- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Creating a Group
You can create a group to facilitate resource management by group.
Create a group on COC.
- Log in to COC.
- In the navigation pane, choose Resources > Application and Resource Management. On the displayed page, click the Applications tab, expand the target application, locate the component for which you want to create a group in the resource tree on the left, and click the plus sign (+) next to the component.
Figure 1 Creating a group
- Set parameters in the Create Group drawer by referring to Table 1 and click OK.
Table 1 Parameters for creating a component Parameter
Example Value
Group ID
(Mandatory) Group of the component you created. Enter a valid group ID.
testGroup
Group
(Mandatory) Group of the component you created. Enter a valid group name.
Test Group
Vendor
(Mandatory) Information about the vendor to which the group belongs.
Region
(Mandatory) Region to which a group belongs.
Resource Association Method
(Mandatory) Method that is used to associate resources with the group you created. There are two association methods: manual association and intelligent association.
- Manual: You can manually associate resources with the group you created for unified management.
- Intelligent: You can add all resources with the same tag in an enterprise project to a resource group.
Manual
Enterprise Project
(Mandatory) Enterprise project. This parameter is displayed when the resource association mode is intelligent association.
Tag Key
(Mandatory) This parameter is displayed if the intelligent resource association method is used.
testKey
Tag Value
(Optional) This parameter is displayed if the intelligent resource association method is used.
testValue
Associate APM Environment
(Optional) Configure the application, component, and environment of the APM service corresponding to the group. APM service performance information can be obtained through this field during fault diagnosis.
