Creating a File System from an SFS Turbo Backup
In case of a virus attack, accidental deletion, or software or hardware fault, you can use an SFS Turbo file system backup to create a new file system. Once created, data on the new file system is the same as that in the backup.
You can change the storage class of a file system within a certain range. For example, you can change a file system from Standard to Performance, but not from Standard to Standard - Enhanced. From SFS Turbo HPC backups, you can only create HPC file systems with different performance, such as 20 MB/s/TiB, 40 MB/s/TiB, 125 MB/s/TiB, 250 MB/s/TiB, 500 MB/s/TiB, and 1,000 MB/s/TiB.
Billing
- You need to pay for the storage space of the new SFS Turbo file system created from the backup.
- For details about billed items, see SFS Turbo Billing Overview. For details about pricing, see SFS Turbo Pricing Details.
In CloudPond scenarios, SFS Turbo backups cannot be used to create new SFS Turbo file systems.
- Log in to the CBR console. Click
in the upper left corner and select a region. - Click the Backups tab and locate the desired backup. For details, see Viewing a Backup.
- Click Create New File System in the Operation column of the backup. The button is available only when the backup status is Available. The Create File System page is displayed. Figure 1 Viewing a backup
- Configure the file system parameters.
You can learn about the parameter descriptions in table "Parameter description" under "Creating an SFS Turbo File System" in Create a File System of the Scalable File Service Turbo User Guide.
You can change the storage class of the file system within a certain range. For example, you can change a file system from Standard to Performance, but not from Standard to Standard - Enhanced.
The billing mode of the new file system can only be pay-per-use.
- Click Create Now.
- Confirm the file system information and click Submit.
- Make the payment and click OK.
- Go back to the file system list and check whether the file system is successfully created.
You will see the file system status change as follows: Creating, Available, Restoring, Available. You may not notice the Restoring status because Instant Restore is very fast. After the file system status changes from Creating to Available, the file system is successfully created. After the status has changed from Restoring to Available, backup data has been successfully restored to the created file system.
