotas as needed. CoreDNS QPS is positively correlated with CPU consumption. As the number of nodes or containers in the cluster increases, the CoreDNS workload increases accordingly. Adjust the number of the CoreDNS pods and their CPU and memory quotas based on the cluster scale. For details, see Table 1.
      Table 1 Recommended CoreDNS quotas
      Nodes
      Recommended QPS
      Pods
      Requested vCPUs
      vCPU Limit
      Requested Memory
      Memory Limit
      50
      2500
      2
      500m
      500m
      512 MiB
      512 MiB
      200
      5000
      2
      1000m
      1000m
      1024 MiB
      1024 MiB
      1000
      10000
      2
      2000m
      2000m
      2048 MiB
      2048 MiB
      2000
      20000
      4
      2000m
      2000m
      2048 MiB
      2048 MiB
  4. Configure the add-on parameters.
    Table 2 Add-on parameters
    Stub Domain
    A domain name server for a custom domain name, which is in the format of key-value pairs. The key is a domain name suffix, and the value is one or more DNS IP addresses, for example, acme.local -- 1.2.3.4,6.7.8.9.
    For details, see Configuring the Stub Domain for CoreDNS.
    CAUTION:
    Uppercase letters are not allowed in custom domain names.
    Extended Parameter Settings
    • parameterSyncStrategy: indicates whether to configure consistency check when the add-on is upgraded.
      • ensureConsistent: indicates that the configuration consistency check is enabled. If the delivered configuration differs from the current effective configuration, the current effective configuration will be replaced. However, if the delivered configuration is the same as the current effective configuration, the current effective configuration will be preserved. The ensureConsistent parameter guarantees the configuration consistency. If a ConfigMap is modified manually, the add-on cannot be upgraded. In such cases, you will need to use the force or inherit policy to upgrade the add-on.
      • force: controls whether the configuration consistency check is ignored during an upgrade. If the configuration delivered during an add-on upgrade is identical to the configuration before the upgrade, the ConfigMap will not be updated and the effective configuration will remain unchanged. If the configuration is modified during an add-on upgrade, the new configuration delivered with the upgrade is applied. It is important to ensure that the configuration delivered during the add-on upgrade matches the current effective configuration. After the add-on is upgraded, you need to restore the value of parameterSyncStrategy to ensureConsistent to enable the configuration consistency check again.
      • inherit: If the configuration provided during the add-on upgrade differs from the current effective configuration, the current effective configuration will be used instead. After the add-on is upgraded, you need to restore the value of parameterSyncStrategy to ensureConsistent to enable the configuration consistency check again.
        CAUTION:
        After the automatic inheritance of parameter settings (parameterSyncStrategy=inherit) is enabled, stub domain settings will be cleared and merged into the extended parameter settings. The original stub domain settings remain unchanged and can still be viewed under Extended Parameter Settings.
    • servers: It is available in CoreDNS 1.23.1 and later. You can customize servers. For details, see dns-custom-nameservers.
      plugins indicates the configuration of each component in CoreDNS. Retain the default settings typically to prevent CoreDNS from being unavailable due to configuration errors. Each plugin component contains name, parameters (optional), and configBlock (optional). The format of the generated Corefile is as follows:
      $name  $parameters {
      $configBlock
      Table 3 describes common plugins. For details, see Plugins.
    • upstream_nameservers: specifies the IP address of the upstream DNS server.
