GaussDB(DWS) Source Table (Not Recommended)
Updated on 2024-09-29 GMT+08:00
Function
DLI reads data of Flink jobs from GaussDB(DWS). GaussDB(DWS) database kernel is compliant with PostgreSQL. The PostgreSQL database can store data of more complex types and deliver space information services, multi-version concurrent control (MVCC), and high concurrency. It applies to location applications, financial insurance, and e-Commerce.
GaussDB(DWS) is an online data processing database based on the cloud infrastructure and platform and helps you mine and analyze massive sets of data. For more information about GaussDB(DWS), see Data Warehouse Service Management Guide.
You are advised to use GaussDB(DWS) self-developed GaussDB(DWS) connector.
For how to use the GaussDB(DWS) connector, see dws-connector-flink.
  • You have created a GaussDB(DWS) cluster.
    For details about how to create a GaussDB(DWS) cluster, see Creating a Cluster in the Data Warehouse Service Management Guide.
  • You have created a GaussDB(DWS) database table.
  • An enhanced datasource connection has been created for DLI to connect to GaussDB(DWS) clusters, so that jobs can run on the dedicated queue of DLI and you can set the security group rules as required.
  • In Flink cross-source development scenarios, there is a risk of password leakage if datasource authentication information is directly configured. You are advised to use the datasource authentication provided by DLI.
    For details about datasource authentication, see Introduction to Datasource Authentication.
Precautions
  • When you create a Flink OpenSource SQL job, set Flink Version to 1.15 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs.
  • Storing authentication credentials such as usernames and passwords in code or plaintext poses significant security risks. It is recommended using DEW to manage credentials instead. Storing encrypted credentials in configuration files or environment variables and decrypting them when needed ensures security. For details, see Flink OpenSource SQL Jobs Using DEW to Manage Access Credentials.
  • Fields in the with parameter can only be enclosed in single quotes.
Syntax
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
create table dwsSource (
  attr_name attr_type
  (',' attr_name attr_type)*
  (','PRIMARY KEY (attr_name, ...) NOT ENFORCED)
  (',' watermark for rowtime_column_name as watermark-strategy_expression)
with (
  'connector' = 'gaussdb',
  'url' = '',
  'table-name' = '',
  'username' = '',
  'password' = ''
Parameters
Table 1 Parameter description
Mandatory
Default Value
Data Type
connector
Yes
None
String
Connector to be used. Set this parameter to gaussdb.
url
Yes
None
String
JDBC connection address. Set the IP address in this parameter to the internal IP address of GaussDB(DWS).
If you use the gsjdbc4 driver, set the value in jdbc:postgresql://${ip}:${port}/${dbName} format.
If you use the gsjdbc200 driver, set the value in jdbc:gaussdb://${ip}:${port}/${dbName} format.
table-name
Yes
None
String
Name of the GaussDB(DWS) table to be operated. If the GaussDB(DWS) table is in a schema, refer to the description of GaussDB(DWS) table in a schema.
driver
No
org.postgresql.Driver
String
JDBC connection driver. The default value is org.postgresql.Driver.
  • If you use the gsjdbc4 driver for connection, set this parameter to org.postgresql.Driver.
  • If you use the gsjdbc200 driver for connection, set this parameter to com.huawei.gauss200.jdbc.Driver.
username
No
None
String
Username for GaussDB(DWS) database authentication. This parameter must be configured in pair with password.
password
No
None
String
Password for GaussDB(DWS) database authentication. This parameter must be configured in pair with username.
scan.partition.column
No
None
String
Name of the column used to partition the input.
Note: This parameter must be used together with scan.partition.lower-bound, scan.partition.upper-bound, and scan.partition.num.
No
None
Integer
Lower bound of values to be fetched for the first partition.
This parameter must be used together with scan.partition.column, scan.partition.upper-bound, and scan.partition.num.
No
None
Integer
Upper bound of values to be fetched for the last partition.
