Help Center/ Cloud Backup and Recovery/ User Guide/ Data Restoration/ Restoring from a Cloud Disk Backup
Updated on 2026-07-09 GMT+08:00
You can use a disk backup to restore the disk to its state when the backup was created.
Before restoring the disk data, stop the server to which the disk is attached and detach the disk from the server. After the disk data is restored, attach the disk to the server and start the server.
  • The disk to be restored is Available.
  • The server is stopped and the disk is detached from the server. After the disk data is restored, attach the disk to the server and start the server.
  • If the server OS is changed after the system disk is backed up, the system disk backup cannot be restored to the original system disk due to reasons such as disk UUID change. You can use the system disk backup to create a new disk and copy data to the original system disk.
  • When restoring from a cloud disk backup, the backup can only be restored to the original disk. To restore backup of a data disk to a system disk, see How Do I Restore a Data Disk Backup to a System Disk?
  • Concurrent data restoration is not supported.
  1. Log in to the CBR console. Click in the upper left corner and select a region.
  2. Click the Backups tab. Locate the desired backup. For details, see Viewing a Backup.
  3. In the row of the backup, click Restore Disk. The Restore Disk dialog box is displayed.
    Figure 1 Locating the target backup
    • The EVS disk data will be overwritten by the data captured at the time of backup. The restoration cannot be undone.
    • If the restore button is grayed out, stop the server, detach the disk, and try again. After the disk data is restored, attach the disk to the server and start the server.
    Figure 2 Restore Disk
  4. Confirm the information as prompted and enter YES. Click Yes. You can check whether data is successfully restored on the Backups tab of Cloud Disk Backups or on the EVS console.
    When the backup status changes to Available, the restoration is successful. The resource is restored to the state when that backup was created.
  5. After the restoration is complete, re-attach the disk to the server. For details, see Attaching a Non-Shared Disk.
    If the restoration takes a long time, click the target backup name in the backup list. On the backup details page, check the value of Instant Restore Support. If the value is No, the current backup is not an enhanced backup. Therefore, the restoration takes a long time. You are advised to manually create a full backup for the resources. The new backup is an enhanced backup and can then be used to restore resources.
