Help Center/ Virtual Private Cloud/ User Guide/ Traffic Mirroring/ Traffic Mirroring Example Scenarios/ Mirroring Inbound and Outbound TCP Traffic to a Network Interface in a Different VPC
Updated on 2026-09-18 GMT+08:00
Solution Architecture
To mirror inbound and outbound TCP traffic between a mirror source (network interface) and a given instance to a mirror target (network interface) in a VPC different from the mirror source, you can refer to the configurations in this section. In Figure 1, mirror source ECS-source and mirror target ECS-target are running in different VPCs (VPC-A and VPC-B that are connected by a VPC peering connection). Traffic between ECS-source and ECS-test-A does not need to be mirrored. To mirror TCP traffic between ECS-source and ECS-test-B to ECS-target, a mirror session needs to be created. In this example, mirror session mirror-session-01 is created. You can configure it as follows:
  • Set the mirror source to network-interface-s on ECS-source. The inbound and outbound TCP traffic on this network interface will be mirrored.
  • Set the mirror target to network-interface-t on ECS-target. The inbound and outbound TCP traffic on network-interface-s will be mirrored to network-interface-t.
  • Create a mirror filter (mirror-filter-01) and add the following rules:
    • Two outbound rules: Rule 1 rejects TCP traffic from ECS-source to ECS-test-A. Rule 2 accepts TCP traffic from ECS-source to ECS-test-B.
    • Two inbound rules: Rule 1 rejects TCP traffic from ECS-test-A to ECS-source. Rule 2 accepts TCP traffic from ECS-test-B to ECS-source.
Figure 1 Mirroring inbound and outbound TCP traffic to a mirror target in a different VPC
Notes and Constraints
See Notes and Constraints.
Resource Planning
In this example, the VPCs, subnets, EIP, and ECSs must be in the same region but can be in different AZs.
The following resource details are only for your reference. You can modify them if needed.
Table 1 Resource details for mirroring inbound and outbound TCP traffic
Resource
Quantity
VPC and subnet
VPC: 2
Subnet: 2
Configure the VPCs as follows:
  • Name: Set it as needed. In this example, VPC-A and VPC-B are used.
  • VPC IPv4 CIDR Block: Set it as needed. In this example, 192.168.0.0/16 is used for VPC-A, and 10.0.0.0/16 is used for VPC-B.
  • Subnet Name: Set it as needed. In this example, there are two subnets: Subnet-A01 in VPC-A and Subnet-B01 in VPC-B.
  • Subnet IPv4 CIDR Block: Set it as needed. In this example, the CIDR block of Subnet-A01 is 192.168.0.0/24 and that of Subnet-B01 is 10.0.1.0/24.
ECS
4
Configure the ECSs as follows:
  • ECS Name: Set it as needed. In this example, the ECSs are named ECS-source, ECS-target, ECS-test-A, and ECS-test-B.
  • ECS Type: In this example, the type of ECS-source is General computing-plus c7t. Currently, only the elastic network interfaces of ECSs of certain types can be used as mirror sources. For details, see Notes and Constraints. There are no constraints on the types of other ECSs.
  • Image: Set it as needed. In this example, public image Huawei Cloud EulerOS 2.0 Standard 64 bit is used.
  • System Disk: In this example, a general-purpose SSD disk of 40 GiB is used.
  • Data Disk: Set it as needed. In this example, no data disk is used.
  • Network
    • VPC: Select VPCs. In this example, select VPC-A for ECS-source and ECS-test-A, and VPC-B for ECS-target and ECS-test-B.
    • Subnet: Select subnets. In this example, select Subnet-A01 for ECS-source and ECS-test-A, and Subnet-B01 for ECS-target and ECS-test-B.
  • Security Group: In this example, the four ECSs are associated with the same security group (Sg-X). Ensure that all rules in Table 2 are added.
    If the ECSs are associated with different security groups, you also need to add additional rules.
    • If ECS-test-A is associated with Sg-X but ECS-source is associated with Sg-A, add the rules in Table 3 to Sg-A and Sg-X to allow traffic between ECS-test-A and ECS-source. The same applies to ECS-test-B.
    • If ECS-source is associated with Sg-A but ECS-target is associated with Sg-B, add the rules in Table 4 to Sg-B to allow UDP packets encapsulated by the mirror source to access the mirror target over port 4789.
  • EIP: Select Not required.
  • Private IP address: In this example, use 192.168.0.230 for ECS-source, 10.0.1.97 for ECS-target, 192.168.0.161 for ECS-test-A, and 10.0.1.156 for ECS-test-B.
