El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Show all
Issue Process
After an issue ticket is created, its status is Not accepted. You can accept or reject the ticket, or transfer it to the owner.
After the issue ticket is accepted, its status becomes Locate the solution. You can enter the issue locating result, transfer the ticket to the owner, upgrade or downgrade the ticket, or suspend it.
After an issue ticket is suspended, it needs to be approved by the creator. After the ticket is approved, the status of the issue ticket changes to Suspend. You can manually cancel the suspension or the suspension is automatically canceled when the specified time arrives.
When you enter the locating result, if you select change-required, the ticket status is To be implemented on the live network. You need to associate with a change ticket and the change ticket has the backfilling result. In this way, the issue ticket can be transferred to the next step.
If an issue ticket does not require change or the issue ticket has a change result, the ticket status is To be verified. The creator confirms whether the issue is resolved or not. If the issue is not resolved, the creator can reject the ticket.