This parameter must be used together with scan.partition.column, scan.partition.lower-bound, and scan.partition.num.
scan.partition.num
No
None
Integer
Number of partitions to be created.
This parameter must be used together with scan.partition.column, scan.partition.upper-bound, and scan.partition.upper-bound.
scan.fetch-size
No
0
Integer
Number of rows fetched from the database each time. The default value is 0, indicating that the number of rows is not limited.
Example
In this example, data is read from the GaussDB(DWS) data source and written to the Print result table. The procedure is as follows:
  1. Create a table named dws_order in GaussDB(DWS).
    create table public.dws_order(
      order_id VARCHAR,
      order_channel VARCHAR,
      order_time VARCHAR,
      pay_amount FLOAT8,
      real_pay FLOAT8,
      pay_time VARCHAR,
      user_id VARCHAR,
      user_name VARCHAR,
      area_id VARCHAR);
    Insert data into the dws_order table.
    insert into public.dws_order
      (order_id,
      order_channel,
      order_time,
      pay_amount,
      real_pay,
      pay_time,
      user_id,
      user_name,
      area_id) values
      ('202103241000000001', 'webShop', '2021-03-24 10:00:00', '100.00', '100.00', '2021-03-24 10:02:03', '0001', 'Alice', '330106'),
      ('202103251202020001', 'miniAppShop', '2021-03-25 12:02:02', '60.00', '60.00', '2021-03-25 12:03:00', '0002', 'Bob', '330110');
  2. Create an enhanced datasource connection in the VPC and subnet where GaussDB(DWS) locates, and bind the connection to the required Flink elastic resource pool. For details, see Enhanced Datasource Connections.
  3. Set GaussDB(DWS) security groups and add inbound rules to allow access from the Flink queue. Test the connectivity using the GaussDB(DWS) address by referring to Testing Address Connectivity. If the connection is successful, the datasource is bound to the queue. Otherwise, the binding fails.
  4. Create a Flink OpenSource SQL job. Enter the following job script and submit the job. The job script uses the GaussDB(DWS) data source and the Print result table.
    When you create a job, set Flink Version to 1.15 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs. Change the values of the parameters in bold as needed in the following script.
    CREATE TABLE dwsSource (
      order_id string,
      order_channel string,
      order_time string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) WITH (
      'url' = 'jdbc:postgresql://DWSIP:DWSPort/DWSdbName',
      'table-name' = 'dws_order',
      'driver' = 'org.postgresql.Driver',
      'username' = 'DWSUserName',
      'password' = 'DWSPassword'
    CREATE TABLE printSink (
      order_id string,
      order_time string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) WITH (
      'connector' = 'print'
    insert into printSink select * from dwsSource;
  5. Perform the following operations to view the data result in the taskmanager.out file:
    1. Log in to the DLI console. In the navigation pane, choose Job Management > Flink Jobs.
    2. Click the name of the corresponding Flink job, choose Run Log, click OBS Bucket, and locate the folder of the log you want to view according to the date.
    3. Go to the folder of the date, find the folder whose name contains taskmanager, download the taskmanager.out file, and view result logs.
    The data result is as follows:
    +I(202103241000000001,webShop,2021-03-24 10:00:00,100.0,100.0,2021-03-24 10:02:03,0001,Alice,330106)
    +I(202103251202020001,miniAppShop,2021-03-25 12:02:02,60.0,60.0,2021-03-25 12:03:00,0002,Bob,330110)
FAQ
  • Q: What should I do if the job execution fails and the log contains the following error information?
    java.io.IOException: unable to open JDBC writer
    Caused by: org.postgresql.util.PSQLException: The connection attempt failed.
    Caused by: java.net.SocketTimeoutException: connect timed out
    A: The datasource connection is not bound or the binding fails.
  • Q: How can I configure a GaussDB(DWS) table that is in a schema?
    A: The following provides an example of configuring the dws_order table in the dbuser2 schema:
      order_id string,
      order_time string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) WITH (
      'table-name' = 'dbuser2.dws_order',
