- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Affected Application Management
Add affected applications after a WarRoom is started.
- Log in to COC.
- In the navigation pane on the left, choose Fault Management > WarRoom to view the war room list.
- Click a war room name in the war room list. The war room detail page is displayed.
- On the displayed page, click Add Affected Application.
- Set the information about the new affected application as prompted.
- Click OK.
Figure 1 New affected applications
- View the added applications on the main page. Enter the fault start time, recovery time, and fault description. Submit the modification and the application status becomes Recovered.
- Select and execute an emergency plan to quickly rectify faults of the affected application as needed. You can also view alarms, incidents, and changes of the application.
Figure 2 Affected application page
Parent topic: WarRoom
