Configuring an HTTP/HTTPS Header for a LoadBalancer Ingress
Updated on 2025-02-18 GMT+08:00
HTTP headers are a list of strings sent and received by both the client and server on every HTTP request and response. This section describes HTTP headers supported by HTTP and HTTP listeners.
  • HTTP/HTTPS headers rely on ELB. Before using HTTP/HTTPS headers in a Service, check whether HTTP/HTTPS headers are supported in the current region. For details, see HTTP/HTTPS Headers.
  • After HTTP or HTTPS is configured, if you delete the HTTP or HTTPS configuration on the CCE console or delete the target annotation from the YAML file, the configuration on the ELB will be retained.
Table 1 Headers
Header
Feature
X-Forwarded-Port
Transfer Listener Port Number
If this option is enabled, the port number used by the listener will be transmitted to backend servers through the X-Forwarded-Port header.
X-Forwarded-For-Port
Transfer Port Number in the Request
If this option is enabled, the port number used by the client will be transmitted to backend servers through the X-Forwarded-For-Port header.
X-Forwarded-Host
Rewrite X-Forwarded-Host
If this function is enabled, X-Forwarded-Host will be rewritten using the Host field in the client request header and transferred to backend servers.
  • A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
    • v1.23: v1.23.13-r0 or later
    • v1.25: v1.25.8-r0 or later
    • v1.27: v1.27.5-r0 or later
    • v1.28: v1.28.3-r0 or later
    • Other clusters of later versions
  • An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
  • A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
Notes and Constraints
  • Ingresses support HTTP to HTTPS headers only when dedicated load balancers are used.
  • If multiple ingresses share the same external port on a load balancer, you are advised to use the same HTTP/HTTPS header for these ingresses. Otherwise, the configuration of the first created ingress will take precedence. For details, see Configuring Multiple Ingresses to Use the Same External ELB Port.
You can configure an HTTP/HTTPS header for an ingress using either the CCE console or kubectl.
  2. In the navigation pane, choose Services & Ingresses. Click the Ingresses tab and click Create Ingress in the upper right corner.
  3. Configure ingress parameters.
    This example explains only key parameters for configuring HTTP/HTTPS headers. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
    Table 2 Key parameters
    Example
    Name
    Enter an ingress name.
    ingress-test
    Load Balancer
    Select a load balancer to be associated with the ingress or automatically create a load balancer. In this example, only dedicated load balancers are supported.
    Dedicated
    Listener
    • External Protocol: HTTP and HTTPS are available.
    • External Port: specifies the port of the load balancer listener.
    • Advanced Options
      • Transfer Listener Port Number: If this function is enabled, the listening port on the load balancer can be transferred to backend servers through the HTTP header of the packet.
      • Transfer Port Number in the Request: If this function is enabled, the source port on the client can be transferred to backend servers through the HTTP header of the packet.
      • Rewrite X-Forwarded-Host: If this function is enabled, X-Forwarded-Host will be rewritten using the Host field in the client request header and transferred to backend servers.
    • External Port: 80
    • Advanced Options
      • Transfer Listener Port Number: Enable
      • Transfer Port Number in the Request: Enable
      • Rewrite X-Forwarded-Host: Enable
    Forwarding Policy
    • Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through the IP address. Ensure that the domain name has been registered and licensed. Once a forwarding policy is configured with a domain name specified, you must use the domain name for access.
    • Path Matching Rule: Select Prefix match, Exact match, or RegEx match.
    • Path: Enter the path provided by a backend application for external access. The path added must be valid in the backend application, or the forwarding cannot take effect.
    • Destination Service: Select an existing Service or create a Service. Any Services that do not match the search criteria will be filtered out automatically.
    • Destination Service Port: Select the access port of the destination Service.
    • Domain Name: You do not need to configure this parameter.
    • Path Matching Rule: Prefix match
    • Path: /
    • Destination Service: nginx
    • Destination Service Port: 80
    Figure 1 Configuring HTTP/HTTPS headers
  4. Click OK.
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress associated with an existing load balancer is as follows:
    kind: Ingress
      annotations:
        kubernetes.io/elb.id: <your_elb_id>                 # Replace it with the ID of your existing load balancer.
        kubernetes.io/elb.class: performance                # Load balancer type
        kubernetes.io/elb.port: '80'
        kubernetes.io/elb.x-forwarded-port: 'true'         # Obtain the listener port number.
        kubernetes.io/elb.x-forwarded-for-port: 'true'     # Obtain the client port number for requests.
        kubernetes.io/elb.x-forwarded-host: 'true'         # Rewrite X-Forwarded-Host.
      rules:
      - host: ''
        http:
          paths:
          - path: '/'
            backend:
              service:
                name: <your_service_name>  # Replace it with the name of your target Service.
                port:
                  number: 80             # Replace 80 with the port number of your target Service.
            property:
      ingressClassName: cce
    Table 3 Key parameters
    Type
    String
    A load balancer can obtain the port number of a listener using X-Forwarded-Port and transmit the port number to the packets of the backend server.
    • true: Enable the function of obtaining a listener port number.
    • false: Disable the function of obtaining a listener port number.
    String
    A load balancer can obtain a client port number for requests using X-Forwarded-For-Port and transmit the port number to the packets of the backend server.
    • true: Enable the function of obtaining a client port number for requests.
    • false: Disable the function of obtaining a client port number for requests.
    String
    • true: Enable the function of rewriting X-Forwarded-Host. Then, the X-Forwarded-Host header will be rewritten using the Host header of the client request and transmitted to backend servers.
    • false: Disable the function of rewriting X-Forwarded-Host. Then, the X-Forwarded-Host header of the client will be transmitted to backend servers.
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME          CLASS    HOSTS     ADDRESS          PORTS   AGE
    ingress-test  cce      *         121.**.**.**     80      10s
    Example
    Name
    ingress-test
    Load Balancer
    Dedicated
    Listener
    • Advanced Options
    • External Port: 80
    • Advanced Options
    Forwarding Policy
    • Path: /
  4. Click OK.
    kind: Ingress
      annotations:
      rules:
      - host: ''
        http:
          paths:
          - path: '/'
            backend:
              service:
                port:
            property:
    Type
    String
    String
    String
    kubectl get ingress
