Creating a Deployment
Deployments are workloads (for example, Nginx) that do not store any data or status. You can create Deployments on the CCE console or by running kubectl commands.
  • Before creating a workload, you must have an available cluster. For details on how to create a cluster, see Buying a CCE Standard/Turbo Cluster.
  • To enable public access to a workload, ensure that an EIP or load balancer has been bound to at least one node in the cluster.
    If a pod has multiple containers, ensure that the ports used by the containers do not conflict with each other. Otherwise, creating the Deployment will fail.
Using the CCE Console
  1. Log in to the CCE console.
  2. Click the cluster name to go to the cluster console, choose Workloads in the navigation pane, and click the Create Workload in the upper right corner.
  3. Set basic information about the workload.
    Basic Info
    • Workload Type: Select Deployment. For details about workload types, see Overview.
    • Workload Name: Enter the name of the workload. Enter 1 to 63 characters starting with a lowercase letter and ending with a lowercase letter or digit. Only lowercase letters, digits, and hyphens (-) are allowed.
    • Namespace: Select the namespace of the workload. The default value is default. You can also click Create Namespace to create one. For details, see Creating a Namespace.
    • Pods: Enter the number of pods of the workload.
    • Container Runtime: A CCE standard cluster uses runC by default, whereas a CCE Turbo cluster supports both runC and Kata. For details about the differences, see Secure Runtime and Common Runtime.
    • Time Zone Synchronization: Specify whether to enable time zone synchronization. After time zone synchronization is enabled, the container and node use the same time zone. The time zone synchronization function depends on the local disk mounted to the container. Do not modify or delete the time zone. For details, see Configuring Time Zone Synchronization.
    Container Settings
    • Container Information
      Multiple containers can be configured in a pod. You can click Add Container on the right to configure multiple containers for the pod.
      • Basic Info: Configure basic information about the container.
        Container Name
        Name the container.
        Pull Policy
        Image update or pull policy. If you select Always, the image is pulled from the image repository each time. If you do not select Always, the existing image of the node is preferentially used. If the image does not exist, the image is pulled from the image repository.
        Image Name
        Click Select Image and select the image used by the container.
        To use a third-party image, see Using Third-Party Images.
        Image Tag
        Select the image tag to be deployed.
        CPU Quota
        • Request: minimum number of CPU cores required by a container. The default value is 0.25 cores.
        • Limit: maximum number of CPU cores that can be used by a container. This prevents containers from using excessive resources.
        If Request and Limit are not specified, the quota is not limited. For more information and suggestions about Request and Limit, see Configuring Container Specifications.
        Memory Quota
        • Request: minimum amount of memory required by a container. The default value is 512 MiB.
        • Limit: maximum amount of memory available for a container. When memory usage exceeds the specified memory limit, the container will be terminated.
        (Optional) GPU Quota
        Configurable only when the cluster contains GPU nodes and the CCE AI Suite (NVIDIA GPU) add-on is installed.
        • All: No GPU will be used.
        • Dedicated: GPU resources are dedicated for the container.
        • Shared: percentage of GPU resources used by the container. For example, if this parameter is set to 10%, the container uses 10% of GPU resources.
        For details about how to use GPUs in the cluster, see Default GPU Scheduling in Kubernetes.
        (Optional) Privileged Container
        Programs in a privileged container have certain privileges.
        If Privileged Container is enabled, the container is assigned privileges. For example, privileged containers can manipulate network devices on the host machine and modify kernel parameters.
        (Optional) Init Container
        Whether to use the container as an init container. An init container does not support health check.
        An init container is a special container that runs before other app containers in a pod are started. Each pod can contain multiple containers. In addition, a pod can contain one or more init containers. Application containers in a pod are started and run only after the running of all init containers completes. For details, see Init Containers.
      • (Optional) Lifecycle: Configure operations to be performed in a specific phase of the container lifecycle, such as Startup Command, Post-Start, and Pre-Stop. For details, see Configuring Container Lifecycle Parameters.
      • (Optional) Health Check: Set the liveness probe, ready probe, and startup probe as required. For details, see Configuring Container Health Check.
      • (Optional) Environment Variables: Configure variables for the container running environment using key-value pairs. These variables transfer external information to containers running in pods and can be flexibly modified after application deployment. For details, see Configuring Environment Variables.
      • (Optional) Data Storage: Mount local storage or cloud storage to the container. The application scenarios and mounting modes vary with the storage type. For details, see Storage.
        If the workload contains more than one pod, EVS volumes cannot be mounted.
      • (Optional) Security Context: Assign container permissions to protect the system and other containers from being affected. Enter the user ID to assign container permissions and prevent systems and other containers from being affected.
      • (Optional) Logging: Report standard container output logs to AOM by default, without requiring manual settings. You can manually configure the log collection path. For details, see Collecting Container Logs Using ICAgent.
        To disable the standard output of the current workload, add the annotation kubernetes.AOM.log.stdout: [] in Labels and Annotations. For details about how to use this annotation, see Table 1.
    • Image Access Credential: Select the credential used for accessing the image repository. The default value is default-secret. You can use default-secret to access images in SWR. For details about default-secret, see default-secret.
    • (Optional) GPU: All is selected by default. The workload instance will be scheduled to the node of the specified GPU type.
    (Optional) Service Settings
    A Service provides external access for pods. With a static IP address, a Service forwards access traffic to pods and automatically balances load for these pods.
    You can also create a Service after creating a workload. For details about Services of different types, see Overview.
