Updated on 2026-09-01 GMT+08:00
Simple Upload (PUT)
If the size of an object, such as a text file, an image, or a video, to be uploaded is smaller than 5 GB, you can use simple upload (PUT).
Parameters sent by PUT are passed in the request header. You need to specify the object name in the URL. An example request is as follows:
PUT /ObjectName HTTP/1.1
OBS allows you to upload objects to buckets in a specified region, but Huawei Cloud does not inspect the content you upload. If your object uploads involve cross-border transfer, ensure that your use complies with relevant laws and regulations.
  • You have the write permissions to a bucket.
  • If you want to classify files, you can create folders and upload files to different folders. For details, see Creating Folders.
Limits
Size and number of objects
  • If a file is smaller than 5 GB, use simple upload. To upload a file larger than 5 GB, refer to Multipart Upload.
  • You can set a bucket quota to limit the total size of objects the bucket can store. For details, see Managing Bucket Quotas.
Object naming
See Guidelines on Naming Object Keys.
Batch operations
Batch uploads are available only when:
  1. The bucket is in the CN-Hong Kong, AP-Bangkok, or AP-Singapore region.
  2. The bucket version is 3.0. To view a bucket version, see Checking Your OBS Version (OBS 2.0 or OBS 3.0).
Folder uploads
You can upload folders using OBS Console, OBS Browser+, or obsutil.
Other
  • Versioning is not enabled for a bucket:
    • If you upload a new file with the same name as the one in the bucket, the new file will automatically overwrite the previous one and the ACL information of the previous file will not be retained.
    • If you upload a new folder with the same name as the one in the bucket, the two folders will be merged, and files in the new folder will overwrite those with the same name in the previous folder.
  • Versioning is enabled for a bucket: If you upload a new file with the same name as the one you previously uploaded to the bucket, a new file version will be added to the bucket. For details, see Versioning.
Ways to Upload Objects
You can use OBS Console, APIs, SDKs, OBS Browser+, or obsutil to upload objects.
To improve the upload success rate, OBS Console automatically uses multipart upload for objects larger than 8 MB, and OBS Browser+ and obsutil automatically use resumable upload (essentially multipart upload) for objects larger than 50 MB. You will not perceive any backend switchovers, as your operations on OBS Console or tools keep unchanged.
