Updated on 2026-03-10 GMT+08:00
Accessing Cloud Services from a Pod in the Same VPC
The method of accessing cloud services from a pod in the same VPC varies depending on the cluster's network model. For details, see Table 1 Accessing cloud services from a pod in the same VPC.
Network Model
Tunnel network
Data packets are encapsulated through tunnels in the node network. If the node access permission is limited, you will not be able to access resources from a pod in the same VPC. If you encounter an access failure, verify that the security group of the service you are trying to access allows access from the node where the pod is located.
VPC network
Pod traffic is forwarded through VPC routing. If the container CIDR block is different from the VPC CIDR block of the node, the pods cannot directly communicate with other IP addresses in the VPC. To access a service outside the cluster from a pod in the same VPC, you must configure the security group of the accessed service.
Cloud Native 2.0 network
Pods receive IP addresses from VPC CIDR blocks. Container CIDR blocks are part of the VPC subnet where the node is located. Therefore, the pods can directly communicate with other IP addresses in the VPC. If the access failed, check if the security group of the accessed service permits access from the container CIDR block.
Cloud services that communicate with CCE include ECS, ELB, RDS, DCS, Kafka, RabbitMQ, ModelArts, and DDS. To ensure successful communication, make sure your network is configured correctly and verify that the cloud service you want to access allows external access. For example, accessing DCS Redis requires being trustlisted. If you cannot configure the trustlist on the service console, create a service ticket in the target service. The following describes the operations and precautions for accessing an ECS from a pod and an RDS MySQL DB instance from a pod.
This part describes how to access an ECS or an RDS for MySQL DB instance from a pod in the same VPC.
The following uses a VPC network cluster as an example to describe how to configure security group rules for seamless access to an ECS in the same VPC. For example, the node CIDR block is 192.168.0.0/24, and the container CIDR block is 172.16.0.0/16.
  1. Buy an ECS. For details, see Purchasing and Using a Linux ECS (New Edition). The ECS and the cluster are in the same region and VPC, and the IP address of the ECS is 192.168.0.28.
  2. Log in to the pod. For details, see Logging In to a Container. Try to access the ECS from the pod.
    ping 192.168.0.28
    • If the ping command is available, execute it. If the following information is displayed, the access from the pod to the ECS failed:
      PING 192.168.0.28 (192.168.0.28): 56 data bytes
      --- 192.168.0.28 ping statistics ---
      104 packets transmitted, 0 packets received, 100% packet loss
    • If no ping command is available, add it.
      ping: command not found
      The following uses the Nginx:latest container as an example to describe how to add a ping command. If the ping command is already available, skip this step.
      1. Ensure that the pod can access the Internet. For details, see Accessing the Internet from a Pod.
      2. Update the local software package index.
        apt-get update
      3. Install the iputils-ping software package, which provides the ping command.
        apt-get install iputils-ping
      4. Access the ECS again.
        ping 192.168.0.28
        If the following information is displayed, the ping command has been added:
  3. Add the container CIDR block of the cluster to the inbound rules of the ECS security group so that all pods in the cluster can access the ECS. If you only want to grant access to the ECS from a specific pod in the cluster, you can add the IP address of that pod to the inbound rules of the ECS security group.
    1. On the console homepage, click in the upper left corner. Choose Service List > Compute > Elastic Cloud Server and click the ECS name.
    2. Click the Security Groups tab. In the left pane of the page, click Manage Rule. On the Inbound Rules tab, you can find that the source addresses include the CIDR block 192.168.0.0/18. Within this block, the node CIDR block 192.168.0.0/24 is included, but the container CIDR block 172.16.0.0/16 is not. For a cluster that uses a VPC network, you need to allow both the node CIDR block and container CIDR block in the ECS security group rules to access the ECS from a pod. However, for clusters using other types of networks, you only need to allow the node CIDR block in the ECS security group rules.
      Figure 1 Original inbound rules
    3. Click Add Rule and enter 172.16.0.0/16 in the Source text box. For details, see Figure 2.
      Figure 2 Adding a rule
  4. Check whether the pod can access the ECS in the same VPC. On CloudShell, run the following command again:
    ping 192.168.0.28
    If information similar to the following is displayed, the pod can access the ECS:
    64 bytes from 192.168.0.28: seq=0 ttl=64 time=1.412 ms
    64 bytes from 192.168.0.28: seq=1 ttl=64 time=1.400 ms
    64 bytes from 192.168.0.28: seq=2 ttl=64 time=1.299 ms
    64 bytes from 192.168.0.28: seq=3 ttl=64 time=1.283 ms
    4 packets transmitted, 4 packets received, 0% packet loss
This part uses a VPC network cluster as an example to describe how to configure security group rules for seamless access to an RDS for MySQL DB instance in the same VPC. For example, the node CIDR block is 192.168.0.0/24, and the container CIDR block is 172.16.0.0/16.