    (Optional) Advanced Settings
    • Upgrade: Specify the upgrade mode and parameters of the workload. Rolling upgrade and Replace upgrade are available. For details, see Configuring Workload Upgrade Policies.
    • Scheduling: Configure affinity and anti-affinity policies for flexible workload scheduling. Load affinity and node affinity are provided.
      • Load Affinity: Common load affinity policies are offered for quick load affinity deployment.
        • Multi-AZ deployment is preferred: Workload pods are preferentially scheduled to nodes in different AZs through pod anti-affinity (podAntiAffinity). If all the nodes in the cluster are deployed in the same AZ, the pods will be scheduled to that AZ but onto different nodes for high availability. If there are fewer nodes than pods, the extra pods will fail to run.
        • Forcible multi-AZ deployment: Workload pods are forcibly scheduled to nodes in different AZs through pod anti-affinity (podAntiAffinity). If there are fewer AZs than pods, the extra pods will fail to run.
        • Custom policies: Affinity and anti-affinity policies can be customized as needed. For details, see Scheduling Policies (Affinity/Anti-affinity).
      • Node Affinity: Common load affinity policies are offered for quick load affinity deployment.
        • Node Affinity: Workload pods can be deployed on specified nodes through node affinity (nodeAffinity). If no node is specified, the pods will be randomly scheduled based on the default scheduling policy of the cluster.
        • Specified node pool scheduling: Workload pods can be deployed in a specified node pool through node affinity (nodeAffinity). If no node pool is specified, the pods will be randomly scheduled based on the default scheduling policy of the cluster.
    • Toleration: Using both taints and tolerations allows (not forcibly) the pod to be scheduled to a node with the matching taints, and controls the pod eviction policies after the node where the pod is located is tainted. For details, see Configuring Tolerance Policies.
    • Labels and Annotations: Add labels or annotations for pods using key-value pairs. After entering the key and value, click Confirm. For details about how to use and configure labels and annotations, see Configuring Labels and Annotations.
    • DNS: Configure a separate DNS policy for the workload. For details, see DNS Configuration.
    • APM Settings: Use Application Performance Management (APM) to provide more accurate problem analysis and location for Java programs. For details, see Configuring APM.
    • Network Configuration
      • Pod ingress/egress bandwidth limitation: You can set ingress/egress bandwidth limitation for pods. For details, see Configuring QoS for a Pod.
  4. Click Create Workload in the lower right corner.
Using kubectl
The following procedure uses Nginx as an example to describe how to create a workload using kubectl.
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Create and edit the nginx-deployment.yaml file. nginx-deployment.yaml is an example file name, and you can rename it as required.
    vi nginx-deployment.yaml
    The following is an example YAML file. For more information about Deployments, see Kubernetes documentation.
    apiVersion: apps/v1
    kind: Deployment
      replicas: 1
      selector:
        matchLabels:
          app: nginx
      strategy:
        type: RollingUpdate
      template:
          labels:
            app: nginx
          containers:
          - image: nginx    # If you use an image in My Images, obtain the image path from SWR.
            imagePullPolicy: Always
          imagePullSecrets:
          - name: default-secret
    For details about the parameters, see Table 1.
    Table 1 Deployment YAML parameters
    Mandatory/Optional
    apiVersion
    API version.
    Set this parameter based on the cluster version.
    • For clusters of v1.17 or later, the apiVersion format of Deployments is apps/v1.
    • For clusters of v1.15 or earlier, the apiVersion format of Deployments is extensions/v1beta1.
    Mandatory
    kind
    Type of a created object.
    Mandatory
    metadata
    Metadata of a resource object.
    Mandatory
    name
    Name of the Deployment.
    Mandatory
    spec
    Detailed description of the Deployment.
    Mandatory
    replicas
    Number of pods.
    Mandatory
    selector
    Determines container pods that can be managed by the Deployment.
    Mandatory
    strategy
    Upgrade mode. Possible values:
    • RollingUpdate
    • ReplaceUpdate
    By default, rolling update is used.
    Optional
    template
    Detailed description of a created container pod.
    Mandatory
    metadata
    Metadata.
    Mandatory
    labels
    metadata.labels: Container labels.
    Optional
    containers
    • image (mandatory): Name of a container image.
    • imagePullPolicy (optional): Policy for obtaining an image. The options include Always (attempting to download images each time), Never (only using local images), and IfNotPresent (using local images if they are available; downloading images if local images are unavailable). The default value is Always.
    • name (mandatory): Container name.
    Mandatory
    imagePullSecrets
    Name of the secret used during image pulling. If a private image is used, this parameter is mandatory.
    • To pull an image from the Software Repository for Container (SWR), set this parameter to default-secret.
    • To pull an image from a third-party image repository, set this parameter to the name of the created secret.
    Optional
  3. Create a Deployment.
    kubectl create -f nginx-deployment.yaml
    If the following information is displayed, the Deployment is being created.
    deployment "nginx" created
  4. Obtain the Deployment status.
    kubectl get deployment
    If the following information is displayed, the Deployment is running.
    NAME           READY     UP-TO-DATE   AVAILABLE   AGE
    nginx          1/1       1            1           4m5s
    Parameters
    • NAME: Name of the application running in the pod.
    • READY: indicates the number of available workloads. The value is displayed as "the number of available pods/the number of expected pods".
    • UP-TO-DATE: indicates the number of replicas that have been updated.
    • AVAILABLE: indicates the number of available pods.
    • AGE: period the Deployment keeps running
  5. If the Deployment will be accessed through a ClusterIP or NodePort Service, configure the access mode. For details, see Network.