    Example:
         "annotations": {},
         "parameterSyncStrategy": "ensureConsistent",
         "servers": [
    			"plugins": [
    					"name": "bind",
    					"parameters": "{$POD_IP}"
    					"name": "cache",
    					"configBlock": "servfail 5s",
    					"parameters": 30
    					"name": "errors"
    					"name": "health",
    					"parameters": "{$POD_IP}:8080"
    					"name": "ready",
    					"parameters": "{$POD_IP}:8081"
    					"configBlock": "pods insecure\nfallthrough in-addr.arpa ip6.arpa",
    					"name": "kubernetes",
    					"parameters": "cluster.local in-addr.arpa ip6.arpa"
    					"name": "loadbalance",
    					"parameters": "round_robin"
    					"name": "prometheus",
    					"parameters": "{$POD_IP}:9153"
    					"configBlock": "policy random",
    					"name": "forward",
    					"parameters": ". /etc/resolv.conf"
    					"name": "reload"
    			"port": 5353,
    			"zones": [
    					"zone": "."
    	"upstream_nameservers": ["8.8.8.8", "8.8.4.4"]
    Table 3 Default CoreDNS configurations
    Plugin Name
    Type
    bind
    Default configuration
    Host IP address listened by CoreDNS. Retain the default value {$POD_IP}. For details, see bind.
    cache
    Enables DNS cache. For details, see cache.
    If the add-on version is 1.25.10 or later, the servfail cache can be disabled. To disable the servfail cache, set configBlock to servfail 0. Otherwise, the unit for the servfail cache is second and cannot be omitted.
    errors
    Errors are logged to stdout. For details, see errors.
    health
    Health check for CoreDNS. It listens on {$POD_IP}:8080. Keep the default setting. Otherwise, the CoreDNS health check will fail and the add-on will restart repeatedly. For details, see health.
    ready
    Whether the backend server is ready to receive traffic. It listens on {$POD_IP}:8081. If the backend server is not ready, CoreDNS will suspend DNS resolution until the backend server becomes ready. For details, see ready.
    kubernetes
    CoreDNS Kubernetes plugin, which provides the service parsing capability in a cluster. For details, see kubernetes.
    loadbalance
    Round-robin DNS load balancer that randomizes the order of A, AAAA, and MX records in an answer. For details, see loadbalance.
    prometheus
    API for obtaining CoreDNS metrics. It listens on {$POD_IP}:9153 by default. Keep the default setting. Otherwise, Prometheus cannot collect CoreDNS metrics. For details, see Prometheus.
    forward
    Forwards any queries that are not within the cluster domain of Kubernetes to predefined resolvers (/etc/resolv.conf). For details, see forward.
    reload
    Automatically reloads modified Corefiles. After you modify a ConfigMap, wait for two minutes for the modification to take effect. For details, see reload.
    log
    Extended configuration
    Enables CoreDNS logging. For details, see log.
    The following is an example:
       "name": "log"
    template
    A quick response template, where AAAA indicates an IPv6 request. If NXDOMAIN is returned in an rcode response, no IPv6 resolution result is returned. For details, see template.
       "configBlock": "rcode NXDOMAIN",
       "name": "template",
       "parameters": "ANY AAAA"
  5. Configure deployment policies for the add-on pods.
    • Scheduling policies do not take effect on the DaemonSet pods of the add-on.
    • When configuring multi-AZ deployment or node affinity, ensure that there are nodes meeting the scheduling policy and that resources are sufficient in the cluster. Otherwise, the add-on pods cannot run.
    Table 4 Configurations for add-on scheduling
    Multi-AZ Deployment
    • Preferred: Deployment pods of the add-on will be preferentially scheduled to nodes in different AZs. If all the nodes in the cluster are deployed in the same AZ, the pods will be scheduled to different nodes in that AZ.
    • Equivalent mode: Deployment pods of the add-on are evenly scheduled to the nodes in the cluster in each AZ. If a new AZ is added, you are advised to increase add-on pods for cross-AZ HA deployment. With the Equivalent multi-AZ deployment, the difference between the number of add-on pods in different AZs will be less than or equal to 1. If resources in one of the AZs are insufficient, pods cannot be scheduled to that AZ.
    • Forcible: Deployment pods of the add-on are forcibly scheduled to nodes in different AZs. There can be at most one pod in each AZ. If nodes in a cluster are not in different AZs, some add-on pods cannot run properly. If a node is faulty, the add-on pods on it may fail to be migrated.