  1. Buy a DB instance. For details, see Buying a DB Instance and Connecting to It Using a MySQL Client. The DB instance and the cluster are in the same region and VPC, and the IP address of the DB instance is 192.168.10.10.
  2. Log in to the pod. For details, see Logging In to a Container. Try to access the DB instance from the pod.
    ping 192.168.10.10
    • If the ping command is available, execute it. If the following information is displayed, the access from the pod to the DB instance failed:
      PING 192.168.10.10 (192.168.10.10): 56 data bytes
      --- 192.168.10.10 ping statistics ---
        apt-get update
      4. Access the DB instance again.
        ping 192.168.10.10
  3. Add the container CIDR block of the cluster to the inbound rules of the DB instance security group so that all pods in the cluster can access the DB instance. If you only want to grant access to the DB instance from a specific pod in the cluster, you can add the IP address of that pod to the inbound rules of the DB instance security group.
    1. On the console homepage, click in the upper left corner. Choose Service List > Databases > Relational Database Service. On the Instances page, click the DB instance name.
    2. In the navigation pane, choose Connectivity & Security. In the Security Group Rules area, click the security group rule. On the Inbound Rules tab, you can find that the source addresses include the CIDR block 192.168.0.0/18. Within this block, the node CIDR block 192.168.0.0/24 is included, but the container CIDR block 172.16.0.0/16 is not. For a cluster that uses a VPC network, you need to allow both the node and container CIDR blocks in the security group rules of the DB instance to access the DB instance from a pod. However, for clusters that use other types of networks, you only need to allow the node CIDR block in the security group rules of the DB instance.
      Figure 3 Original inbound rules
    3. Click Add Rule and enter 172.16.0.0/16 in the Source text box. For details, see Figure 4.
      Figure 4 Adding a rule
  4. Check whether the pod can access the DB instance. On CloudShell, run the following command again:
    ping 192.168.10.10
    If information similar to the following is displayed, the pod can access the DB instance:
    64 bytes from 192.168.10.10: seq=0 ttl=64 time=1.412 ms
    64 bytes from 192.168.10.10: seq=1 ttl=64 time=1.400 ms
    64 bytes from 192.168.10.10: seq=2 ttl=64 time=1.299 ms
    64 bytes from 192.168.10.10: seq=3 ttl=64 time=1.283 ms
Troubleshooting a Pod Access Failure
If a pod cannot access a network, rectify the fault by referring to Table 2. If the fault persists, submit a service ticket to contact Huawei Cloud customer service.
Table 2 Troubleshooting methods
Check Item
Possible Fault
Solution
Security group rules of the accessed service
One of the following issues may be the cause of the failure:
  • The security group's inbound rules prevent access to the node CIDR block or container CIDR block.
  • The security group's inbound rules permit access to the node CIDR block and container CIDR block, but the protocol is improperly configured.
    NOTICE:
    Run the ping command and use ICMP to test network connectivity. Before doing so, enable the ICMP port in the security group rule.
Trustlist
The trustlist for the accessed service does not have the node CIDR block or container CIDR block configured.
Add the container CIDR block and node CIDR block to the trustlist. Find more information in the help document for the relevant service.
Domain name resolution
When accessing an external domain name, the pod uses its cluster's domain name resolution to resolve the destination address and accesses the address based on the pod's network policy. However, sometimes the domain name cannot be resolved, resulting in errors. The most common errors are listed below:
  • "Name or service not known"
  • "Temporary failure in name resolution"
  • "Unable to resolve hostname"
  • "DNS resolution failed"
  • "Could not resolve MYHOST (nodename nor servname known)", where MYHOST refers to the domain name that cannot be resolved
Locate the cause of the DNS exception. For details, see DNS Overview for troubleshooting.
Network policy (applicable only to tunnel networks)
If you have configured a network policy for both your tunnel network cluster and the namespace where the pod is located, the network policy may prevent the pod from accessing the destination address.
If so, modify the network policy. For details, see Configuring Network Policies to Restrict Pod Access.
