Configuring an HTTPS Certificate for a LoadBalancer Ingress
Ingresses support SSL or TLS certificates, allowing you to secure your Services with HTTPS.
- Using a Cluster TLS Certificate: First import a certificate into a secret. CCE automatically provisions the certificate on the ELB with a name prefixed by k8s_plb_default. CCE-managed certificates cannot be modified or deleted through the ELB console. To modify the certificate, update the secret where the certificate is imported to on CCE.
- Using a Certificate Created on the ELB Console: You are allowed to directly use certificates created on the ELB console. There is no need to manually configure the cluster secrets, and you can modify the certificates on the ELB console.
If multiple ingresses share the same external port on a load balancer, you are advised to use the same certificate and security policy for these ingresses. Otherwise, the configuration of the first created ingress will take precedence. For details, see Configuring a Same Port for Multiple Ingresses.
- An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
- A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
- You can obtain a trusted certificate from a certificate provider. For details, see Purchasing an SSL Certificate.
You can configure TLS certificates for LoadBalancer ingresses via the CCE console or kubectl.
- Choose Services and Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
- Configure ingress parameters.
This example explains only key parameters for configuring HTTPS certificates. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
Table 1 Key parameters Parameter
Example
Name
Enter an ingress name.
ingress-test
Load Balancer
Select a load balancer to be associated with the ingress or automatically create a load balancer.
Shared
Listener
- Frontend Protocol: Select HTTPS when configuring a certificate for an ingress.
- External Port: specifies the port of the load balancer listener. The default HTTPS port is 443.
- Certificate Source: Select TLS secret.
- Server Certificate: kubernetes.io/tls and IngressTLS are supported.
If no certificate is available, you can create a TLS certificate. For details about parameter settings, see Creating a Secret.
- Frontend Protocol: HTTPS
- External Port: 443
- Certificate Source: TLS secret
- Server Certificate: test
Forwarding Policy
- Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through an IP address. The domain name must be registered and filed. Once used by a forwarding policy, only that domain name will be accepted for access.
- Path Matching Rule: Choose Prefix match, Exact match, or RegEx match.
- Path: comes from a backend application for external access. It must work in the backend application. Otherwise, forwarding will not take effect.
- Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list. If no Service meets the requirements, create one by following the operations provided in Services Supported by Ingresses.
- Destination Service Port: Select the access port of the destination Service.
- Domain Name: You do not need to configure this parameter.
- Path Matching Rule: Prefix match
- Path: /
- Destination Service: nginx
- Destination Service Port: 80
Figure 1 Selecting a TLS certificate
- Click OK.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Ingress supports two TLS secret types: kubernetes.io/tls and IngressTLS. IngressTLS is used as an example. For details, see Creating a Secret. For details about examples of the kubernetes.io/tls secret and its description, see TLS secrets.
Create a YAML file named ingress-test-secret.yaml. You can change the file name if you want to.
vi ingress-test-secret.yaml
The YAML file is configured as follows:apiVersion: v1 data: tls.crt: LS0******tLS0tCg== tls.key: LS0tL******0tLS0K kind: Secret metadata: annotations: description: test for ingressTLS secrets name: ingress-test-secret namespace: default type: IngressTLS
In the preceding information, tls.crt and tls.key are only examples. Replace them with the actual files. The values of tls.crt and tls.key are Base64-encoded.
- Create a secret.
kubectl create -f ingress-test-secret.yaml
If information similar to the following is displayed, the secret has been created:
secret/ingress-test-secret created
- Check the created secret.
kubectl get secrets
NAME TYPE DATA AGE ingress-test-secret IngressTLS 2 13s
- Create a YAML file named ingress-test.yaml. You can change the file name if you want to.
vi ingress-test.yaml
Default security policy (kubernetes.io/elb.tls-ciphers-policy) is supported only in clusters v1.17.17 or later.
Custom security policy (kubernetes.io/elb.security_policy_id) is supported only in clusters v1.17.17 or later.
