Collecting NGINX Ingress Controller Logs
The Cloud Native Log Collection add-on can collect the logs of the NGINX Ingress Controller add-on. You can use the logs to analyze traffic changes and obtain service traffic characteristics for service decision making.
Notes and Constraints
- The NGINX Ingress Controller add-on (NGINX Ingress Controller) of version 2.2.82 or later, 2.6.32 or later, or 3.0.8 or later must be installed in the cluster.
- The Cloud Native Log Collection add-on (Cloud Native Log Collection) of version 1.6.0 or later must be installed in the cluster.
Billing
LTS does not charge you for creating log groups and offers a free quota for you to collect logs every month. You pay only for the log volume exceeding the quota. For details, see Price Calculator.
Step 1: Enabling Log Collection
The NGINX Ingress Controller add-on has been installed in the cluster, with log collection enabled.
After log collection is enabled, the default-stdout collection policy no longer collects logs of the NGINX Ingress Controller add-on.
- In the navigation pane, choose Add-ons.
- Find the NGINX Ingress Controller add-on and enable Logging.
- If the add-on has been installed, click Manage, locate the installed add-on instance, and click Edit. Then, enable Logging.
If multiple add-on instances are installed in the cluster, you need to modify the configuration of each add-on instance to collect logs of all instances.
- If the add-on is not installed, click Install. Then, enable Logging. Set other parameters as required. For details, see NGINX Ingress Controller.
Step 2: Collecting NGINX Ingress Controller Logs in Logging
To enable log collection for the NGINX Ingress Controller add-on in different scenarios, take the following steps.
If logging is not enabled for a cluster, you can select Collect add-on logs (NGINX Ingress Controller stdout logs) when enabling logging to create the default log collection policy for the NGINX Ingress Controller add-on.
- In the navigation pane, choose Logging.
- If you are not authorized, obtain required permissions first. Otherwise, skip this step.
In the displayed dialog box, click Authorize.
Figure 1 Adding authorization
- On the page that is displayed, select the type of logs to be collected and click Enable. Wait for about 30 seconds. The new page is automatically displayed. Figure 2 Enabling log collection
- Stdout logs: You can enable this option as needed. After it is enabled, a log collection policy named default-stdout will be created, which will report stdout logs from all namespaces to LTS.
- Kubernetes events: You can enable this option as needed. After it is enabled, a log collection policy named default-event will be created, which will report Kubernetes events from all namespaces to LTS.
- NGINX Ingress Controller stdout logs: This option is mandatory. You need to install the NGINX Ingress Controller add-on and enable logging for it.
After logging is enabled, a log policy named default-nginx-ingress will be created to collect stdout logs of NGINX Ingress Controller and report the logs to LTS.
If logging has been enabled for a cluster but log collection is not enabled for the NGINX Ingress Controller add-on, you can manually create a log collection policy.
- In the upper right corner, click View Log Collection Policies. All log collection policies in the current cluster are displayed.
- Click Create Log Collection Policy. Then, select Collect NGINX Ingress Controller stdout Logs and click OK. Figure 3 Creating a log collection policy
- (The system automatically creates a log collection policy named default-nginx-ingress.) Go to the Logging page and click the Add-on Logs tab to view the logs reported by the add-on to LTS. Figure 4 Viewing logs
Step 3: Viewing NGINX Ingress Controller Logs
- Click the Add-ons Log tab and select the NGINX Ingress Controller add-on. For details about related operations, see Log Tank Service User Guide. Figure 5 Viewing NGINX Ingress Controller logs
- (If multiple add-on instances are installed in the cluster and log collection has been enabled for these instances, logs of all instances will be displayed.) Search for logs by appName. The options of appName are as follows:
- If the NGINX Ingress Controller name is nginx, the value of appName is cceaddon-nginx-ingress-controller.
- If the NGINX Ingress Controller name is user-defined, for example, {className}, the value of appName is cceaddon-nginx-ingress-{className}-controller.
The following is an example of filtering cceaddon-nginx-ingress-controller logs. For details, see Log format.
appName : cceaddon-nginx-ingress-controller
Step 4: Viewing Dashboards of NGINX Ingress
CCE can collect NGINX ingress logs and use LTS for multi-dimensional analysis. You can configure log structuring and dashboards to meet monitoring requirements across different scenarios.
To view NGINX ingress dashboards, perform the following steps:
- Click the Add-on Logs tab and then the Dashboard tab. On the displayed tab, you can select different dashboard templates.
Supported dashboards include Monitoring Center Dashboard, Access Center Dashboard, and Second-by-Second Monitoring Dashboard. Each dashboard is described in the following section.
This dashboard displays basic information about NGINX Ingress in different time dimensions (relative time from now, relative time from last, and specified time), including:
- Access data: PV, UV, request success rate, average latency, the number of 4XX requests, the number of 404 requests, the number of 429 requests, the number of 5XX requests, the number of 504 requests, status code distribution, traffic, access failure rate, and latency
- Top statistics: hosts ranked by requests, hosts ranked by latencies, hosts ranked by failure rates, URLs ranked by requests, URLs ranked by latencies, URLs ranked by failure rates, backend servers ranked by requests, backend servers ranked by latencies, and backend servers ranked by failure rates
This dashboard displays access request statistics in different time dimensions (relative time from now, relative time from last, and specified time), including:
- Data comparison: day-over-day PV, week-over-week PV, day-over-day UV, week-over-week UV, PV/UV today, and PV/UV in past seven days
- Data distribution: PV distribution (China), PV distribution (global), UV distribution (China), UV distribution (global), average latency distribution (China), average latency distribution (global), device proportion (by terminal), and device proportion (by system)
- Top statistics: top 10 provinces with the most requests, top 10 cities with the most requests, top 10 hosts with the most requests, top 10 UserAgents with the most requests, top URLs with the most requests, and top IP addresses with the most requests
This dashboard displays NGINX Ingress traffic and application performance in real time, including QPS, success rates, latencies, traffic, status codes, and backend response codes.
Helpful Links
Log Format
For details about the NGINX Ingress Controller log format, see Log format.
Additional Log Management Features
Once collected, NGINX Ingress Controller logs are sent to LTS. You can then use additional features on the LTS console, such as log analysis and alarms. For details, see Log Tank Service.
