Configuring, Editing, and Viewing Object Metadata
Object metadata is a set of name-value pairs that describe an object and is used for object management. OBS has two types of metadata: system-defined object metadata and user-defined object metadata. System-defined metadata includes the object's creation date, size, and storage class. User-defined metadata is the metadata that you can set for an object to identify the purpose or properties of the object.
You can configure metadata for an OBS object during upload. After the upload, you can also add or edit metadata for the object.
System-Defined Object Metadata
There are two types of system-defined metadata: system-controlled and user-controlled.
- System-controlled: metadata that is controlled by the system and cannot be edited by users, for example, LastModified
- User-controlled: metadata whose value you can control. For example, if you use an OBS bucket to host a static web page and you might want to redirect requests for the hosted page to another page or an external URL, you can configure WebsiteRedirectLocation for the page. In this case, OBS stores the redirection value as system metadata that you can control. Table 1 lists the metadata items that you can control.
| Metadata | Description | User-Modifiable |
| ContentDisposition | Controls how a browser handles the content it receives. Especially during file downloads, this metadata directs the browser to either display the file inline or prompt the user to download it to their device, optionally with a specified filename. The metadata values can be:
NOTE: If the file name contains special characters, it may be escaped when the file is downloaded to the local device. To ensure that the file name is correctly displayed in different browsers, you can use URL encoding or RFC 5987 encoding. The following gives some examples:
For more information, see the definition of ContentDisposition in the HTTP protocol. | Yes |
| ContentLanguage | States the language or languages intended for the audience. The metadata values can be:
NOTE: Separate multiple languages with commas (,), for example, Content-Language: en-US, fr-FR. For more information, see the definition of Content-Language in the HTTP protocol. | Yes |
| WebsiteRedirectLocation | Redirects requests for an object to another object or an external URL. If redirection is configured for an object, the response returned upon a request for that object will include the WebsiteRedirectLocation header to tell the URL to which the request should be redirected. The redirection is implemented using static website hosting. The format is WebsiteRedirectLocation: <url>, where <url> indicates the target URL of redirection. OBS only supports redirection for objects in a bucket's root directory. Redirection for objects in the bucket's folders is not supported. For example, you can redirect requests for an object by doing as follows:
| Yes |
| ContentEncoding | Specifies the content encoding format when an object is downloaded. This metadata tells a client to decode objects according to their encoding format, so that the content can be correctly displayed or processed. The value options are as follows:
| Yes |
| CacheControl | Specifies the caching behavior for a web page when an object is downloaded. The value options are as follows:
| Yes |
| Expires | Specifies the cache expiration time (GMT). | Yes |
| ContentType | Specifies the object type. It determines the format and encoding method a browser will use to read the file. For details, see Table 2. | Yes |
| Date | Specifies the current date and time. Example: WED, 01 Jul 2015 04:19:21 GMT | No |
| Content-Length | Specifies the object size. Unit: byte | No |
| Last-Modified | Specifies the date and time when an object was first uploaded or last modified. Example: WED, 01 Jul 2015 04:19:21 GMT In a multipart upload, the object's creation date is when the multipart upload started. | No |
| ETag | Base64-encoded 128-bit MD5 digest of an object. ETag is the unique identifier of the object content. It reflects whether the object content is changed. For example, if the ETag value is A when an object is uploaded but is B when the object is downloaded, it means that the object content has been changed. The ETag value is a hash of the object. | No |
| x-obs-tagging-count | The number of tags associated with an object. For example, x-obs-tagging-count:1 indicates that the object has one tag. | No |
| x-obs-version-id | The object version ID. When versioning is enabled for a bucket, OBS assigns a version ID to each object in the bucket. For more information, see Enabling, Suspending, and Viewing Versioning. | No |
| x-obs-storage-class | The storage class of an object. The value can be:
| Yes |
Object Metadata Content-Type
When you access an object through a web browser, the browser uses the object's Content-Type to determine how to handle and display the object. You can change an object's Content-Type based on its file name extension.
- When uploading an object through an API, you must specify the Content-Type. If the Content-Type is not specified, it defaults to binary/octet-stream when you download the object.
- If you upload an object through OBS Console, OBS automatically assigns the Content-Type based on the file name extension of the object.
