- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
War Room Members
After a war room is started, you can view members, invite members, set recovery owners and members, and remove members.
- Log in to COC.
- In the navigation pane on the left, choose Fault Management > WarRoom to view the war room list.
- Click a war room name in the war room list. The war room detail page is displayed.
- In the Member area, click Invite, select the attendance mode and the members to be invited, and click Add to WarRoom.
Parent topic: WarRoom
