- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Show all
Synchronizing Resources
You can synchronize resources from resource management platforms. You filter resources by selecting filter criteria or setting the columns to display on the Resources tab page.
A resource is an entity that you can use on the cloud platform. A resource can be an Elastic Cloud Server (ECS), an Elastic Volume Service (EVS) disk, or a Virtual Private Cloud (VPC).
To synchronize resources, you must have the rms:resources:list permission. This permission is used to call RMS APIs to obtain resources in all regions to which the current user belongs.
Synchronize resources from other platforms to COC.
Precautions
After resource synchronization is triggered, wait until the synchronization task is executed. The synchronization duration depends on the total amount of resource data to be synchronized.
- Log in to COC.
- In the navigation pane, choose Resources > Application and Resource Management. On the displayed page, click the Resources tab, select the resources you want synchronize (Elastic Cloud Server (ECS) is selected by default), and click Synchronize Resource.
Figure 1 Synchronizing resources
- In the search box above the resource list, select search criteria to quickly search for resources.
Figure 2 Filtering resources
- Click
to select the columns to display.
Figure 3 Column display control