- If the value of Content-Type does not match the file name extension, the file name extension will change after the file is downloaded.
| File Name Extension | Content-Type | File Name Extension | Content-Type |
| .* (binary stream, unknown file type) | application/octet-stream | .7z | application/x-7z-compressed |
| .001 | application/x-001 | .301 | application/x-301 |
| .323 | text/h323 | .906 | application/x-906 |
| .907 | drawing/907 | .a11 | application/x-a11 |
| .acp | audio/x-mei-aac | .ai | application/postscript |
| .aif | audio/aiff | .aifc | audio/aiff |
| .aiff | audio/aiff | .anv | application/x-anv |
| .asa | text/asa | .asf | video/x-ms-asf |
| .asp | text/asp | .asx | video/x-ms-asf |
| .au | audio/basic | .avi | video/avi |
| .awf | application/vnd.adobe.workflow | .biz | text/xml |
| .bmp | application/x-bmp | .bot | application/x-bot |
| .c4t | application/x-c4t | .c90 | application/x-c90 |
| .cal | application/x-cals | .cat | application/vnd.ms-pki.seccat |
| .cdf | application/x-netcdf | .cdr | application/x-cdr |
| .cel | application/x-cel | .cer | application/x-x509-ca-cert |
| .cg4 | application/x-g4 | .cgm | application/x-cgm |
| .cit | application/x-cit | .class | java/* |
| .cml | text/xml | .cmp | application/x-cmp |
| .cmx | application/x-cmx | .cot | application/x-cot |
| .crl | application/pkix-crl | .crt | application/x-x509-ca-cert |
| .csi | application/x-csi | .css | text/css |
| .cut | application/x-cut | .dbf | application/x-dbf |
| .dbm | application/x-dbm | .dbx | application/x-dbx |
| .dcd | text/xml | .dcx | application/x-dcx |
| .der | application/x-x509-ca-cert | .dgn | application/x-dgn |
| .dib | application/x-dib | .dll | application/x-msdownload |
| .doc | application/msword | .dot | application/msword |
| .drw | application/x-drw | .dtd | text/xml |
| .dwf | Model/vnd.dwf | .dwf | application/x-dwf |
| .dwg | application/x-dwg | .dxb | application/x-dxb |
| .dxf | application/x-dxf | .edn | application/vnd.adobe.edn |
| .emf | application/x-emf | .eml | message/rfc822 |
| .ent | text/xml | .epi | application/x-epi |
| .eps | application/x-ps | .eps | application/postscript |
| .etd | application/x-ebx | .exe | application/x-msdownload |
| .fax | image/fax | .fdf | application/vnd.fdf |
| .fif | application/fractals | .fo | text/xml |
| .frm | application/x-frm | .g4 | application/x-g4 |
| .gbr | application/x-gbr | . | application/x- |
| .gif | image/gif | .gl2 | application/x-gl2 |
| .gp4 | application/x-gp4 | .hgl | application/x-hgl |
| .hmr | application/x-hmr | .hpg | application/x-hpgl |
| .hpl | application/x-hpl | .hqx | application/mac-binhex40 |
| .hrf | application/x-hrf | .hta | application/hta |
| .htc | text/x-component | .htm | text/html |
| .html | text/html | .htt | text/webviewhtml |
| .htx | text/html | .icb | application/x-icb |
| .ico | image/x-icon | .ico | application/x-ico |
| .iff | application/x-iff | .ig4 | application/x-g4 |
| .igs | application/x-igs | .iii | application/x-iphone |
| .img | application/x-img | .ins | application/x-internet-signup |
| .isp | application/x-internet-signup | .IVF | video/x-ivf |
| .java | java/* | .jfif | image/jpeg |
| .jpe | image/jpeg | .jpe | application/x-jpe |
| .jpeg | image/jpeg | .jpg | image/jpeg |
| .jpg | application/x-jpg | .js | application/x-javascript |
| .jsp | text/html | .la1 | audio/x-liquid-file |
| .lar | application/x-laplayer-reg | .latex | application/x-latex |
