Creating an Alarm Conversion Rule
Enterprise IT architectures are becoming increasingly complex, and alarm data from multiple monitoring systems such as servers, network devices, and cloud services is in different formats and standards. These raw alarms directly go to the O&M process, which often floods systems with unnecessary data while burying key issues. Furthermore, such data leads to inconsistent fault handling standards, lowering fault response and team collaboration efficiency.
In the standard O&M system, COC, various types of raw alarms are converted to those that can be handled in a unified process. This ensures accurate notification and quick response. In addition, response plans can be configured to implement automatic fault recovery. To this end, alarm conversion rules are used for the standard process to handle alarms from different monitoring systems. This improves O&M efficiency with automation.
What Is an Alarm Conversion Rule?
Alarm conversion rules process all ingested raw integrated alarms by performing suppression, noise reduction, deduplication, and routing. They support vertical suppression and horizontal convergence across multiple monitoring sources to achieve multi-dimensional noise reduction.
These rules can aggregate one or more disparate raw alarms into a single aggregated alarm. Conversely, a single raw alarm can also trigger multiple conversion rules simultaneously. For details about the configuration items of alarm conversion rules, see Table 2.
- Before configuring an alarm conversion rule, ensure that the monitoring system for which the alarm conversion rule you want to configure has been connected in the Data Sources module.
- You have enabled the fault management package. For details about billing, see Billing Items.
- Once an alarm conversion rule generates an incident, no new incidents will be created by that same rule if its conditions are met again, provided the existing incident has not yet reached the Completed or Closed status. This suppression mechanism is enabled by default but can be disabled.
- If you receive no raw alarms within the corresponding time window for generating aggregated alarms using alarm conversion rules, the system considers the alarms generated in the previous window period as historical alarms (that is, the current alarm status is set to Handled by default).
- Log in to COC.
- In the navigation pane, choose Fault Management > Alarm Forwarding Rules.
- On the page that is displayed, click Create in the upper right corner. The page for creating an alarm conversion rule is displayed.
- On the page, set basic information about the alarm conversion rule by referring to Table 1.
Table 1 Basic information parameters Parameter
Rule
Specify the name of the alarm conversion rule you want to create.
Region
(Optional) Select a region.
If no region is selected, default is displayed, indicating that no region is required.
Enterprise Project
Select an enterprise project.
Application
Select an application.
- On the page, set trigger conditions for the alarm conversion rule by referring to Table 2.
Table 2 Parameters for configuring a trigger rule Parameter
Trigger Type
The options are Incident and Alarm.
- Incident: An incident ticket is generated. The on-duty personnel need to handle the incident ticket as soon as possible and continuously trace the incident ticket until it is closed.
- Alarm: Alarms are generated and are manually or automatically closed based on response plans.
Data Source
Select a data source.
A data source is the system where raw alarms are from.
Before configuring a trigger rule, ensure that data source has been integrated and enabled. When all conditions are met, the alarm conversion rule is triggered. For details about how to set the data source, see Integrating a Monitoring System.
Trigger Conditions
Select the key, comparison method, and value for the trigger conditions.
A maximum of five trigger conditions can be added. For details about how to set the keys, see Table 3.
Trigger Rule
Select a trigger rule.
Incident Level
This parameter is required only when Trigger Type is set to Incident. The options are P1, P2, P3, P4, and P5.
P1 incidents are the most critical, while P5 incidents are the least severe.
Silence Rule
This parameter is required only when Trigger Type is set to Incident. Enable or disable this rule as required.
After an incident is generated based on the alarm conversion rule, a new incident ticket will not be generated if the trigger rule is met before the incident ticket is completed or closed.
Alarm Severity
This parameter is required only when Trigger Type is set to Alarm. The value can be Critical, Major, Minor, or Warning.
Table 3 Parameters for trigger conditions Parameter
Alarm Field from Cloud Eye
Alarm Field from AOM
alarmId
Alarm ID
alarm_id
id
alarmName
Alarm name
alarm_name
event_name in the metadata
alarmLevel
Alarm severity. The options are Critical, Major, Minor, and Warning.