    Node Affinity
    • Not configured: Node affinity is disabled for the add-on pods.
    • Specify node: Specify the nodes where the add-on pods are deployed. If you do not specify the nodes, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
    • Specify node pool: Specify the node pool where the add-on pods are deployed. If you do not specify the node pools, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
    • Customize affinity: Enter the labels of the nodes where the add-on pods are to be deployed for more flexible scheduling policies. If you do not specify node labels, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
      If multiple custom affinity policies are configured, ensure that there are nodes that meet all the affinity policies in the cluster. Otherwise, the add-on pods cannot run.
    Toleration
    Using both taints and tolerations enables (but does not require) the add-on's Deployment pods to be scheduled on nodes with matching taints, and allows control over pod eviction policies when host nodes are tainted.
    The add-on applies default tolerations for the node.kubernetes.io/not-ready and node.kubernetes.io/unreachable taints. The toleration time window is 60 seconds.
    For details, see Configuring Tolerance Policies.
  6. Click Install.
Components
Table 5 Add-on components
Component
Resource Type
CoreDNS
DNS server for clusters
Deployment
Configuring CoreDNS Using Corefile
If you install the CoreDNS add-on, the Corefile view configuration is not available. This configuration is supported only when you are editing or upgrading the add-on.
  2. In the navigation pane, choose Add-ons. Locate CoreDNS on the right and click Edit.
  3. In the Parameters area, select whether to enable Corefile View (supported by add-on 1.30.3 and later versions).
    Once the function is enabled, the ConfigMap of CoreDNS in the kube-system namespace will be directly configured in the Corefile format. Any existing stub domain configurations and parameters such as parameterSyncStrategy, servers, and upstream_nameservers in the advanced settings will no longer be in effect. It is important to verify that the Corefile configuration is accurate.
    For description of the Corefile format, see Configuration.
    • Once the Corefile view is disabled, the ConfigMap of CoreDNS will continue to be configured based on to the stub domain configurations and parameters such as parameterSyncStrategy, servers, and upstream_nameservers in the advanced settings. It is important to verify that the configuration is correct during the function switchover.
    • Once the Corefile view is enabled, the add-on can be upgraded. However, if the Corefile view is disabled again, the add-on upgrade will override the current configurations. To complete the upgrade, parameterSyncStrategy must be set to either force or inherit.
    • Once the Corefile ConfigMap has been modified, simply wait for CoreDNS' reload mechanism to automatically update the configuration. This typically takes about 10 seconds for the changes to take effect.
  4. After editing the Corefile, click OK.
How Does Domain Name Resolution Work in Kubernetes?
DNS policies can be configured per pod. Kubernetes supports DNS policies Default, ClusterFirst, ClusterFirstWithHostNet, and None. For details, see DNS for Services and Pods. These policies are specified in the pod-specific dnsPolicy field.
  • Default: Pods inherit the name resolution configuration from the node that the pods run on. The custom upstream DNS server and the stub domain cannot be used together with this policy.
  • ClusterFirst: Any DNS query that does not match the configured cluster domain suffix, such as www.kubernetes.io, is forwarded to the upstream name server inherited from the node. Cluster administrators may have extra stub domains and upstream DNS servers configured.
  • ClusterFirstWithHostNet: For pods running with hostNetwork, use ClusterFirstWithHostNet.
  • None: It allows a pod to ignore DNS settings in a Kubernetes environment. All DNS settings should be provided using the dnsPolicy field in dnsConfigPod.
  • Clusters of Kubernetes v1.10 and later support Default, ClusterFirst, ClusterFirstWithHostNet, and None. Clusters earlier than Kubernetes v1.10 support only Default, ClusterFirst, and ClusterFirstWithHostNet.
  • Default is not the default DNS policy. If dnsPolicy is not explicitly specified, ClusterFirst is used.