| .lavs | audio/x-liquid-secure | .lbm | application/x-lbm |
| .lmsff | audio/x-la-lms | .ls | application/x-javascript |
| .ltr | application/x-ltr | .m1v | video/x-mpeg |
| .m2v | video/x-mpeg | .m3u | audio/mpegurl |
| .m4e | video/mpeg4 | .mac | application/x-mac |
| .man | application/x-troff-man | .math | text/xml |
| .mdb | application/msaccess | .mdb | application/x-mdb |
| .mfp | application/x-shockwave-flash | .mht | message/rfc822 |
| .mhtml | message/rfc822 | .mi | application/x-mi |
| .mid | audio/mid | .midi | audio/mid |
| .mil | application/x-mil | .mml | text/xml |
| .mnd | audio/x-musicnet-download | .mns | audio/x-musicnet-stream |
| .mocha | application/x-javascript | .movie | video/x-sgi-movie |
| .mp1 | audio/mp1 | .mp2 | audio/mp2 |
| .mp2v | video/mpeg | .mp3 | audio/mp3 |
| .mp4 | video/mp4 | .mpa | video/x-mpg |
| .mpd | application/vnd.ms-project | .mpe | video/x-mpeg |
| .mpeg | video/mpg | .mpg | video/mpg |
| .mpga | audio/rn-mpeg | .mpp | application/vnd.ms-project |
| .mps | video/x-mpeg | .mpt | application/vnd.ms-project |
| .mpv | video/mpg | .mpv2 | video/mpeg |
| .mpw | application/vnd.ms-project | .mpx | application/vnd.ms-project |
| .mtx | text/xml | .mxp | application/x-mmxp |
| .net | image/pnetvue | .nrf | application/x-nrf |
| .nws | message/rfc822 | .odc | text/x-ms-odc |
| .out | application/x-out | .p10 | application/pkcs10 |
| .p12 | application/x-pkcs12 | .p7b | application/x-pkcs7-certificates |
| .p7c | application/pkcs7-mime | .p7m | application/pkcs7-mime |
| .p7r | application/x-pkcs7-certreqresp | .p7s | application/pkcs7-signature |
| .pc5 | application/x-pc5 | .pci | application/x-pci |
| .pcl | application/x-pcl | .pcx | application/x-pcx |
| | application/pdf | | application/pdf |
| .pdx | application/vnd.adobe.pdx | .pfx | application/x-pkcs12 |
| .pgl | application/x-pgl | .pic | application/x-pic |
| .pko | application/vnd.ms-pki.pko | .pl | application/x-perl |
| .plg | text/html | .pls | audio/scpls |
| .plt | application/x-plt | .png | image/png |
| .png | application/x-png | .pot | application/vnd.ms-powerpoint |
| .ppa | application/vnd.ms-powerpoint | .ppm | application/x-ppm |
| .pps | application/vnd.ms-powerpoint | .ppt | application/vnd.ms-powerpoint |
| .ppt | application/x-ppt | .pr | application/x-pr |
| .prf | application/pics-rules | .prn | application/x-prn |
| .prt | application/x-prt | .ps | application/x-ps |
| .ps | application/postscript | .ptn | application/x-ptn |
| .pwz | application/vnd.ms-powerpoint | .r3t | text/vnd.rn-realtext3d |
| .ra | audio/vnd.rn-realaudio | .ram | audio/x-pn-realaudio |
| .ras | application/x-ras | .rat | application/rat-file |
| .rdf | text/xml | .rec | application/vnd.rn-recording |
| .red | application/x-red | .rgb | application/x-rgb |
| .rjs | application/vnd.rn-realsystem-rjs | .rjt | application/vnd.rn-realsystem-rjt |
| .rlc | application/x-rlc | .rle | application/x-rle |
| .rm | application/vnd.rn-realmedia | .rmf | application/vnd.adobe.rmf |
| .rmi | audio/mid | .rmj | application/vnd.rn-realsystem-rmj |
| .rmm | audio/x-pn-realaudio | .rmp | application/vnd.rn-rn_music_package |
| .rms | application/vnd.rn-realmedia-secure | .rmvb | application/vnd.rn-realmedia-vbr |
| .rmx | application/vnd.rn-realsystem-rmx | .rnx | application/vnd.rn-realplayer |
| .rp | image/vnd.rn-realpix | .rpm | audio/x-pn-realaudio-plugin |
| .rsml | application/vnd.rn-rsml | .rt | text/vnd.rn-realtext |
| .rtf | application/msword | .rtf | application/x-rtf |
