Help Center/ Cloud Container Engine/ User Guide/ Clusters/ Upgrade Management/ Migrating Services Across Clusters of Different Versions
Updated on 2026-04-03 GMT+08:00
Application Scenarios
This section describes how to migrate services from a cluster of an earlier version to a cluster of a later version in CCE.
This operation is applicable when a cross-version cluster upgrade is required (for example, upgrade from v1.19.* to v1.28.*) and new clusters can be created for service migration.
Table 1 Checklist before migration
Category
Cluster
NodeIP-related: Check whether node IP addresses (including EIPs) of the cluster before the migration have been used in other configurations or trustlists.
Workload
Record the number of workloads for post-migration check.
  1. Check whether the storage resources in use are provisioned by the cloud or by your organization.
  2. Change the automatically created storage to the existing storage in the new cluster.
Network
  1. Pay special attention to the LoadBalancer Services and ingresses.
  2. Clusters of an earlier version support only the classic load balancer. To migrate services to a new cluster, change load balancer type to shared load balancer. Then, the corresponding LoadBalancer Services will be re-established.
O&M
Private configuration: Check whether kernel parameters or system data have been configured on nodes in the cluster.
  1. Create a CCE cluster.
    Create a cluster with the same specifications and configurations as the cluster of the earlier version. For details, see Buying a Standard/Turbo Cluster.
  2. Add nodes.
    Add nodes with the same specifications and manual configuration items. For details, see Creating a Node.
  3. Create storage volumes in the new cluster.
    Use the existing storage to create PVCs in the new cluster. The PVC names remain unchanged. For details, see Using an Existing OBS Bucket Through a Static PV or Using an Existing SFS Turbo File System Through a Static PV.
    Storage switching supports only shared storage such as OBS and SFS Turbo. If non-shared storage is used, suspend the workloads in the old cluster to switch the storage resources. In this case, services will become unavailable.
  4. Create workloads in the new cluster.
    Create workloads in the new cluster. The names and specifications remain unchanged. For details, see Creating a Deployment or Creating a StatefulSet.
  5. Mount the storage again.
    Remount the existing storage in the workload. For details, see Using an Existing OBS Bucket Through a Static PV or Using an Existing SFS Turbo File System Through a Static PV.
  6. Create Services in the new cluster.
    The Service names and specifications remain unchanged. For details about how to create a Service, see Service.
  7. Commission services.
    After all resources are created, commission the containerized services. If the commissioning is successful, migrate the services to the new cluster.
  8. Delete or unsubscribe from the old cluster.
    When all functions of the new cluster are ready, unsubscribe from or delete the old cluster. For details about how to delete a cluster, see Deleting a Cluster.
