Updated on 2026-09-21 GMT+08:00
CCE Patch Release Notes
Version 1.36
Table 1 Release notes for the v1.36 patch
CCE Cluster Patch Version
Kubernetes Version
Feature Updates
Optimization
Vulnerability Fixing
v1.36.1-r10
v1.36.1
  • When resetting a node, you can choose to retain data disks. Data on non-default data disks mounted to a specified directory or used as persistent storage volumes will be retained. The system disk and default data disk will still be cleared.
  • You can disable listener hosting for LoadBalancer Services, allowing listener configurations to be managed independently on the ELB.
  • Added an option in the containerd node pool configuration to control whether original image layer files are garbage-collected after an image is downloaded.
  • Metrics from kubelet-cadvisor-master on master nodes can now be collected.
Fixed some security issues.
v1.36.1-r0
v1.36.1
CCE clusters v1.36 are released for the first time. For more information, see Kubernetes 1.36 Release Notes.
Fine-grained audit logging for access events that use IAM 5.0 agency credentials.
Version 1.35
Table 2 Release notes for the v1.35 patch
Kubernetes Version
Feature Updates
Optimization
v1.35.5-r0
v1.35.5
v1.35.3-r10
v1.35.3
None
v1.35.3-r0
v1.35.3
None
Creation, deletion, and modification operations now record source IP addresses in kube-apiserver and audit logs.
v1.35.1-r2
v1.35.1
None
None
v1.35.1-r0
v1.35.1
CCE clusters v1.35 are released for the first time. For more information, see Kubernetes 1.35 Release Notes.
  • LoadBalancer Services support custom backend weights for StatefulSets.
  • Cluster certificates can be rotated during a cluster upgrade.
None
Version 1.34
Table 3 Release notes for the v1.34 patch
Kubernetes Version
Feature Updates
Optimization
v1.34.8-r0
v1.34.8
v1.34.6-r10
v1.34.6
None
v1.34.6-r0
v1.34.6
None
v1.34.3-r12
v1.34.3
None
None
v1.34.3-r10
v1.34.3
None
v1.34.3-r4
v1.34.3
None
None
v1.34.3-r2
v1.34.3
None
None
v1.34.3-r0
v1.34.3
  • HTTPS is supported for Service/ingress health checks.
  • Cluster agents can be customized.
When purchasing a CCE node, you can reduce the system disk size to 20 GB.
v1.34.2-r0
v1.34.2
  • CCE supports pod identities, which provide secure, dynamic identity credentials for pods.
  • CCE add-ons support custom agencies.
  • Services and Ingresses support QUIC listeners.
In CCE Turbo clusters, you can specify the enterprise project and resource tags of an EIP when the EIP is automatically bound to a pod.
v1.34.1-r4
v1.34.1
None
None
v1.34.1-r2
v1.34.1
None
None
Fixed runc container escape vulnerabilities (CVE-2025-31133, CVE-2025-52565, and CVE-2025-52881).
v1.34.1-r0
v1.34.1
CCE clusters v1.34 are released for the first time. For more information, see Kubernetes 1.34 Release Notes.
  • Traffic mirroring is supported in the advanced forwarding policies of LoadBalancer ingresses.
  • Cluster certificate expiration alerts and updates are supported.
  • Secret-free image pull can be configured for node pools. Workloads running on nodes can automatically download images using the agency permissions of the nodes.
  • Pod CIDR reservation can be enabled (O&M > Network Settings) for clusters that use the VPC network model to prevent conflicts between new subnet CIDR blocks and container CIDR blocks.
  • Service accounts that use TokenRequest support enhanced node authentication.
  • The number of nodes in a scaling group was optimized, and the actual number of ready nodes can be displayed.
