El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
On this page
Failure Modes
Updated on 2024-11-20 GMT+08:00
A failure mode refers to a specific type of problem or failure status that may occur during application running. Build a rich failure mode library and formulate corresponding prevention and recovery measures to help design a more highly available application system. By identifying potential faults, you can perform routine drills to verify whether the fault recovery measures and fault impacts meet the expectations and prepare for better response to various challenges.
You can analyze the possible fault points of an application, create a failure mode by describing the fault occurrence conditions, fault symptoms, and customer impacts, and apply the failure mode to routine chaos drills.
Precautions
Check whether the enterprise project, application, event level, and scenario category of the failure mode are correct.
  1. Log in to COC.
  2. In the navigation pane on the left, choose Resilience Center > Chaos Drill. On the displayed page, click Risk Management Tasks, and click Failure Modes. On the displayed page, click Create Failure Mode.
    Figure 1 Failure Modes
  3. Enter the failure mode information by referring to Table 1.
    Figure 2 Creating a failure mode
    Table 1 Failure mode parameters
    Failure Mode
    Custom failure mode name
    Enterprise Project
    Enterprise project to which the failure mode resource belongs. default is the preset value.
    Application
    Application to which the drill target belongs
    Incident Level
    For details about the incident level, see Creating an Incident.
    Source
    Including Failure modes detected proactively and Existing failure modes.
    Contingency Plan Available
    Yes or No. The default value is Yes.
    Select a contingency plan from the drop-down list box. If no plan is available, create one. For details, see Emergency Plan.
    Scenario Category
    Failure scenario, including redundancy, disaster recovery, overload, configuration, and dependency
    Occurrence Conditions
    Possible conditions that cause the failure
    Fault Symptom
    Service symptom when the failure occurs
    Impact on Customer
    Failure impact on customers
  4. Select whether a contingency plan is provided. If you select Yes, select a contingency plan name from the drop-down list. If no contingency plan is available, create a contingency plan and click OK.
Utilizamos cookies para mejorar nuestro sitio y tu experiencia. Al continuar navegando en nuestro sitio, tú aceptas nuestra política de cookies. Descubre más