Routing
Without stub domain configurations: Any query that does not match the configured cluster domain suffix, such as www.kubernetes.io, is forwarded to the upstream DNS server inherited from the node.
With stub domain configurations: If stub domains and upstream DNS servers are configured, DNS queries are routed according to the following flow:
  1. The query is first sent to the DNS caching layer in CoreDNS.
  2. From the caching layer, the suffix of the request is examined and then the request is forwarded to the corresponding DNS:
    • Names with the cluster suffix, for example, .cluster.local: The request is sent to CoreDNS.
    • Names with the stub domain suffix, for example, .acme.local: The request is sent to the configured custom DNS resolver that listens, for example, on 1.2.3.4.
    • Names that do not match the suffix, for example, widget.com: The request is forwarded to the upstream DNS.
Figure 1 Routing
Helpful Links
Release History
Table 6 CoreDNS updates
Add-on Version
Supported Cluster Version
New Feature
Community Version
1.30.99
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Fixed some issues.
1.11.4
1.30.95
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Supported CCE clusters v1.36.
1.11.4
1.30.94
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
Fixed some issues.
1.11.4
1.30.73
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
Supported CCE clusters v1.35.
1.11.4
1.30.67
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Fixed some issues.
1.11.4
1.30.61
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Fixed some issues.
1.11.4
1.30.45
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Supported CCE clusters v1.34.
1.11.4
1.30.43
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Fixed some issues.
1.11.4
1.30.37
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Supported CCE clusters v1.33.
1.11.4
1.30.33
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
Supported CCE clusters v1.32.
1.11.4
1.30.30
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Fixed some issues.
1.11.4
1.30.29
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Supported CCE clusters v1.31.
1.11.4
1.30.6
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
  • Supported Corefile configurations.
  • Supported CCE clusters v1.30.
1.10.1
1.29.5
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
Fixed some issues.
1.10.1
1.29.4
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
Supported CCE clusters v1.29.
1.10.1
1.28.7
v1.21
v1.23
v1.25
v1.27
v1.28
Supported hot module replacement. Rolling upgrade is not required.
1.10.1
1.28.5
v1.21
v1.23
v1.25
v1.27
v1.28
Fixed some issues.
1.10.1
1.28.4
v1.21
v1.23
v1.25
v1.27
v1.28
Supported CCE clusters v1.28.
1.10.1
1.27.4
v1.19
v1.21
v1.23
v1.25
v1.27
None
1.10.1
1.25.14
v1.19
v1.21
v1.23
v1.25
  • Supported association between add-on specifications and cluster specifications.
  • Synchronized time zones used by the add-on and the nodes.
1.10.1
1.25.11
v1.19
v1.21
v1.23
v1.25
  • Supported anti-affinity scheduling of add-on pods on nodes in different AZs.
  • Upgrades to its community version 1.10.1.
1.10.1
1.25.1
v1.19
v1.21
v1.23
v1.25
Supported CCE clusters v1.25.
1.8.4
1.23.3
v1.15
v1.17
v1.19
v1.21
v1.23
Regular upgrade of add-on dependencies
1.8.4
1.23.2
v1.15
v1.17
v1.19
v1.21
v1.23
1.8.4
1.23.1
v1.15
v1.17
v1.19
v1.21
v1.23
Supported CCE clusters v1.23.
1.8.4
1.17.15
v1.15
v1.17
v1.19
v1.21
Supported CCE clusters v1.21.
1.8.4
1.17.9
v1.15
v1.17
v1.19
1.8.4
1.17.7
v1.15
v1.17
v1.19
Updated the add-on to its community version 1.8.4.
1.8.4
1.17.4
v1.17
v1.19
Supported CCE clusters v1.19.
1.6.5
1.17.3
v1.17
Supported clusters v1.17 and fixed stub domain configuration issues.
1.6.5
1.17.1
v1.17
Supported clusters v1.17.
1.6.5