None
Version 1.33
Table 4 Release notes for the v1.33 patch
Kubernetes Version
Feature Updates
Optimization
v1.33.12-r0
v1.33.12
v1.33.10-r10
v1.33.10
None
v1.33.10-r0
v1.33.10
None
v1.33.7-r22
v1.33.7
None
None
v1.33.7-r20
v1.33.7
None
v1.33.7-r14
v1.33.7
None
None
v1.33.7-r12
v1.33.7
None
None
v1.33.7-r10
v1.33.7
v1.33.7-r0
v1.33.7
v1.33.5-r24
v1.33.5
None
None
v1.33.5-r22
v1.33.5
None
None
v1.33.5-r20
v1.33.5
v1.33.5-r10
v1.33.5
  • You can modify the IPVS scheduling policy of a cluster through node pool configuration management.
  • You can modify the system-reserved CPU, temporary storage, and PID through node pool configuration management.
  • You can delete pod subnets for the clusters that use VPC networks.
  • You can modify the HPA scale-in stabilization window (horizontal-pod-autoscaler-downscale-stabilization) in the cluster configuration.
  • Two-way authentication can be configured for LoadBalancer Services and ingresses.
None
v1.33.5-r0
v1.33.5
  • You can enable the kubelet's port 127.0.0.1:10255 in the node pool configuration to expose metrics over HTTP. This configuration is disabled by default.
  • You can enable container-isolated resource view in the node pool configuration. Containers only access and manage their own assigned resources.
None
v1.33.1-r0
v1.33.1
CCE clusters v1.33 are released for the first time. For more information, see Kubernetes 1.33 Release Notes.
  • LoadBalancer ingresses associated with shared load balancers can be redirected from HTTP to HTTPS.
  • CCE standard clusters support custom agencies for cluster-level access control.
None
None
Version 1.32
Table 5 Release notes for the v1.32 patch
Kubernetes Version
Feature Updates
Optimization
v1.32.13-r20
v1.32.13
v1.32.13-r10
v1.32.13
None
v1.32.13-r0
v1.32.13
None
v1.32.9-r22
v1.32.9
None
None
v1.32.9-r20
v1.32.9
None
v1.32.9-r14
v1.32.9
None
None
v1.32.9-r12
v1.32.9
None
None
v1.32.9-r10
v1.32.9
v1.32.9-r0
v1.32.9
v1.32.6-r34
v1.32.6
None
None
v1.32.6-r32
v1.32.6
None
None
v1.32.6-r30
v1.32.6
v1.32.6-r20
v1.32.6
None
v1.32.6-r10
v1.32.6
None
v1.32.6-r0
v1.32.6
None
v1.32.5-r2
v1.32.5
None
Optimized the performance of dynamic container network interface pre-binding in large CCE Turbo clusters.
v1.32.5-r0
v1.32.5
AK/SK automatic updates are supported for OBS buckets.
None
Fixed the CVE-2025-5187 vulnerability.
v1.32.1-r0
v1.32.1
CCE clusters v1.32 are released for the first time. For more information, see Kubernetes 1.32 Release Notes.
  • Service pod scheduling can be deferred until node post-installation scripts complete.
  • DataPlane V2 is available for newly created CCE clusters that use the VPC networks. After DataPlane V2 is enabled, you can configure network policies for these clusters.
  • AK/SK automatic updates are supported for parallel file systems of OBS.
  • The X-Real-IP field in HTTP/HTTPS request headers can be rewritten for both LoadBalancer Services and ingresses.
  • During the creation of a LoadBalancer Service, you can configure specific IP addresses for the ELB backend.
  • AppArmor can be used to restrict container access to resources.
  • Streaming encoding is supported, significantly reducing memory pressure on control plane nodes caused by LIST requests.
  • The cce-pause container image can be protected against accidental deletion.
  • The system labels used by the NodeLocal DNSCache add-on can be protected against accidental deletion.
