El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Help Center/
Cloud Operations Center/
User Guide/
Faults/
Issue Management/
Handling an Issue Ticket/
Rejecting an Issues Ticket
If the issue ticket submitted by the creator is not an issue, the issue ticket can be rejected. The creator can edit the issue ticket and submit it again or directly close the issue ticket.
- Log in to COC.
- In the navigation pane on the left, choose Fault Management > Issues. On the displayed page, click Pending.
- Click an issue ticket name to go to the issue details page. Click Reject in the upper right corner. The creator can modify the issue ticket and submit it again, or withdraw and close it.
Figure 1 Rejecting an issue ticket
Parent topic: Handling an Issue Ticket
