Updated on 2026-09-21 GMT+08:00
Node Pool View
The node pool view displays the usage and allocation of node pool resources, so you can better monitor the load of a node pool.
Metric Description
You can view the node pool metrics in the following table.
Figure 1 Node pool metrics
Table 1 Node pool metrics
Metric
Unit
Node Pool CPU Request Rate
Total CPU request of pods on all nodes in the node pool/Total CPU of all nodes in the node pool
Node Pool CPU Usage
Total CPU used by all nodes in the node pool/Total CPU of the node pool
Node Pool Memory Request Rate
Total memory request of pods on all nodes in the node pool/Total memory of all nodes in the node pool
Node Pool Memory Usage
Total memory used by all nodes in the node pool/Total memory of the node pool
Node Count Trend
N/A
The number of nodes in the node pool.
Metric List
The following is the metric list of the node pool view.
Table 2 Metric description
Metric
Unit
kube_node_labels
Gauge
Node label. label_cce_cloud_com_cce_nodepool is the name of the CCE node pool. If the label does not exist, the default pool will be used.
node_cpu_seconds_total
Counter
Seconds the CPUs spent in each mode.
node_memory_MemAvailable_bytes
Gauge
Available memory of a node.
node_memory_MemTotal_bytes
Gauge
Total memory of a node.
kube_pod_container_resource_requests
Gauge
Resource requests of a container.