EIP
  • Billing Mode: Set it as needed. In this example, Pay-per-use is used.
  • EIP Name: Set it as needed. In this example, EIP-A is used.
  • EIP: The EIP is randomly assigned. In this example, 124.X.X.187 is used.
  • VPC Peering Connection Name: Set it as needed. In this example, Peering-AB is used.
  • Local VPC: Select a VPC as needed. In this example, select VPC-A and its CIDR block is 192.168.0.0/16.
  • Account: In this example, VPC-A and VPC-B are in the same account. Select My account.
    Traffic cannot be mirrored across VPCs in different accounts.
  • Peer Project: Retain the default value.
  • Peer VPC: Select a VPC as needed. In this example, select VPC-B and its CIDR block is 10.0.0.0/16.
  • Add the routes in Table 5 for the VPC peering connection.
Mirror filter
  • Name: Set it as needed. In this example, mirror-filter-01 is used.
  • Inbound rules: Add the two inbound rules in Table 6.
    • Rule 1: rejects TCP traffic from all instances, including ECS-test-A, in VPC-A to mirror source ECS-source.
    • Rule 2: accepts TCP traffic from all instances, including ECS-test-B, in VPC-B to mirror source ECS-source.
  • Outbound rules: Add the two outbound rules in Table 6.
    • Rule 1: rejects TCP traffic from mirror source ECS-source to instances, including ECS-test-A, in VPC-A.
    • Rule 2: accepts TCP traffic from mirror source ECS-source to instances, including ECS-test-B, in VPC-B.
Mirror session
  • Basic Information
    • Name: Set it as needed. In this example, mirror-session-01 is used.
    • Priority: Set it as needed. In this example, 1 is used.
    • VNI: Set it as needed. In this example, 1 is used.
    • Packet Length: Set it as needed. In this example, 96 is used.
    • Mirror Session: Enable it to mirror the traffic from the mirror source.
  • Associate Mirror Filter: Set it as needed. In this example, mirror-filter-01 is used.
  • Associate Mirror Sources: Set it as needed. In this example, the private IP address (192.168.0.230) of the network interface on ECS-source is used.
  • Associate Mirror Target
    • Type: Network interface
    • Network interface: Set it as needed. In this example, the private IP address (10.0.1.97) of the network interface of ECS-target is used.
Table 2 Security group Sg-X rules
Direction
Action
Type
Protocol & Port
Source/Destination
Inbound
Allow
IPv4
TCP: 22
Source: 0.0.0.0/0
Allows remote logins to Linux ECSs over SSH port 22.
Inbound
Allow
IPv4
TCP: 3389
Source: 0.0.0.0/0
Allows remote logins to Windows ECSs over RDP port 3389.
Inbound
Allow
IPv4
All
Source: current security group (Sg-X)
Allows the ECSs in this security group to communicate with each other using IPv4 addresses.
Inbound
Allow
IPv6
All
Allows the ECSs in this security group to communicate with each other using IPv6 addresses.
Outbound
Allow
IPv4
All
Destination: 0.0.0.0/0
Allows ECSs in this security group to access the external networks using IPv4 addresses.
Outbound
Allow
IPv6
All
Destination: ::/0
Allows ECSs in this security group to access external networks using IPv6 addresses.
If the source of an inbound rule is set to 0.0.0.0/0, all external IP addresses are allowed to remotely log in to your cloud server. Exposing port 22 or 3389 to the public network will leave your instances vulnerable to network risks. To address this issue, set the source to a known IP address, for example, the IP address of your local PC.
Table 3 Rules for security groups Sg-A and Sg-X to allow traffic between ECSs
Security Group
Direction
Action
Type
Protocol & Port
Source
Sg-A
Inbound
Allow
IPv4
TCP: 1234
The security group with which ECS-test-A is associated:
Sg-X
Allows TCP packets from ECS-test-A to ECS-source over port 1234.
Sg-X
Inbound
Allow
IPv4
TCP: All ports
The security group with which ECS-source is associated:
Sg-A
Allows TCP packets from ECS-source to ECS-test-A over all ports.
Table 4 Security group Sg-B rule
Direction
Action
Type
Protocol & Port
Source
Inbound
Allow
IPv4
UDP: 4789
The private IP address of mirror source ECS-source:
192.168.0.230/32
Allows UDP packets encapsulated by ECS-source to access ECS-target over port 4789.
