Updated on 2026-11-24 GMT+08:00
Creating a Parallel File System
Parallel File System (PFS) is a high-performance semantic file system provided by OBS. It features access latency in milliseconds, TB/s-level bandwidth, and millions of IOPS. When you need to process massive amounts of data in scenarios such as big data analytics and high-performance computing, you can use OBS parallel file systems to achieve high-concurrency access.
You must create a parallel file system before you can store file data.
Ways to Create a Parallel File System
You can create a parallel file system using OBS Console, SDKs, or APIs.
Helpful Links