| .rv | video/vnd.rn-realvideo | .sam | application/x-sam |
| .sat | application/x-sat | .sdp | application/sdp |
| .sdw | application/x-sdw | .sit | application/x-stuffit |
| .slb | application/x-slb | .sld | application/x-sld |
| .slk | drawing/x-slk | .smi | application/smil |
| .smil | application/smil | .smk | application/x-smk |
| .snd | audio/basic | .sol | text/plain |
| .sor | text/plain | .spc | application/x-pkcs7-certificates |
| .spl | application/futuresplash | .spp | text/xml |
| .ssm | application/streamingmedia | .sst | application/vnd.ms-pki.certstore |
| .stl | application/vnd.ms-pki.stl | .stm | text/html |
| .sty | application/x-sty | .svg | text/xml |
| .swf | application/x-shockwave-flash | .tdf | application/x-tdf |
| .tg4 | application/x-tg4 | .tga | application/x-tga |
| .tif | image/tiff | .tif | application/x-tif |
| .tiff | image/tiff | .tld | text/xml |
| .top | drawing/x-top | .torrent | application/x-bittorrent |
| .tsd | text/xml | .txt | text/plain NOTE: If you want to preview a TXT file online, set Content-Type to text/plain;charset=UTF-8 to avoid garbled characters. |
| .uin | application/x-icq | .uls | text/iuls |
| .vcf | text/x-vcard | .vda | application/x-vda |
| .vdx | application/vnd.visio | .vml | text/xml |
| .vpg | application/x-vpeg005 | .vsd | application/vnd.visio |
| .vsd | application/x-vsd | .vss | application/vnd.visio |
| .vst | application/vnd.visio | .vst | application/x-vst |
| .vsw | application/vnd.visio | .vsx | application/vnd.visio |
| .vtx | application/vnd.visio | .vxml | text/xml |
| .wav | audio/wav | .wax | audio/x-ms-wax |
| .wb1 | application/x-wb1 | .wb2 | application/x-wb2 |
| .wb3 | application/x-wb3 | .wbmp | image/vnd.wap.wbmp |
| .wiz | application/msword | .wk3 | application/x-wk3 |
| .wk4 | application/x-wk4 | .wkq | application/x-wkq |
| .wks | application/x-wks | .wm | video/x-ms-wm |
| .wma | audio/x-ms-wma | .wmd | application/x-ms-wmd |
| .wmf | application/x-wmf | .wml | text/vnd.wap.wml |
| .wmv | video/x-ms-wmv | .wmx | video/x-ms-wmx |
| .wmz | application/x-ms-wmz | .wp6 | application/x-wp6 |
| .wpd | application/x-wpd | .wpg | application/x-wpg |
| .wpl | application/vnd.ms-wpl | .wq1 | application/x-wq1 |
| .wr1 | application/x-wr1 | .wri | application/x-wri |
| .wrk | application/x-wrk | .ws | application/x-ws |
| .ws2 | application/x-ws | .wsc | text/scriptlet |
| .wsdl | text/xml | .wvx | video/x-ms-wvx |
| .xdp | application/vnd.adobe.xdp | .xdr | text/xml |
| .xfd | application/vnd.adobe.xfd | .xfdf | application/vnd.adobe.xfdf |
| .xhtml | text/html | .xlsx | application/vnd.openxmlformats-officedocument.spreadsheetml.sheet |
| .xls | application/x-xls | .xlw | application/x-xlw |
| .xml | text/xml | .xpl | audio/scpls |
| .xq | text/xml | .xql | text/xml |
| .xquery | text/xml | .xsd | text/xml |
| .xsl | text/xml | .xslt | text/xml |
| .xwd | application/x-xwd | .x_b | application/x-x_b |
| .sis | application/vnd.symbian.install | .sisx | application/vnd.symbian.install |
| .x_t | application/x-x_t | .ipa | application/vnd.iphone |
| .apk | application/vnd.android.package-archive | .xap | application/x-silverlight-app |
| .zip | application/zip | .rar | application/x-rar-compressed |
User-Defined Object Metadata
You can add user-defined metadata headers that start with x-obs-meta- for easy object management. When you retrieve an object or query its metadata, any user-defined metadata added will appear in the response.