Table 5 Routes for the VPC peering connection
VPC
Route Table
Destination
Next Hop
VPC-A
rtb-VPC-A (default)
VPC-B CIDR block:
10.0.0.0/16
VPC peering connection: Peering-AB
Route from VPC-A to VPC-B
VPC-B
rtb-VPC-B (default)
VPC-A CIDR block:
192.168.0.0/16
Route from VPC-B to VPC-A
Table 6 Inbound and outbound rules of the mirror filter
Direction
Priority
Protocol
Action
Type
Source
Source Port Range
Destination
Destination Port Range
Inbound
TCP
Reject
IPv4
VPC-A CIDR block:
192.168.0.0/16
All
VPC-A CIDR block:
192.168.0.0/16
All
Inbound
2
TCP
Accept
IPv4
VPC-B CIDR block:
10.0.0.0/16
All
The private IP address of ECS-source:
192.168.0.230/32
Port of ECS-source:
1234-1234
Outbound
TCP
Reject
IPv4
VPC-A CIDR block:
192.168.0.0/16
All
VPC-A CIDR block:
192.168.0.0/16
All
Outbound
2
TCP
Accept
IPv4
192.168.0.230/32
All
VPC-B CIDR block:
10.0.0.0/16
Port of ECS-test-B:
1234-1234
Figure 2 shows the procedure required to mirror the inbound and outbound TCP traffic between a mirror source (network interface) and a given instance to a mirror target (network interface) in a different VPC from the mirror source.
Figure 2 Mirroring inbound and outbound TCP traffic to a mirror target in a different VPC
Step 1: Create Cloud Resources
  1. Create two VPCs, each with a subnet.
    For details, see Creating a VPC with a Subnet.
  2. Create four ECSs.
    For details, see Purchasing an ECS in Custom Config Mode.
  3. Assign an EIP.
    For details, see Assigning an EIP.
Step 2: Create a VPC Peering Connection
Create a VPC peering connection to connect VPC-A and VPC-B by referring to Creating a VPC Peering Connection to Connect Two VPCs in the Same Account.
Add forward and return routes to the route tables of VPC-A and VPC-B so that the two VPCs can communicate with each other. For details, see Table 5.
Step 3: Create a Mirror Filter and a Mirror Session
  1. Create a mirror filter.
    For details, see Creating a Mirror Filter.
  2. Create a mirror session, and associate the mirror filter, mirror source, and mirror target with this mirror session.
    For details, see Creating a Mirror Session.
Step 4: Install Netcat (nc) to Simulate Traffic
The nc utility reads and writes data across network connections using TCP or UDP. It is usually used to test ports for accessibility. You need to install nc on ECS-source, ECS-test-A, and ECS-test-B.
  1. Install nc on ECS-source.
    1. Bind the EIP to ECS-source to connect to the Internet for downloading the nc utility.
      For details, see Binding an EIP.
    2. Remotely log in to ECS-source.
      For details, see How Do I Log In to My ECS?
    3. Run the following commands in sequence to install nc:
      sudo yum update
      Information similar to the following is displayed:
      [root@ecs-source ~]# sudo yum update
      HCE 2.0 base        55 MB/s | 6.1 MB     00:00
      HCE 2.0 updates        98 MB/s |  14 MB     00:00
      Last metadata expiration check: 0:00:01 ago on Tue 10 Sep 2024 05:54:28 PM CST.
      Dependencies resolved.
      Nothing to do.
      Complete!
      sudo yum install nc
      If information similar to the following is displayed, enter y as prompted and press Enter:
      [root@ecs-source ~]# sudo yum install nc
      Last metadata expiration check: 0:00:12 ago on Tue 10 Sep 2024 05:54:28 PM CST.
      Install  2 Packages
      Total download size: 6.1 M
      Installed size: 25 M
      Is this ok [y/N]: y
      Downloading Packages:
      Importing GPG key 0xA8DEF926:
       Userid     : "XXX"
       Fingerprint: C1BA 9CD4 9D03 A206 E241 F176 28DA 5B77 A8DE F926
      Is this ok [y/N]: y
      Installed:
        libssh2-1.10.0-2.r10.hce2.x86_64                                                               nmap-2:7.92-2.r4.hce2.x86_64
      Complete!
    4. Unbind the EIP from ECS-source after nc is installed.
      For details, see Unbinding an EIP.
