Updated on 2025-09-23 GMT+08:00
Deleting an Application
This section describes how to delete an application or sub-application.
Precautions
When an application or sub-application contains groups, components, or sub-applications, it cannot be deleted. You can delete a node only when the node does not contain sub-nodes.
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Applications in the upper left corner.
  4. In the application list on the left, select the application to be deleted and click .
  5. Click OK.
    The application is deleted.
Deleting a Sub-application
  1. Log in to COC.
  4. In the application list on the left, expand the application, select the sub-application to be deleted, and click .
  5. Click OK.
    The sub-application is deleted.