- An object's checksum and its associated algorithm are stored as part of the object metadata. Metadata provides additional information about an object and is not included in the actual object content.
- When you use a KMS key to encrypt an object, KMS encrypts only the actual content of the object. If you use OBS server-side encryption to encrypt an object, both the object's actual content and checksum are encrypted. The encrypted checksum is then stored in the object metadata. For more information about server-side encryption, see Server-Side Encryption Overview.
- A checksum (the x-obs-meta-md5chksum user-defined metadata) is used to verify data integrity and consistency. It is usually calculated using an algorithm (for example, MD5).
- To add the gid and uid metadata, mount the parallel file system using obsfs and add the metadata through file semantics. For details, see Mounting a Parallel File System.
User-defined object metadata must meet the following requirements:
- All user-defined metadata is limited to 8 KB in size. The size of user-defined metadata is the sum of the number of bytes in the UTF-8 encoding of each key and value.
- User-defined metadata keys are case insensitive, but OBS stores them in lowercase. The user-defined metadata values are case sensitive.
1 2 3 4 5 6 7
PUT /key HTTP/1.1 Host: bucket01.obs.myhuaweicloud.com x-obs-meta-Test1: Test Meta1 HEAD /Key HTTP/1.1 Host: bucket01.obs.myhuaweicloud.com x-obs-meta-test1: Test Meta1
- Both user-defined metadata keys and their values must conform to US-ASCII. If non-ASCII or unrecognizable characters are necessary, they must be encoded or decoded in URL or Base64 on the client side. The server side does not perform any decoding.
- In a versioning-enabled bucket, you can only configure metadata for the latest version of an object, but not for historical versions.
- Metadata cannot be configured for Archive or Deep Archive objects.
- The total size of user-defined metadata is limited to 8 KB.
- For the permissions required to configure, edit, or view object metadata, see Object Actions.
Ways to Configure Object Metadata
You can configure object metadata through OBS Console or APIs.
Using OBS Console
- In the navigation pane of OBS Console, choose Buckets.
- In the bucket list, click the desired bucket. The Objects page is displayed.
- Click the required object name to go to the object details page.
- On the Metadata tab, click Add and specify metadata information. For details about how to fill in the metadata name and value, see Metadata Introduction. Figure 1 Adding metadata
- Click OK.
Using APIs
Using the CLI Tool - obsutil
Command Line Structure
- Windows
- Setting properties of a single object
obsutil chattri obs://bucket/key [-meta=aaa:bbb#ccc:ddd] [-sc=xxx] [-acl=xxx] [-aclXml=xxx] [-versionId=xxx] [-fr] [-o=xxx] [-config=xxx] [-e=xxx] [-i=xxx] [-k=xxx] [-t=xxx]
- Setting properties of objects in batches
obsutil chattri obs://bucket[/key] -r [-f] [-v] [-meta=aaa:bbb#ccc:ddd] [-sc=xxx] [-acl=xxx] [-aclXml=xxx] [-o=xxx] [-j=1] [-config=xxx] [-e=xxx] [-i=xxx] [-k=xxx] [-t=xxx]
- macOS or Linux
./obsutil chattri obs://bucket/key [-meta=aaa:bbb#ccc:ddd] [-sc=xxx] [-acl=xxx] [-aclXml=xxx] [-versionId=xxx] [-fr] [-o=xxx] [-config=xxx] [-e=xxx] [-i=xxx] [-k=xxx] [-t=xxx]
./obsutil chattri obs://bucket[/key] -r [-f] [-v] [-meta=aaa:bbb#ccc:ddd] [-sc=xxx] [-acl=xxx] [-aclXml=xxx] [-o=xxx] [-j=1] [-config=xxx] [-e=xxx] [-i=xxx] [-k=xxx] [-t=xxx]
Examples
- In Windows, run obsutil chattri obs://bucket-test/key -acl=public-read to set the object ACL to public read.
