Updated on 2025-08-08 GMT+08:00
Bills
You can choose Billing > Bills to check the COC transactions and bills.
Bill Generation
- After a yearly/monthly package is paid, a bill is reported to the billing system for settlement.
- The usage of pay-per-use resources is reported to the billing system periodically for settlement. Pay-per-use resources can be settled by hour, day, or month based on usage type. For details, see Bill Run for Pay-per-Use Resources. The COC packages that use the pay-per-use billing mode are settled by day.
- The fee deduction time of pay-per-use resources may be later than the settlement period. For example, an ECS settled by day was deleted at 08:30 on June 18, 2023, but the fees generated from 08:00 to 09:00 on June 18, 2023 were usually deducted at 00:00 on June 19, 2023.
- On the Billing Center > Billing > Transactions and Detailed Bills > Transaction Bills tab page, Expenditure Time lists the usage duration of your pay-per-use resources.
Viewing Bills
- Go to the Billing Center > Expenditure Details page.
- Select COC as the product type to view all expenditure details generated in COC.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
