El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Show all
Reviewing an Incident
- Log in to COC.
- In the navigation pane on the left, choose Basic Configurations > Process Management. Click the Incident Review tab under Incident Process to configure the incident deescalation and suspension review processes. By default, incident deescalation does not need to be reviewed, and incident suspension is not available.
Figure 1 Reviewing an incident
- Click Create Incident Review to configure the incident deescalation or suspension process, and specify the incident process configurations, incident level, and review configurations.
Figure 2 Creating an incident review process
- After the configuration is complete, the incident deescalation needs to be reviewed on the incidents processing page. In addition, the incident can be suspended.
Figure 3 Incident processing page
NOTICE:
1. The created incident ticket process takes effect only after the incident deescalation and review process configurations take effect.
2. Incidents in the handled state can be escalated, deescalated, or suspended.
3. Before closing an incident, close the escalation, deescalation, and suspension e-flows.
4. Incident escalation does not need to be reviewed.