obsutil chattri obs://bucket-test/key -acl=public-read Start at 2024-09-30 08:17:15.5572914 +0000 UTC Set the acl of object [key] in the bucket [bucket-test] to [public-read] successfully, request id [04050000016836DDFA73B2B5320E2651]
- In Windows, run obsutil chattri obs://bucket-test -r -f -acl=public-read to set the ACL of all objects in the bucket to public read.
obsutil chattri obs://bucket-test -r -f -acl=public-read Start at 2024-09-30 08:18:03.105373 +0000 UTC [------------------------------------------------] 100.00% tps:155.15 5/5 233ms Succeed count: 5 Failed count: 0 Metrics [max cost:177 ms, min cost:53 ms, average cost:102.40 ms, average tps:20.41] Task id: 9d7f73ff-f747-4fdd-9b2a-815ba2dc3b07
Parameter Description
| Parameter | Optional or Mandatory | Description |
| bucket | Mandatory | The name of the bucket to which an object belongs |
| key | Mandatory when setting properties of an object. Optional when setting properties of objects in batches. | The name of the object whose properties are to be set, or the name prefix of objects whose properties are to be set in batches If this parameter is left blank during batch operation, properties of all objects in the bucket are set. |
| meta | Optional (additional parameter) | The standard or user-defined metadata that can be specified for an object when setting properties of the object
This parameter must be used together with direct. |
| direct | Optional (additional parameter) | The metadata operation indicator The value can be:
This parameter must be used together with meta. |
| sc | Optional (additional parameter) | The storage class of an object. The value can be:
For an object whose storage class is cold, restore the object first and then specify its storage class. To restore an object, see Restoring an Object. |
| acl | Optional (additional parameter) | The predefined access control policy of an object. The value can be:
| aclXml | Optional (additional parameter) | The bucket's access control policy, in XML format. The format is as follows: <AccessControlPolicy>
<Owner>
<ID>ownerid</ID>
</Owner>
<AccessControlList>
<Grant>
<Grantee>
<ID>userid</ID>
</Grantee>
<Permission>[WRITE|WRITE_ACP|READ|READ_ACP|FULL_CONTROL]</Permission>
</Grant>
<Grant>
<Grantee>
<Canned>Everyone</Canned>
</Grantee>
</Grant>
</AccessControlList>
</AccessControlPolicy>
Because angle brackets (<) and (>) are unavoidably included in the parameter value, you must use quotation marks to enclose them for escaping when running the command. Use single quotation marks for Linux or macOS and double quotation marks for Windows. |
| fs | Optional (additional parameter) | Whether the method of listing parallel file systems is applied. If you are listing parallel file systems, you are recommended to add this parameter.
| versionId | Optional when setting properties of an object (additional parameter) | The version ID of the object whose properties are to be set |
| fr | Optional when setting properties of an object (additional parameter) | Generates an operation result file when setting properties of an object. |
| f | Optional when setting properties of objects in batches (additional parameter) | Performs operations without asking for confirmation. |
| r | Mandatory when setting properties of objects in batches (additional parameter) | Sets properties of objects in batches based on a specified object name prefix. |
| v | Optional when setting properties of objects in batches (additional parameter) | Sets properties of versions of objects in batches based on a specified object name prefix. |
| o | Optional (additional parameter) | The folder that stores the result files. After the command is executed, result files (including success and failure files) will be created in the specified folder. The default value is .obsutil_output, a subfolder in the user's home directory where obsutil commands are executed.
| j | Optional when setting properties of objects in batches (additional parameter) | The maximum number of concurrent tasks for setting object properties in batches. The default value is the value of defaultJobs in the configuration file. NOTE: The tool ensures that this value is at least 1. |
| bucket-cname | Optional (additional parameter) | The user-defined domain name bound to the bucket NOTE: This parameter is only supported by obsutil 5.7.9 and later. |
| config | Optional (additional parameter) | The user-defined configuration file for executing the current command. For details about parameters that can be configured, see Configuration Parameters. |
| e | Optional (additional parameter) | The endpoint |
| i | Optional (additional parameter) | The user's AK |
| k | Optional (additional parameter) | The user's SK |
| t | Optional (additional parameter) | The user's security token |
Only one from acl, sc, or aclXml can be set for each command.
