- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Show all
Incidents
After an incident is created, it is in the unaccepted state. You can forward, reject, or accept the incident.
After an incident ticket is rejected, it becomes the rejected state. The creator can close the incident or update the incident information and submit it again.
After being accepted, an incident ticket is in the accepted state. You can perform operations such as incident handling, upgrade and downgrade, add remarks, and war room startup.
After an incident ticket is processed, it becomes the resolved and to be verified state. You can perform the verification operation. If the verification is successful, the incident ticket becomes the completed state. If the verification fails, the incident ticket becomes the accepted state again.
For details about how to add the incident-level suspension function, see Reviewing an Incident.