  2. Repeat 1.a to 1.d on ECS-test-A.
  3. Repeat 1.a to 1.d on ECS-test-B.
  4. Release the EIP.
    For details, see Unbinding an EIP. If you do not release the EIP, the EIP will continue to be billed.
Step 5: Check Whether the Mirror Session Rejects the Traffic Between ECS-source and ECS-test-A
Check whether the mirror session rejects the traffic between ECS-source and ECS-test-A.
  1. Establish a TCP connection between ECS-source and ECS-test-A.
    Use ECS-source to send TCP packets to ECS-test-A and check whether ECS-test-A can receive the packets.
    1. Run the following command on ECS-source to listen to port 1234:
      nc -l <listening-port-of-mirror-source-ECS-source>
      Example command:
      nc -l 1234
      If the command output is empty, the port is opened for listening.
    2. Run the following command on ECS-test-A to establish a TCP connection between ECS-source and ECS-test-A:
      nc <private-IP-address-of-mirror-source-ECS-source> <listening-port-of-mirror-source-ECS-source>
      Example command:
      nc 192.168.0.230 1234
      If the command output is empty, the TCP connection has been established.
    3. Enter any information (for example, hello) on ECS-source and press Enter to check whether requests can be sent over the TCP connection.
      [root@ecs-source ~]# nc -l 1234
      hello
    4. Check whether ECS-test-A can receive "hello" from ECS-source.
      If information similar to the following is displayed, the TCP connection is successfully established.
      [root@ecs-test-a ~]# nc 192.168.0.230 1234
      hello
  2. Check whether the outbound TCP packet from ECS-source to ECS-test-A can be mirrored to ECS-target.
    When ECS-source sends a TCP packet to ECS-test-A, run tcpdump to check whether ECS-target can receive the packet. If ECS-target does not receive the packet, the mirror session rejects the outbound TCP traffic.
    1. Remotely log in to ECS-target.
    2. Run the following command on ECS-target to view its network interface name:
      ifconfig
      Information similar to the following is displayed. In this example, the network interface of the mirror target is eth0.
      [root@ecs-target ~]# ifconfig
      eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
              inet 10.0.1.97  netmask 255.255.255.0  broadcast 10.0.1.255
              inet6 fe80::f816:3eff:fea0:a101  prefixlen 64  scopeid 0x20<link>
              ether fa:16:3e:a0:a1:01  txqueuelen 1000  (Ethernet)
              RX packets 103445  bytes 119352826 (113.8 MiB)
              RX errors 0  dropped 0  overruns 0  frame 0
              TX packets 34118  bytes 15630293 (14.9 MiB)
              TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    3. Run the following command on ECS-target to check whether it can receive the packet:
      tcpdump -i <network-interface-name-of-the-mirror-target> udp port 4789 -nne
      Example command:
      tcpdump -i eth0 udp port 4789 -nne
      [root@ecs-target ~]# tcpdump -i eth0 udp port 4789 -nne
      dropped privs to tcpdump
      tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
      listening on eth0, link-type EN10MB (Ethernet), snapshot length 262144 bytes
    4. Enter any information (for example, to testa) on ECS-source and press Enter to send a TCP packet to ECS-test-A.
      hello
      to testa
    5. Check whether ECS-test-A can receive "to testa" from ECS-source.
      If information similar to the following is displayed, ECS-test-A can receive "to testa" from ECS-source.
      hello
      to testa
    6. Check whether ECS-target can receive the packet.
      If the information similar to the following is displayed, the packet containing "to testa" from ECS-source is not sent to ECS-test-A after running tcpdump. This means the reject rule works.
  3. Check whether the inbound TCP packets from ECS-test-A to ECS-source can be mirrored to ECS-target.
    When ECS-test-A sends a TCP packet to ECS-source, run tcpdump to check whether ECS-target can receive the packet. If ECS-target does not receive the packet, the mirror session rejects the inbound TCP traffic.
    1. Enter any information (for example, testa to source) on ECS-test-A and press Enter to send a TCP packet to ECS-source.
      hello
      to testa
      testa to source
    2. Check whether ECS-source can receive "testa to source" from ECS-test-A.
      If information similar to the following is displayed, ECS-source can receive "testa to source" from ECS-test-A.
      hello
      to testa
      testa to source
    3. Check whether ECS-target can receive the TCP packet.
      If the information similar to the following is displayed, the packet containing "testa to source" from ECS-test-A is not sent to ECS-source after running tcpdump. This means the reject rule works.
Step 6: Check Whether the Mirror Session Accepts the Traffic Between ECS-source and ECS-test-B
Check whether the mirror session accepts the traffic between ECS-source and ECS-test-B.
