Configuring Multiple Ingresses to Use the Same External ELB Port
In a cluster, multiple ingresses can share a listener, allowing them to use the same port on a single load balancer. If two ingresses have different listener configurations, the listener configuration of the earlier ingress (known as the first route) will be used. For details about how to check the first route, see How Can I Determine Which Ingress the Listener Settings Have Been Applied To?
The following table lists listener parameters.
Listener |
Annotation |
Helpful Links |
Configuring ELB Certificates |
kubernetes.io/elb.tls-certificate-ids kubernetes.io/elb.tls-ciphers-policy |
Using HTTP/2 |
kubernetes.io/elb.http2-enable |
Configuring Timeout for an Ingress |
kubernetes.io/elb.keepalive_timeout kubernetes.io/elb.client_timeout kubernetes.io/elb.member_timeout |
Configuring a Blocklist/Trustlist |
kubernetes.io/elb.acl-id kubernetes.io/elb.acl-status kubernetes.io/elb.acl-type |
Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Ingress |
Configuring an HTTP/HTTPS Header |
kubernetes.io/elb.x-forwarded-port kubernetes.io/elb.x-forwarded-for-port kubernetes.io/elb.x-forwarded-host kubernetes.io/elb.x-real-ip |
Enabling GZIP |
kubernetes.io/elb.gzip-enabled |
Configuring GZIP Data Compression for a LoadBalancer Ingress |
Ensure that the configurations of different listeners for various ingresses are synchronized. To do so, perform the following operations:
- In the navigation pane, choose Services & Ingresses. Then, click the Ingresses tab, and choose More > Update in the Operation column.
- Synchronize Configuration is available if the listener configuration of the ingress differs from that of the ELB. Click Synchronize Configuration. Then, the listener configuration will be automatically synchronized.