An example YAML file of an ingress associated with an automatically created load balancer is as follows:
For clusters v1.23 or later:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.class: performance kubernetes.io/elb.port: '443' kubernetes.io/elb.autocreate: '{ "type": "public", "bandwidth_name": "cce-bandwidth-******", "bandwidth_chargemode": "bandwidth", "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp", # EIP "available_zone": [ "ap-southeast-1a" ], # The AZ where the load balancer is located "elb_virsubnet_ids":["b4bf8152-6c36-4c3b-9f74-2229f8e640c9"], # Subnet network ID "l7_flavor_name": "L7_flavor.elb.s1.small" # Layer 7 load balancer flavor name }' kubernetes.io/elb.security_policy_id: 99bec42b-0dd4-4583-98e9-b05ce628d157 # The priority of the custom security policy is higher than that of the default security policy. kubernetes.io/elb.tls-ciphers-policy: tls-1-2 spec: tls: - secretName: ingress-test-secret # Server certificate name rules: - host: '' http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with your target Service name. port: number: 80 # Replace it with your target Service port. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cceFor clusters v1.21 or earlier:
apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.class: performance kubernetes.io/ingress.class: cce kubernetes.io/elb.port: '443' kubernetes.io/elb.autocreate: '{ "type": "public", "bandwidth_name": "cce-bandwidth-******", "bandwidth_chargemode": "bandwidth", "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp", # EIP "available_zone": [ "ap-southeast-1a" ], # The AZ where the load balancer is located "elb_virsubnet_ids":["b4bf8152-6c36-4c3b-9f74-2229f8e640c9"], # Subnet network ID "l7_flavor_name": "L7_flavor.elb.s1.small" # Layer 7 load balancer flavor name }' kubernetes.io/elb.security_policy_id: 99bec42b-0dd4-4583-98e9-b05ce628d157 # The priority of the custom security policy is higher than that of the default security policy. kubernetes.io/elb.tls-ciphers-policy: tls-1-2 spec: tls: - secretName: ingress-test-secret # Server certificate name rules: - host: '' http: paths: - path: '/' backend: serviceName: <your_service_name> # Replace it with your target Service name. servicePort: 80 # Replace it with your target Service port. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITHTable 2 Key parameters Parameter
Mandatory
Type
No
String
The ID of the custom security group policy on ELB. Obtain it on the ELB console. This field takes effect only when HTTPS is used and has a higher priority than the default security policy.
For details about how to create and update a custom security policy, see TLS Security Policy.
No
String
The default value is tls-1-2, which is the default security policy used by the listener and takes effect only when HTTPS is used.
Options:
- tls-1-0
- tls-1-1
- tls-1-2
- tls-1-2-strict
- tls-1-0-with-1-3 (dedicated load balancer)
- tls-1-2-fs (dedicated load balancer)
- tls-1-2-fs-with-1-3 (dedicated load balancer)
For details of cipher suites for each security policy, see Table 3.
tls
No
Array of strings
When HTTPS is used, this parameter must be added to specify the secret certificate.
Multiple independent domain names and certificates can be added. For details, see Configuring SNI for a LoadBalancer Ingress.
secretName
No
String
This parameter is mandatory if HTTPS is used. Set this parameter to the name of the created secret.
Table 3 tls_ciphers_policy parameters Security Policy
TLS Version
Cipher Suite
tls-1-0
TLS 1.2
TLS 1.1
TLS 1.0
ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:AES128-GCM-SHA256:AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:AES128-SHA256:AES256-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:AES128-SHA:AES256-SHA
tls-1-1
TLS 1.2
TLS 1.1
tls-1-2
TLS 1.2
tls-1-2-strict
TLS 1.2
TLS 1.3
TLS 1.2
TLS 1.1
TLS 1.0
ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:AES128-GCM-SHA256:AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:AES128-SHA256:AES256-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:AES128-SHA:AES256-SHA:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256:TLS_AES_128_CCM_8_SHA256:TLS_AES_128_CCM_SHA256
TLS 1.3
TLS 1.2
ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384
TLS 1.3
TLS 1.2
ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256:TLS_AES_128_CCM_8_SHA256:TLS_AES_128_CCM_SHA256
- Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress.networking.k8s.io/ingress-test created
- Check the created ingress.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test cce * 121.**.**.** 80,443 10s
- Enter https://121.**.**.**:443 in the address bar of the browser to access the workload (for example, Nginx workload).
121.**.**.** indicates the IP address of the unified load balancer.
You can configure a certificate created on the ELB console for an ingress through either the CCE console or kubectl.
- If both an ELB certificate and a TLS certificate are specified for the same ingress, the ingress will use the ELB certificate.
- CCE does not check whether an ELB certificate is valid. It only checks whether the certificate is present.
- Only ingresses in clusters v1.19.16-r2, v1.21.5-r0, v1.23.3-r0, or later support ELB certificates.
Table 4 Key parameters Parameter
Example
Name
ingress-test
Load Balancer
Shared
Listener
- Frontend Protocol: Select HTTPS.
- Certificate Source: Select ELB server certificate.
- SSL Authentication: This parameter is available only when Certificate Source is set to ELB server certificate. Clusters v1.28.15-r60, v1.29.15-r20, v1.30.14-r20, v1.31.10-r20, v1.32.6-r20, v1.33.5-r10, or later support this configuration.
- One-way authentication: Only the backend server is authenticated. If you also need to authenticate the identity of the client, select two-way authentication.
- Two-way authentication: Both the clients and the load balancer authenticate each other. This ensures only authenticated clients can access the load balancer. No additional backend server configuration is required if you select this option.
- Server Certificate: Use a certificate created on ELB.
If no certificate is available, go to the ELB console and create one. For details, see Adding a Certificate.
