Updated on 2026-09-08 GMT+08:00
Overview
What Is Datasource Authentication?
When analyzing across multiple sources, you are advised not to configure authentication information directly in a job as it can lead to password leakage. Instead, you are advised to use either DEW or datasource authentication provided by DLI to securely store data source authentication information.
  • DEW is designed to address critical challenges such as data security, key security, and the complexities of key management. You are advised to use DEW to securely store authentication credentials for your data sources.
    For cross-source access scenarios involving Spark 3.3.1 or later versions, as well as Flink 1.15 or later versions, we strongly advise using DEW to manage your data source authentication information. This approach ensures robust solutions for data security, key protection, and streamlined key management. For details, see Managing Data Source Access Credentials Using DEW.
  • Datasource authentication is used to manage authentication information for accessing specified data sources. After datasource authentication is configured, you do not need to repeatedly configure data source authentication information in jobs, improving data source authentication security while enabling DLI to securely access data sources.
    When SQL and Flink 1.12 jobs access data sources using datasource connections, use DLI's datasource authentication feature to manage data source access credentials.
This section describes how to use datasource authentication provided by DLI.
Notes and Constraints
Table 1 Notes and constraints on datasource authentication
Item
Use case
  • Only Spark SQL and Flink OpenSource SQL 1.12 jobs support datasource authentication.
  • Flink jobs can use datasource authentication only on queues created after May 1, 2023.
Datasource authentication type
  • DLI supports four types of datasource authentication. Select an authentication type specific to each data source.
    • CSS: applies to 6.5.4 or later CSS clusters with the security mode enabled.
    • Kerberos: applies to MRS security clusters with Kerberos authentication enabled.
    • Kafka_SSL: applies to Kafka with SSL enabled.
    • Password: applies to DWS, RDS, DDS, and DCS.
Datasource Authentication Types
  • CSS: applies to 6.5.4 or later CSS clusters with the security mode enabled. During the configuration, you need to specify the username, password, and authentication certificate of the cluster and store the information in DLI through datasource authentication so that DLI can securely access CSS data sources. For details, see Creating a CSS Datasource Authentication.
  • Kerberos: applies to MRS security clusters with Kerberos authentication enabled. During the configuration, you need to specify MRS cluster authentication credentials, including the krb5.conf and user.keytab files. For details, see Creating a Kerberos Datasource Authentication.
  • Kafka_SSL: applies to Kafka with SSL enabled. During the configuration, you need to specify the KafkaTruststore path and password. For details, see Creating a Kafka_SSL Datasource Authentication.
  • Password: applies to DWS, RDS, DDS, and DCS data sources. During the configuration, you need to store the passwords of the data sources in DLI. For details, see Creating a Password Datasource Authentication.
Jobs That Can Connect to Data Sources Through Datasource Authentication
Different types of jobs can connect to data sources through different types of datasource authentication.
  • For details about the data sources that Spark SQL jobs can connect to through datasource authentication and their constraints, see Table 2.
  • For details about the data sources that Flink OpenSource SQL 1.12 jobs can connect to through datasource authentication and their constraints, see Table 3.
Table 2 Data sources that Spark SQL jobs can connect to through datasource authentication
Data Source
CSS
CSS
The cluster version is 6.5.4 or later.
The security mode has been enabled for the cluster.
Password
DWS, RDS, DDS, and Redis
Table 3 Data sources that Flink OpenSource SQL 1.12 jobs can connect to through datasource authentication
Table Type
Data Source
Source table
Kerberos
HBase
Kerberos authentication has been enabled for the MRS cluster.
Kafka
Kerberos authentication has been enabled for MRS Kafka.
Kafka_SSL
Kafka
SASL_SSL authentication has been enabled for DMS Kafka.
SASL authentication has been enabled for MRS Kafka.
SSL authentication has been enabled for MRS Kafka.
Password
DWS, RDS, and Redis
Result table
Kerberos
HBase
Kafka
Kafka_SSL
Kafka
Password
DWS, RDS, CSS, and Redis
Dimension table
Kerberos
HBase
Password
DWS, RDS, and Redis