  1. Establish a TCP connection between ECS-source and ECS-test-B.
    Use ECS-test-B to send TCP packets to ECS-source and check whether ECS-source can receive the packets.
    1. Run the following command on ECS-test-B to listen to port 1234:
      nc -l <listening-port-of-ECS-test-B>
      Example command:
      nc -l 1234
    2. Run the following command on ECS-source to establish a TCP connection between ECS-source and ECS-test-B:
      nc <private-IP-address-of-ECS-test-B> <listening-port-of-ECS-test-B>
      Example command:
      nc 10.0.1.156 1234
    3. Enter any information (for example, hello) on ECS-test-B and press Enter to check whether requests can be sent over the TCP connection.
      [root@ecs-test-b ~]# nc -l 1234
      hello
    4. Check whether ECS-source can receive "hello" from ECS-test-B.
      [root@ecs-source ~]# nc 10.0.1.156 1234
      hello
  1. Check whether the outbound TCP packet from ECS-source to ECS-test-B can be mirrored to ECS-target.
    When ECS-source sends a TCP packet to ECS-test-B, run tcpdump to check whether ECS-target can receive the packet. If ECS-target receives the packet, the mirror session accepts the outbound TCP traffic.
      ifconfig
    3. Run the following command on ECS-target to check whether it can receive packets:
      Example command:
    4. Enter any information (for example, to testb) on ECS-source and press Enter to send a TCP packet to ECS-test-B.
      hello
      to testb
    5. Check whether ECS-test-B can receive "to testb" from ECS-source.
      If information similar to the following is displayed, ECS-test-B can receive "to testb" from ECS-source.
      hello
      to testb
    6. Check whether ECS-target can receive the TCP packet.
      If the information similar to the following is displayed, the packet containing "to testb" (time: 17:28:48.772658) from ECS-source is sent to ECS-test-B after running tcpdump. This means the accept rule works. In this packet, vni 1 is the identifier of mirror-session-01, indicating that ECS-target can receive the packet through this mirror session. The packet content has two parts: a VXLAN packet encapsulated by traffic mirroring and the original packet. For details, see Table 6.
      17:28:48.772658 fa:16:3e:6e:42:80 > fa:16:3e:a0:a1:01, ethertype IPv4 (0x0800), length 125: 192.168.0.230.32821 > 10.0.1.97.4789: VXLAN, flags [I] (0x08), vni 1
      fa:16:3e:7e:d6:bc > fa:16:3e:d1:6b:5d, ethertype IPv4 (0x0800), length 75: 192.168.0.230.44906 > 10.0.1.156.1234: Flags [P.], seq 935460393:935460402, ack 4279496885, win 502, options [nop,nop,TS val 1414482596 ecr 3323401462], length 9
  2. Check whether the inbound TCP packets from ECS-test-B to ECS-source can be mirrored to ECS-target.
    When ECS-test-B sends a TCP packet to ECS-source, run tcpdump to check whether ECS-target can receive the packet. If ECS-target receives the packet, the mirror session accepts the inbound TCP traffic.
    1. Enter any information (for example, testb to source) on ECS-test-B and press Enter to send a TCP packet to ECS-source.
      hello
      to testb
      testb to source
    2. Check whether ECS-source can receive "testb to source" from ECS-test-B.
      If information similar to the following is displayed, ECS-source can receive "testb to source" from ECS-test-B.
      hello
      to testb
      testb to source
      If the information similar to the following is displayed, the packet containing "testb to source" (time: 17:30:26.193420) from ECS-test-B is sent to ECS-source after running tcpdump. This means the accept rule works. In this packet, vni 1 is the identifier of mirror-session-01, indicating that ECS-target can receive the packet through this mirror session. The packet content has two parts: a VXLAN packet encapsulated by traffic mirroring and the original packet. For details, see Table 6.
      17:30:26.193420 fa:16:3e:6e:42:80 > fa:16:3e:a0:a1:01, ethertype IPv4 (0x0800), length 116: 192.168.0.230.32821 > 10.0.1.97.4789: VXLAN, flags [I] (0x08), vni 1
      fa:16:3e:7e:d6:bc > fa:16:3e:d1:6b:5d, ethertype IPv4 (0x0800), length 66: 192.168.0.230.44906 > 10.0.1.156.1234: Flags [.], ack 17, win 502, options [nop,nop,TS val 1414580016 ecr 3323563970], length 0