None
Version 1.31
Table 6 Release notes for the v1.31 patch
Kubernetes Version
Feature Updates
Optimization
v1.31.14-r50
v1.31.14
v1.31.14-r40
v1.31.14
None
v1.31.14-r30
v1.31.14
None
v1.31.14-r22
v1.31.14
None
None
v1.31.14-r20
v1.31.14
None
v1.31.14-r14
v1.31.14
None
None
v1.31.14-r12
v1.31.14
None
None
v1.31.14-r10
v1.31.14
v1.31.14-r0
v1.31.14
v1.31.10-r34
v1.31.10
None
None
v1.31.10-r32
v1.31.10
None
None
v1.31.10-r30
v1.31.10
v1.31.10-r20
v1.31.10
None
v1.31.10-r10
v1.31.10
None
v1.31.10-r0
v1.31.10
None
v1.31.6-r12
v1.31.6
None
v1.31.6-r10
v1.31.6
None
v1.31.6-r0
v1.31.6
v1.31.4-r0
v1.31.4
  • Yearly/Monthly nodes added during a node pool scale-out can be automatically paid.
  • Nodes added during a node pool scale-out can be automatically bound with EIPs.
  • ELB ingresses allow you to specify backend server groups for forwarding.
None
v1.31.1-r4
v1.31.1
None
  • Optimized the ELB timeout settings for LoadBalancer Services and ingresses.
  • Enhanced compatibility with specialized node pool configurations during cluster upgrades.
  • Enhanced compatibility with private images used by BMSs.
  • Optimized the container network performance of BMSs.
v1.31.1-r2
v1.31.1
None
Improved the Docker runtime security.
v1.31.1-r0
v1.31.1
CCE clusters v1.31 are released for the first time. For more information, see Kubernetes 1.31 Release Notes.
  • LoadBalancer ingresses support more advanced forwarding actions and return fixed responses.
  • DataPlane V2 is available for newly created CCE Turbo clusters. After DataPlane V2 is enabled, you can configure network policies for these clusters.
  • During a cluster upgrade, you can scale out the nodes in the cluster.
  • You can choose multiple blocklists or trustlists to manage access to a LoadBalancer ingress.
None
Version 1.30
Table 7 Release notes for the v1.30 patch
Kubernetes Version
Feature Updates
Optimization
v1.30.14-r90
v1.30.14
v1.30.14-r80
v1.30.14
None
v1.30.14-r70
v1.30.14
None
v1.30.14-r62
v1.30.14
None
None
v1.30.14-r60
v1.30.14
None
v1.30.14-r54
v1.30.14
None
None
v1.30.14-r52
v1.30.14
None
None
v1.30.14-r50
v1.30.14
v1.30.14-r40
v1.30.14
v1.30.14-r34
v1.30.14
None
None
v1.30.14-r32
v1.30.14
None
None
v1.30.14-r30
v1.30.14
v1.30.14-r20
v1.30.14
None
v1.30.14-r10
v1.30.14
None
v1.30.14-r0
v1.30.14
None
v1.30.10-r12
v1.30.10
None
v1.30.10-r10
v1.30.10
None
v1.30.10-r0
v1.30.10
v1.30.6-r10
v1.30.6
None
v1.30.6-r4
v1.30.6
None
v1.30.6-r2
v1.30.6
None
v1.30.6-r0
v1.30.6
v1.30.4-r4
v1.30.4
None
  • Improved the stability of cluster upgrades.
  • Optimized clusters' overload protection.
v1.30.4-r2
v1.30.4
None
Fixed the issue of chart upload failures in certain situations.
v1.30.4-r0
v1.30.4
  • LoadBalancer ingresses can forward requests based on parameters such as HTTP request methods, HTTP request headers, query strings, CIDR blocks, and cookies.
  • LoadBalancer ingresses support cross-origin access.
  • You can change a node password when updating its node pool.
  • A node can be attached with no data disks.
  • When updating a LoadBalancer ingress, you can modify the configuration of redirecting HTTP requests to HTTPS requests.
