Updated on 2026-09-21 GMT+08:00
Comparison Between Cluster Types
Comparison
CCE provides different types of clusters for you to select. The following table lists the differences between them.
Cluster Type
CCE standard
CCE Turbo
CCE Autopilot
Positioning
Standard clusters that provide highly reliable, secure containers for commercial use
Next-generation clusters designed for Cloud Native 2.0, with accelerated compute, networking, and scheduling
Serverless clusters that you do not need to manage nodes and are billed based on actual CPU and memory usage
In such clusters, no node deployment, management, and security maintenance are needed.
Applications
For users who expect to use container clusters to manage applications, obtain elastic compute resources, and enable simplified management of compute, network, and storage resources
For users who have higher requirements on performance, resource utilization, and full-scenario coverage
For users whose services suffer frequent traffic surges, such as users in the online education and e-commerce sectors
Network
For scenarios where there are not so many containers and high performance is not needed, the following networks are provided:
  • Tunnel networks
  • VPC networks
For details, see Network Model Comparison.
Cloud Native 2.0 networks: for scenarios where there are many containers and high performance is needed
By default, 2,000 nodes are supported. A maximum of 20,000 nodes are supported.
Host Ports (hostPort) for Pods
Supported
Not supported by default; supported after DataPlane V2 is enabled
Not supported
Network Performance
The container network is overlaid with the VPC network, causing certain performance loss.
The VPC network and container network are flattened into one for zero performance loss.
Network Isolation
  • Tunnel networks: network policies for communications within a cluster
  • VPC networks: NetworkPolicies are supported after DataPlane V2 is enabled. For details, see DataPlane V2.
Pods can be associated with security groups for isolation. This ensures consistent security isolation both within and outside a cluster.
After DataPlane V2 is enabled, CCE supports network policies. For details, see DataPlane V2.
Pod EIP
Not supported
Supported
Supported
Static Pod IP Address
Not supported
Supported by StatefulSets and can be combined with EIP binding to provide a fixed public IP address
Container Resource Isolation
cgroups are used to isolate common containers.
  • VM-level isolation is supported for secure containers that run only on physical machines.
  • cgroups are used to isolate common containers.
VM-level isolation
Edge Infrastructure Management
Not supported
Support for management of edge cloud resources. For details, see Using Edge Cloud Resources in a Remote CCE Turbo Cluster.
Not supported
