x-apigateway-backend
Meaning: API backend definition.
Scope of effect: Operation Object (2.0)/Operation Object (3.0)
Example:
paths:
  '/users/{userId}':
    get:
      produces:
        - "application/json"
      responses:
        default:
          description: "default response"
      x-apigateway-request-type: "public"
      x-apigateway-backend:
        type: "backend endpoint type"
       Parameter  |
       Mandatory  |
       Type  |
       Description  |
       x-apigateway-backend  |
       Yes  |
       String  |
       Backend service definition.  |
       type  |
       Yes  |
       String  |
       Backend service type. The options include HTTP, HTTP-VPC, FUNCTION, and MOCK.  |
       parameters  |
       No  |
       Backend parameters.  |
       httpEndpoints  |
       No  |
       HTTP backend service definition.  |
       httpVpcEndpoints  |
       No  |
       HTTP VPC backend service definition.  |
       functionEndpoints  |
       No  |
       Function backend service definition.  |
       mockEndpoints  |
       No  |
       Mock backend service definition.  |
       httpVpcMemberGroupEndpoints  |
       No  |
       HTTP VPC member group backend service definition. It is restricted. To use it, submit a service ticket.  |