Response
| Field | Description |
| Parallel | The parameter -p in the request |
| Jobs | The parameter -j in the request |
| Threshold | The parameter -threshold in the request |
| PartSize | The parameter -ps in the request |
| Exclude | The parameter -exclude in the request |
| Include | The parameter -include in the request |
| TimeRange | The parameter -timeRange in the request |
| VerifyLength | The parameter -vlength in the request |
| VerifyMd5 | The parameter -vmd5 in the request |
| CheckpointDir | The parameter -cpd in the request |
| OutputDir | The parameter -o in the request |
| ArcDir | The parameter -arcDir in the request |
| Succeed count | The number of successful tasks |
| Failed count | The number of failed tasks |
| Skip count | The number of tasks that are skipped during incremental upload, download, or copy, and synchronous upload, download, or copy. NOTE: Skipped tasks are recorded into successful tasks. |
| Warning count | The number of tasks that are executed successfully but contain warnings. NOTE:
| Succeed bytes | The number of bytes that are successfully uploaded |
| max cost | The maximum duration of all tasks, in ms |
| min cost | The minimum duration of all tasks, in ms |
| average cost | The average duration of all tasks, in ms |
| average tps | The average number of tasks completed per second |
| Task id | The unique ID of an operation, which is used to search for the result file generated for a batch task |
Ways to Edit Object Metadata
You can edit object metadata through OBS Console or APIs.
Using OBS Console
- On the Metadata tab, click Edit in the Operation column of the metadata to be edited. Figure 2 Editing the object metadata
- Change the metadata value and click OK. For more information, see Metadata Introduction.
Using APIs
- Windows
- macOS or Linux
Examples
<Owner>
<ID>ownerid</ID>
</Owner>
<AccessControlList>
<Grant>
<Grantee>
<ID>userid</ID>
</Grantee>
</Grant>
<Grant>
<Grantee>
</Grantee>
</Grant>
Response
Ways to View Object Metadata
You can view object metadata through OBS Console, SDKs, or obsutil, or APIs.
Using OBS Console
- On the Metadata tab, view the object metadata.
Using APIs
- Windows
obsutil stat obs://bucket/key [-acl][-bf=xxx] [-config=xxx] [-e=xxx] [-i=xxx] [-k=xxx] [-t=xxx]
- macOS or Linux
./obsutil stat obs://bucket/key [-acl][-bf=xxx] [-config=xxx] [-e=xxx] [-i=xxx] [-k=xxx] [-t=xxx]
Examples
- In Windows, run obsutil stat obs://bucket-test/key to query the basic properties of an object.
obsutil stat obs://bucket-test/key Start at 2024-09-25 04:48:10.1147483 +0000 UTC Key: obs://bucket-test/key LastModified: 2018-11-16T02:15:49Z Size: 7 StorageClass: standard ETag: 43d93b553855b0e1fc67e31c28c07b65 ContentType: text/plain Type: file Metadata: key=value
| key | Mandatory | The name of the object whose attributes are to be queried |
| acl | Optional | Queries the access control policies of the object at the same time. |
| bf | Optional (additional parameter) | The display format of the object size (in bytes). The value can be:
For common users, the human-readable format is easier to understand. For scenarios where accurate calculation or automatic processing is required, the raw format is more suitable. If this parameter is not configured, the display format of the object size (in bytes) is determined by the humanReadableFormat parameter in the configuration file. |
Response
| Key | The object name |
| LastModified | The latest modification time of the object |
| Size | The object size Unit: byte |
| StorageClass | The storage class of the object The value can be:
| MD5 | Real MD5 of the object. This parameter is used to ensure and verify data integrity. You can query this value only after running the cp command and configuring the -vmd5 parameter. |
| ETag | The ETag value of an object calculated on the server |
| ContentType | The file type of an object. It determines the format and encoding method a browser will use to read the file. For details about common ContentType values, see Content-Type Introduction. |
| Type | The file type |
| Metadata | The user-defined metadata of the object. This field can be queried only when the object has user-defined metadata. For details about user-defined object metadata, see User-defined Object Metadata. |