AlarmLevel
event_severity
time
Time when an alarm is generated
time
starts_at
nameSpace
Service namespace
namespace
namespace
region
Region
Region in template_variable
application
Application name
resourceName
Resource name
ResourceName in template_variable
resource_id in the metadata
resourceId
Resource ID
ResourceId in template_variable
alarmDesc
Alarm description
AlarmDesc in template_variable
URL
Raw alarm URL
Link in template_variable
alarmStatus
Alarm status. The value can be alarm (active alarm) or ok (alarm handled).
alarm_status
alarmSource
Alarm data source. For example, if an alarm is reported from Cloud Eye, the value is Cloud Eye.
additional
Additional alarm information. Format: additional.xxx.
Except the preceding parameters, other parameters are contained in this parameter and are represented by additional.xxx. For more information about parameters on Cloud Eye, click here.
Except the preceding parameters, other parameters are contained in this parameter and are represented by additional.xxx. For more information about parameters on AOM, click here.
recTime
Time when COC receives an alarm. The value is a 13-digit timestamp.
- Set the response plan to be executed after the alarm conversion rule is triggered. For details, see Table 4.
Table 4 Response plan parameters Parameter
Task Type
The options are Contingency plan, Script, and Job.
Automatic Execution
Determine whether to automatically execute what you have selected. Automatic contingency plans, scripts, and jobs can be automatically executed.
- If you select Automatic Execution, Parameter Mapping will be displayed. The system automatically executes tasks based on the trigger conditions and settings.
The parameter value, region ID, and target instance must be in the format of ${}. You need to use this expression to parse the corresponding value. For details, see Examples of Automatic Execution Parameters.
- If you deselect Automatic Execution, you can click the link on the left to manually execute the task.
- Set the owner to whom the alarm or incident is assigned after the conversion.
Table 5 Parameters for configuring a dispatch rule Parameter
Owner
Select Shift or Individual.- Shift: Select a shift scenario and corresponding roles from the drop-down lists based on the configured values. For details about how to configure a shift, see Shift Schedule Management.
- Individual: Select an owner. For details about how to configure an owner, see Personnel Management.
- Click OK.
After the rule is created, you can view the created rule in the alarm conversion rule list. After rules are configured for integrated data sources, any reported raw alarm will be automatically converted to an aggregated alarm or an incident that can be automatically handled.
Example:
Alarm data:
"alarmId": "al1696664837170EWbvx24kW",
"alarmName": "alarm-4z39coctest1007",
"URL": "https://console.***.com/ces/?region=***#/alarms/detail?alarmId=al16849986549022X5Vp4pxr",
"additional": {
"dimension": "instance_id:29d99a09-2d15-4ced-8723-6e94ae1c1472",
} - To obtain the value of alarmId in the current alarm data, use the following expression:
${currentAlarm.alarmId} - To obtain the UUID of instance_id from the additional.dimension string, use the following expression:
${string.substring(currentAlarm.additional.dimension, string.indexOf(currentAlarm.additional.dimension, 'instance_id:') + 12)}Alternatively, use the following expression:
${string.substring(currentAlarm.additional.dimension, 12)} - To obtain the region ID of cn-north-7 from the URL string, use the following expression:
${string.substring(currentAlarm.URL, string.indexOf(currentAlarm.URL, 'region=') + 7, string.indexOf(currentAlarm.URL, '#/alarms'))}In the expression, currentAlarm. is a fixed prefix, which indicates that the data is obtained from the existing alarm data.
More Operations
After an alarm conversion rule is created, you can disable, enable, modify, copy, or delete the rule.
| Function | Scenario | Description |
| Disabling an Alarm Conversion Rule | Once the rule is disabled, newly collected raw alarms will not trigger the rule. |
| Enabling an Alarm Conversion Rule | After the rule is enabled, newly collected raw alarms will trigger the rule. |
| Modifying an Alarm Conversion Rule | After an alarm conversion rule is created, you can modify it based on service changes. |
| Copying an Alarm Conversion Rule | You can copy a rule to quickly create a rule that adapts to new service requirements. This greatly saves time in new rule configuration. |
| Deleting an Alarm Conversion Rule | If an alarm conversion rule is no longer needed, you can delete it. Deleted rules cannot be restored. Exercise caution when performing this operation. |