  • The default image address can be specified for Docker node pools.
v1.30.1-r2
v1.30.2
None
Enhanced system stability.
v1.30.1-r0
v1.30.2
CCE clusters v1.30 are released for the first time. For more information, see Kubernetes 1.30 Release Notes.
  • When you delete a cluster, CCE allows you to select which log groups to delete.
  • When creating a cluster, you can select bring-your-own KMS instances for secret-encrypted etcd.
  • When a node is created using a private image, the image password can be retained.
  • CCE supports GPU rendering.
CCE supports ELB listeners on any port.
Version 1.29
Table 8 Release notes for the v1.29 patch
Kubernetes Version
Feature Updates
Optimization
v1.29.15-r90
v1.29.15
v1.29.15-r80
v1.29.15
None
v1.29.15-r70
v1.29.15
None
v1.29.15-r62
v1.29.15
None
None
v1.29.15-r60
v1.29.15
None
v1.29.15-r54
v1.29.15
None
None
v1.29.15-r52
v1.29.15
None
None
v1.29.15-r50
v1.29.15
v1.29.15-r40
v1.29.15
v1.29.15-r34
v1.29.15
None
None
v1.29.15-r32
v1.29.15
None
None
v1.29.15-r30
v1.29.15
v1.29.15-r20
v1.29.15
None
v1.29.15-r10
v1.29.15
None
v1.29.15-r0
v1.29.15
None
v1.29.13-r12
v1.29.13
None
v1.29.13-r10
v1.29.13
None
v1.29.13-r0
v1.29.13
v1.29.10-r10
v1.29.10
None
v1.29.10-r4
v1.29.10
None
v1.29.10-r2
v1.29.10
None
v1.29.10-r0
v1.29.10
v1.29.8-r4
v1.29.8
None
v1.29.8-r2
v1.29.8
None
v1.29.8-r0
v1.29.8
v1.29.4-r2
v1.29.3
None
v1.29.4-r0
v1.29.3
v1.29.3-r0
v1.29.3
  • RAM allows secrets to be shared between accounts.
  • Nodes can be migrated to a custom node pool.
  • FlexusX is supported.
  • The default containerd image path has been included in the management of node pool configurations.
  • On the node pool list page, you can sort node pools according to your preferences.
v1.29.2-r4
v1.29.3
None
The stability of ELB has been improved during upgrades that span across multiple versions.
v1.29.2-r2
v1.29.3
None
During cluster upgrades, the collection of container logs has been made more reliable.
v1.29.2-r0
v1.29.3
  • CCE ingresses support traffic distribution based on custom HTTP headers.
  • Scaling priority policies can be configured for third-party workloads.
  • You can configure a security group for a pod using annotations. This feature is only available for CCE Turbo clusters.
  • You can bind an existing EIP to a pod. This feature is only available for CCE Turbo clusters.
  • An in-progress node drainage can be canceled.
  • When creating a node pool, you do not need to configure its billing mode.
  • When updating a node pool, you can change its agency name, prefix, and suffix.
  • Resetting a node on the console will reserve the node's Kubernetes labels and taints by default.
  • Both the Kubernetes service account token volume projection and the load scaling controller can be configured.
v1.29.1-r10
v1.29.1
  • CCE ingress forwarding policies can be sorted by priority.
  • When configuring volumeClaimTemplates for StatefulSets, you can configure the name prefixes of PVs and underlying storage. (The Everest version must be 2.4.15 or later.)
  • A yearly/monthly node pool supports multiple node flavors.
  • The default node flavor can be deleted when a node pool is updated.
  • Nodes can be managed in a custom node pool.
  • An alarm rule has been added for a CoreDNS resolution failure.
  • Nodes can be drained before they are unsubscribed from.
  • After a node pool is updated, the configuration differences of each node are displayed.
v1.29.1-r0
v1.29.1
CCE clusters v1.29 are released for the first time. For more information, see Kubernetes 1.29 Release Notes.
None
None
Earlier Versions
The following describes earlier cluster versions.