- Certificate Source: ELB server certificate
- SSL Authentication: One-way authentication
- Server Certificate: cert-test
Forwarding Policy
- Path: /
Figure 2 Selecting a certificate from the ELB service
- Click OK.
To use an ELB certificate, you can specify the kubernetes.io/elb.tls-certificate-ids annotation.
An example YAML file of an ingress associated with an existing load balancer is as follows:
For clusters v1.23 or later:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/elb.port: '443' # The port on the interconnected load balancer kubernetes.io/elb.id: 0b9a6c4d-bd8b-45cc-bfc8-ff0f9da54e95 # ELB ID kubernetes.io/elb.class: union # Load balancer type kubernetes.io/elb.tls-ciphers-policy: tls-1-2 # Default security policy, which is tls-1-2 by default kubernetes.io/elb.tls-certificate-ids: 058cc023690d48a3867ad69dbe9cd6e5,b98382b1f01c473286653afd1ed9ab63 # ELB certificate IDs spec: rules: - host: '' http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with your target Service name. port: number: 80 # Replace it with your target Service port. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cceFor clusters v1.21 or earlier:
apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/ingress.class: cce # This parameter is mandatory when you create an ingress. The default value is cce, indicating that proprietary LoadBalancer ingresses are used. kubernetes.io/elb.port: '443' # The port on the interconnected load balancer kubernetes.io/elb.id: 0b9a6c4d-bd8b-45cc-bfc8-ff0f9da54e95 # ELB ID kubernetes.io/elb.class: union # Load balancer type kubernetes.io/elb.tls-ciphers-policy: tls-1-2 # Default security policy, which is tls-1-2 by default kubernetes.io/elb.tls-certificate-ids: 058cc023690d48a3867ad69dbe9cd6e5,b98382b1f01c473286653afd1ed9ab63 # ELB certificate IDs spec: rules: - host: '' http: paths: - path: '/' backend: serviceName: <your_service_name> # Replace it with your target Service name. servicePort: 80 # Replace it with your target Service port. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITHTable 5 Key parameters Parameter
Type
String
ELB certificate IDs, which are separated by comma (,). The list length is greater than or equal to 1. The first ID in the list is the server certificate, and the other IDs are SNI certificates in which a domain name must be contained.
If an SNI certificate cannot be found based on the domain name requested by the client, the server certificate will be returned by default.
To obtain the certificate, log in to the CCE console, choose Service List > Networking > Elastic Load Balance, and choose Certificates in the navigation pane. In the certificate list, copy the ID under the target certificate name.
kubectl get ingress
In a cluster, multiple ingresses can share a listener, allowing them to use the same port on a single load balancer. When two ingresses are set up with HTTPS certificates, the server certificate that is used will be based on the configuration of the earliest ingress. For details, see How Can I Determine Which Ingress the Listener Settings Have Been Applied To?
Starting from v1.21.15-r0, v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.29.1-r0, or v1.28.4-r0, the YAML file of ingresses includes annotation: kubernetes.io/elb.listener-master-ingress. This annotation specifies the server certificate configured and used by ingresses.
For example, the configurations of two ingresses are as follows:
| Ingress Name | ingress1 | ingress2 |
| Namespace | default | default |
| Creation Time | 2024-04-01 | 2024-04-02 |
| Protocol | HTTPS | HTTPS |
| Load Balancer | elb1 | elb1 |
| Port | 443 | 443 |
| kubernetes.io/elb.listener-master-ingress | default/ingress1 | default/ingress1 |
In the configurations of the two ingresses, annotation: kubernetes.io/elb.listener-master-ingress is present and the value is default/ingress1, indicating that the server certificates that take effect for the two ingresses are the server certificates configured for ingress1 in the default namespace.
If ingresses in separate namespaces use the same listener and TLS certificates, the secrets associated with the TLS certificates may not be displayed normally for the later-created ingress due to namespace isolation. For details, see How Can I Synchronize Certificates When Multiple Ingresses in Different Namespaces Share a Listener?
To update a server certificate, modify the certificate in the ingress1 configuration within the default namespace. Once the modification is made, the certificates used by both ingress1 and ingress2 will be updated accordingly.
To find the ingress with the active certificate configuration, run the following command:
kubectl get ingress -n ${namespace} ${ingress_name} -oyaml | grep kubernetes.io/elb.listener-master-ingress
Helpful Links
- If the HTTPS certificate of a LoadBalancer ingress is about to expire or has expired, see Updating the HTTPS Certificate for a LoadBalancer Ingress.
- If you need to configure SNI for a LoadBalancer ingress, see Configuring SNI for a LoadBalancer Ingress.
- To use more advanced functions of LoadBalancer ingresses, see LoadBalancer Ingress Annotations.
- If there is an access exception after an HTTPS certificate is configured for a LoadBalancer ingress, check whether the certificate configuration is correct by referring to What Could Cause Access Exceptions After Configuring an HTTPS Certificate for a LoadBalancer Ingress?
