- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Mobile App Management
Mobile Application Management is used to manage the enterprise WeChat configuration information required for creating an enterprise WeChat WarRoom.
Viewing Mobile Application Management
- Log in to COC.
- In the navigation pane on the left, choose Basic Configurations > Mobile App Management. If a tenant has been bound to an enterprise WeChat account, the binding information is displayed. If a tenant is not bound to an enterprise WeChat account, the page for adding an enterprise WeChat key is displayed.
Figure 1 Mobile application management
Currently, only Enterprise WeChat, DingTalk, and Lark are supported.
Adding a Mobile Application
- Log in to COC.
- In the navigation pane on the left, choose Basic Configurations > Mobile App Management. If a tenant is not bound to an enterprise WeChat account, the page for adding an enterprise WeChat key is displayed.
- To configure Enterprise WeChat, click Enable Now and enter the enterprise WeChat application ID, enterprise key, and address book password. The configuration method is the same for DingTalk enablement and Lark enablement.
- Click OK. If the message is displayed indicating that the mobile application is created successfully, the mobile application is created successfully.
Figure 2 Creating a mobile application
Changing the Mobile App Key
- Log in to COC.
- Click Modify Key and enter the enterprise key and address book key. The same applies to DingTalk and Lark.
- Click OK. If a message indicating the modification succeeded is displayed in the upper right corner, the modification is successful.
Figure 3 Changing a key
Deleting a Mobile Application
- Log in to COC.
- If the tenant ID has been bound to an enterprise WeChat key, the key information page is displayed.
- Click Delete. In the displayed dialog box, click OK.
Figure 4 Deleting a mobile application
Parent topic: Basic Configurations
